Page 11 of 14 FirstFirst ... 910111213 ... LastLast
Results 401 to 440 of 522
  1. #401
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Quote Originally Posted by peb View Post
    I'm not confused about the flows. What isn't clear to me is how the pcv works internally. For example, if it has a valve that requires pressure from the im to open the rear port, this won't work. If it is completely passive, then it will.
    I see where you're going with this. I'll try to draw a diagram of it later of what I think is the setup, but we really need a pcv torn down to look at valve placement.
    Ideally, I'd want to see a straight connection between B and C, with a valve tapped into it (D) to go to the IM. That way, the valve isn't in the path of the flow; if D is blocked or if the valve is closed, air automatically routes to B. It'd also work in the stock system: under vacuum, the valve would open and create a low pressure zone at D to draw gases out that route. Very little gases would then continue on to B.
    Joel, that is sexy. I can't tell in the light, but what color is it? I don't think I can pull off the lime green ones that are left
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
  2. #402
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    I think we the experts on this need to start a new thread woth just the fact and then close it, then sticky it.
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
  3. #403
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    This resource here is great; it got me looking into the pcv system. It's also a great open discussion about all things pcv.
    I'm already thinking of compiling together a large resource with links to everything pcv, as well as detailed descriptions of how the pieces interact with each other and other systems of the engine. Collaboration is welcome from anyone who is up to speed, but I think I'd want to keep ideas for fixes out of the thread. Facts and data belong there instead.
  4. #404
    Jul 19 2011
    Northern Minneapolis, MN
    I didnt read all since my last commend, but I did skim.
    Here is some info:
    If you want to route your breather port out the turbo side port, that is fine. This is actually probably the best bang for buck routing.
    What else do you need to do to make it work 100%?
    You need to plug the tube that goes from the intake manifold to the front PCV, and that is it. At that point, the setup is bulletproof, clean, OEM looking, and will work great! Plus it should cost you like $20 to do tops.
  5. #405
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Quote Originally Posted by CorneliusRox View Post
    Here is some info:
    Bingo. That's what I've done already, and it works great. I'll be updating my thread with consumption data after I've logged some more miles in the next couple of weeks, but so far it's promising! We were just wondering how the valving system works on the front pcv, and where it's tapped into the line. Any info on the VC and how often the baffles fail is something I've had my eye on too: it has to tie in to the failed valve cover gasket somehow. There's not a lot of info out there though.
    Btw Corey, I don't think I thanked you for the write up. It's helped me through diagnostics, and I'm sure it's helped plenty of others. If I was out in CO (like the rest of AZ B7ers) a round would be on me. But you'll have to settle for internet beer credits
  6. #406
    Jun 27 2011
    PCV Modification and Education Thread
    Quote Originally Posted by kaz02a4 View Post
    http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
    Someone buy this and dissect it! K thx.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  7. #407
    Jul 19 2011
    Thanks man! No brew needed, but if you ever head out this way, you should stop and hang out with the B7 community (and tj and jeff ;-) ).
    And I'm glad it helped you!
  8. #408
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Road trip? ROAD TRIP. I've got a few friends out there, plus the skiing is supposed to kick the east coast's ass. Tempting.
    Ninja edit: valve cover. Cool. I would be down to do this, seriously. Probably not by ordering it through ebay, but maybe a part out/pick-n-pull?
  9. #409
    Jul 19 2011
    Lived in Michigan for 22 years, Chicago for 2, and I agree that it is better out here. Let me know if you head out!
  10. #410
    Veteran Member Four Rings jsandor91's Avatar
    Jun 10 2011
    dead hookers
    South Jersey
    Bumping this. What are the plugs in the original post called went to two auto zones and couldn't find anything like it. And trying to explain what I was looking for and why was a nightmare lol.
    Sent from my Nexus 4 using Tapatalk 2
    Quartz Grey B7 A4 Quattro 6MT
    Maestro + Epy Tuned / GTX2867r / S3's / Spintech Non-Resonated 3 Inch Exhaust / Cold Side Synapse DV / TR18 + 2.5" Piping / Hpfp S1 Pump
    Bi-Xenon retrofit + Fly's leds / ST Coils + Rsb / 18x9.5 Miro 111's
    Dat Der Build Thread
    Coming Soon: Boost Manager +, Drakes Performance Stage V Clutch
  11. #411
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Quote Originally Posted by jsandor91 View Post
    Try a napa (that's where I got mine), but any hardware/autoparts store should have them. They're just an expandable plug; you take a wrench to one side and tighten to expand the sucker. Make sure to get the 3/4" OD plugs.
