I'd look for a solid mandrel bent Aluminum pipe to do that bend instead. I had a lot of problems with driveability on the supercharger setup and in hindsight I think it might have been due to the way I did that part of the intake.
Also, I had a question. Is it possible to set the intercooler vertical? Or is there just not enough clearance? What if the inlets on it were on the side facing the engine instead? I was thinking it would be neat to be able to use the stock location for the air filter if there could be room made for the filter. Mainly because I would be too lazy to do a battery relocate if I ever did a single turbo haha.
