Results 1 to 3 of 3
    Sep 13 2012
    VT/QC
    Exclamation No More Beep When Locking Doors With Remote
    On a 2001 Audi A4 Avant quattro 1.8T:
    When I first bought the car in April 2012, it used to "beep" its alarm horn and flash the corner lights once when I locked it using the remote. Over the last few months, that "beep" and corner light "flash" have disappeared. However the corner lights do blink (twice) when I unlock the car.
    If I hit the "panic" button on my remote all corner lights flash and the alarm horn sounds repeatedly. I can clearly hear the sound coming from the rear left quarter panel. So I know the alarm horn works fine. I can trigger the alarm purposely in multiple ways, and the alarm horn sounds just like it should.
    I've located the alarm horn on the left side, behind the CD changer, and it appears to be a standard metal horn, not a battery-backup horn sounder.
    I've also confirmed that the V94 central locking module is in excellent shape and has not seen any water. There's no signs of water intrusion anywhere inside the car.
    I've tried changing the coding on the central locking module using VCDS, but the +00512 and +01024 options seem to do nothing. Every other coding option works fine except those two. +00512 is Remote Control "Close" Confirmation (1x Blink). +01024 is Confirmation Anti-Theft Warning System Horn Activation. Both were enabled on my car from the factory. Enabling and disabling them doesn't appear to affect anything anymore. The module accepts the coding, but the horn still doesn't beep and the corners lights still don't flash when I lock the car using the remote.
    I used VCDS to go through output tests on the central locking module. One of the output tests is to check for the anti-theft arming confirmation beep. It appears to work fine, the alarm horn beeps briefly when performing that test.
    I've tried re-matching all our keys to the car using the instructions in the service manual and that worked fine, but it did not bring back the horn beep or corner light flash when I lock the doors. All batteries in our key fobs appear to be healthy (at least 3v from every battery).
    I'm at a loss. I'd really like the confirmation beep (and flash) to come back. I have no clue why it disappeared in the first place. Near as I can figure, everything works fine. But for some reason, the corner lights and horn are not being triggered when I lock the car using the remote.
    Established Member Two Rings dgirouard39's Avatar
    Aug 17 2012
    mine does the opposite. but check your connections in your doors. mine wont beep or do the corners if my doors aren't shut all the way
    Sep 13 2012
    VT/QC
    I finally figured it out after over a month of diagnosing. The hood sensor switch (that determines whether the hood is open) is defective and always registers as "open". Disconnecting the switch finally fixed the problem. Now the horn beeps and the corner lights flash when I lock the doors.
    ...what a major pain in the butt.