  12. #412
    Mar 03 2011
    STP, MN, USA
    i just installed the IE breather block off plate, and used a silicone "blanking cap" (basically a silicone bottle cap) to completely eliminate the breather tube.
    will this cause any issues?
    i just want to make sure im not gonan have any boost/vac issues that will cause any seals/gaskets to blow out, or lose power.
    so far when i first started the car i had slightly thicker white smoke from the tail pipes (looked as if i was running a test pipe when im currently not) but that went away after a 2 block drive.
    but the current "issue" im having is there is no blow off coming from my forge blow off adapter(i'm aware of the flaming that may come from me having that installed, plz refrain) im ok with the lack of a blow off sound as long as there is not a performance issue.
    the pcv itself is replaced with the JHM catch can setup, currently without the oil line to oil pan (the $10 upgrade option)
    *edit* i removed the block off silicone blanking cap from the "rear breather" hose port and replaced it with my old OEM breather hose, cut it in half, (retaining the check valve and the flex section) have it bent upwards at a near 90degree angle with a small "cone filter" attached. haven't driven with this but have started it... it gives the car a louder diesel sound however because of the check valve.
    after driving it, ill see if it bothers me in the cabin in which case i may remove the check valve or maybe use a small piece of foam or something inside the breather to silence the check valve sound.
  13. #413
    Established Member Two Rings Boarder4life's Avatar
    Jun 09 2013
    Denver Pa
    So from what I'm gathering I should be ok with just putting in a block plate and routing a hose with breather filter to atmosphere for the rear pcv and leaving my 3 port 034 cc as it is on the front pcv?
  14. #414
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    Quote Originally Posted by Boarder4life View Post
    Well, theoretically you would vent to air this way after having a third oil separator(034 cc) added. While it is fine, I wouldn't do it because you'll end-up breathing some of the fumes you'll put out in the engine bay. If you really want to vent to air just route a long heater hose under the car as far back as possible.
    Here's how I have mine.
    - Chip
    034 Stage 2 ECU | 034 Stage 2 TCU | Wagner IC | IE Downpipe | ECS CAI Intake | Fuel-it e85 | Mishimoto Catch Can
  15. #415
    Jun 09 2013
    Denver Pa
    Nice so no filter just a hose? Ever have any problems with it?
  16. #416
    Jul 19 2011
    I've been running no filter for a long time now with no issues. I think it works best with no filter. Fuel tanks have this style setup, and the length surprisingly keeps a ton of debris out.
    Shiro, I really love you vent being in the rear, and it looks like you did a great job with it (really great). I just want to warn you (since I used to design routing for stuff like this in a previous position), if you have any belly's in this, come winter, it will fill up with moisture, will freeze, and will clog. Just make sure there isn't any! I might do this as well though, or even put a venturi in it yet.
  17. #417
    Veteran Member Four Rings jrtrainor's Avatar
    May 07 2011
    94 yj 88 bronco 15 fusion
    The mountains, CO
    Venturi is still my end goal.
    B7 A4, GTX2867R 8.3:1 CR 2.149L motor Build
    C5 Allroad 2.7TT
    C6 A6 3.0T
    Sunday Wrench Days
    "Call him the Redneck mechanic with the beard of glory"
  18. #418
    Jul 19 2011
    Quote Originally Posted by jrtrainor View Post
    It would seriously take me 30min including jacking the car up to make it, but I just have no ambition to do so with my completely stock exhaust!
    Honestly I would love to do it before the CAT so it would burn everything up, but I think there would be too much back pressure from the CAT and for exhaust gasses back into the oil. And I think the further down the exhaust you route it, the less of a chance you would have to get anything back in the oil. Obviously, as the air travels it cools, and compresses, which makes the flow rate drop, and the venturi less effective, but I am willing to bet it will still draw at least a slight vacuum and at very least help route the smell away. Not that the smell is bad at all (at least not on my car).
  19. #419
    Jul 26 2009
    DMV Area
    That is a very good point, but what exactly you think will clog, the escape hose? I see that very possible if there's moisture left into the hose before turn the engine off. I might then have to rethink the last part of the hose cause right now there's a loop at the end, it's going up an down, I see how that will keep moisture inside the hose but not sure if that's enought to clog the whole thing. Now I'm a bit confused about the belly pan you mentioned unless you ment moisture/snow will get trapped under the belly pan and that will feeze, but I'm not sure how it will clog the hose? Please explain a bit.
