Originally Posted by
NOTORIOUS VR
I'm actually rather curious as how you're tuning E85 on the street anyway... I don't see an optimal way to tune advance with it on the street or remotely unless you're on the dyno looking @ the actual TQ curves and seeing if you're at or past MBT (which is fairly easy to happen on E85 since it's resistance to knock is very very high).
Do you think you were conservative on your advance numbers? Or do you think you were pushing it?
Basically at each boost level I will dial in the AFR, and then adjust timing accordingly. On pump gas watching knock obviously, and with E85 analyzing data and logs to see if power increased. If power didn't increase or drops off then there's too much timing.
When the block broke I was shooting for 40psi (hit 42psi) and had bumped the nitrous. I would have been dialing in things from there once the boost was adjusted.
I will tear the block apart tonight, judging from the parts in the pan and the fact that coolant runs out of the block into the pan - I'm pretty sure the devastation I'm going to find will be awesome!
The closest awd dyno to me is 2 hrs away so I hadn't made it there yet.
Perhaps with the new engine I'll just man up and book it for a day and really dial things in there... although to be honest I feel I get very well dialed in from my street tuning...
