Originally Posted by
Max@034
While I do feel that this platform is seriously behind in cylinder head design and such, it's worth mentioning how important velocity is pre-turbo. Going big port is not always beneficial, although judging from the fuel system you are going with, I am guessing your Borg turbo is not the final size of turbo you will be testing?
We've done quite a bit of testing over the years concerning 5v porting, ranging from intake and exhaust port testing to oversized valve flow testing, and combinations of both. There is definitely power to be made on the intake side of things, so long as velocity is maintained based on the turbo size and displacement, etc. On the valve side of things, you need to be pushing some serious amounts of air to benefit from oversizing the valves. Power can be lost.
Increasing exhaust valve size and porting can hurt performance, especially if you aren't revving out and running a very large volume turbo. If your goals do not surpass 550whp, you may consider the disadvantages of porting to the levels it seems you want to port.
But probably one of my main points is, what cams will you be running? I hope CAT (or some other aftermarket cam). The stock cams (or even 2.8L) do not have nearly enough profile to properly take advantage of very large ports and oversized valves.
My plan is to find the limit of the stock heads and intake first, then I'll make an intake.
I'm not planning on running any cnc ported heads until after winter really. I haven't decided if I'll be using APB or 2.8 heads ether, but they will be +1mm on the intake side when I do go that route. The stock heads do not have enough intake throat size.
My customers are some of the best head porters in the world so trust me when I say I know a fair bit about heads and have access to the minds of people who do some amazing stuff...
One of the biggest problems people face is the stock exhaust manifolds and small turbos. There is a limit to how much they can flow which will ultimately limit how much the intake side can breath. You can pressurize the intake as much as you like but if the gasses can't escape then you get minimal gains. The extra flow capabilities you get from a single turbo setup should really help.
Oh and the 2.7 would really benefit from a much larger plenum size. In the order of 3.0 liters of volume or more. I really need to work on my plenum design...
And you are correct, I do plan on going with a larger turbo down the road... the injectors in the fuel system pic are 1680cc... so I have a lot of overhead ;-) but again not until I have a built bottom end. The S256 should be perfect up to the limit of stock rods.
Goal for now is just one fun daily driver.