    - Chip
  20. #420
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    I think by "belly" he just meant any low points in the routing. Like a trough or valley.
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
  21. #421
    Jul 26 2009
    DMV Area
    Quote Originally Posted by clemsongt View Post
    makes sense
    - Chip
  22. #422
    Jul 26 2009
    DMV Area
    aluthman is running venturi and came to the conclusion that is causing problems see post# 187
    http://www.audizine.com/forum/showth...o-build/page10
    - Chip
  23. #423
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    I have mine routed to about 4" downstream of where the testpipe and downpipe meet. It seems to work well, with only a little bit of smell and some smoke at startup, but none any other time that I have noticed.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
  24. #424
    Jul 26 2009
    DMV Area
    Quote Originally Posted by LoKisSpYdR View Post
    so you routed your on the other side, interesting. any reason for doing that?
    - Chip
  25. #425
    Jun 26 2012
    Reading, PA Area
    Quote Originally Posted by shiro1745 View Post
    It seemed to make sense from the thread on vortex and my understanding of the Bernoulli effect. It's still hot enough there to burn up most blow-by (beter there than on the valves) and it made routing easy.
  26. #426
    Jul 26 2009
    DMV Area
    Oh I see, you routed it into the exhaust. I thought you meant you just routed the hose for venting to air on the exhaust side.
    - Chip
  27. #427
    Jul 19 2011
    Yeah, sorry shiro. I meant a belly as a low spot where water could collect and it is lower than the lowest high point so the water couldnt drain other than from pressure.
    It's a big problem in routing air brakes on semi trucks (if you dont design for it).
  28. #428
    Jul 26 2009
    DMV Area
    I guess I have to spend some time under the car again and come up with a different route towards the end.
    - Chip
  29. #429
    Senior Member Three Rings dba4's Avatar
    Sep 02 2010
    Markham/Ontario
    i am trying to learn as much about this as i can and this thread is very informative. I came from the subaru world, and the catch can is the same idea. i was looking at a solution they have and wanted to get some feed back on if it would work for our cars or if its a bad idea all together.
    http://www.grimmspeed.com/catalog/pr...roducts_id=191
  30. #430
    Jul 19 2011
    Under vacuum everything would be going the opposite direction and the check valve before the intake runners would be closed.
    The catch can you posted looks solid and exactly like a catch can from one of our cars, but it just has a second port since you have a boxer engine. I mean you could run one from any car and just tee the two valve cover vents together.
    Just make sure that there is a reservoir under the screw in cap shown above for oil/fuel/blowby/vapor to sit in until you empty it!
  31. #431
    Sep 02 2010
    Markham/Ontario
    This assembly screws into where the oil cap is eliminating te need for a catch can. Kind of the same idea as catch cans with the drain routed back to the oil pan.
  32. #432
    Mar 24 2013
    Oakdale, CT
    I'm still trying to macgyver something up to make it work. I'm running a VTA catch can at the moment though, because I was getting oil out of the VC gasket with just the venturi. I think the check valve I have is garbage also.
    -Adam
  33. #433
    Jul 19 2011
    Quote Originally Posted by dba4 View Post
    Ahh, that's a pretty cool idea then.
  34. #434
    Jun 26 2012
    Reading, PA Area
    x2. Freakin brilliant! Quick someone make one for VAGs and patent it.
  35. #435
    Jul 19 2011
    ehhh, I like my vent to air still. lol
  36. #436
    Established Member Two Rings 808_implant's Avatar
    Sep 09 2012
    montgomery, Alabama
    Are there any PCV delete kits out there? Or should I just get a catch can set up?
  37. #437
    Jun 27 2011
    PCV delete?
    Did you read this thread? Like at all?
    -CP
    2017 Q7 3.0t
  38. #438
    Jul 19 2011
    Quote Originally Posted by 808_implant View Post
    PCV delete?
    x2
    This entire thread is about safely changing the stock PCV system to a bulletproof setup. Just read the first post and you should be able to gather all of your info.
  39. #439
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    You need to have a free flowing exhaust for this to work properly. I'm not sure id try it on a stock exhaust.
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
  40. #440
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Lensch09 View Post
    This. With an RAI downpipe and B&B catback, my PCV to downpipe setup was blowing oil past my VC gasket.
    -Adam
