Results 1 to 25 of 25
    Sep 13 2010
    Niceville
    Idle Rev Limiter..."Launch Control"???
    First off...I searched and googled, and came up with nothing.
    I've had my 2009 B8 A4 Manual for a couple of weeks now and just noticed that while stopped, there is a rev limiter. It's acting like a launch control of some sort. It will only rev up to about 4000RPM. The car is completely stock...so I was wondering if this is normal or what? Also, are there options to change it?
    Reason I'm asking is that once I get the car tuned how I want it, the 4000RPM might bog down and need to be raised to 4500 or so. Just curious. Thanks
    Established Member Two Rings bennydub's Avatar
    May 22 2011
    2011 Ibis White Audi A4
    Vancouver, BC, Canada
    This is normal and is like that for all audis. Safe guard to prevent over revving while in neutral or when the car is standing idle.
    Current Mods:
    APR Stage 1 93 Oct Mode, CTS Turbo FMIC kit (won in contest ), Awe quad tip exhaust w/ res. downpipe, Alu Kreuz DTS Bar, Hotchkis f+r sway bars, KW V2 coilovers, BC Forged rims, OSIR rear valence, PODI gauge+pod, Blackvue dash cam, Escort Passport 9500ix, Rhoplate plate relocator,
    Past Cars:
    1992 Acura Integra, 1992 Dark Blue 380 AWHP Nissan Skyline GT-R, 2002 Toyota Celica GT-S, 2000 Phoenix Yellow JDM front end Integra Type R, 1991 Nissan 240sx, 1993 civic si
    Sep 13 2010
    Niceville
    Quote Originally Posted by bennydub View Post
    It's not like that for all Audis. I say this because I've owned 3...this is the first one that's done it. This is my first B8 though, so it must be normal for the B8.
    Anyone know if it's removable?
    Feb 13 2004
    Silicon Valley, CA
    It is a standard "feature" on the B8 2.0T and the turbo does not really spool much if you are in neutral either.
    Kevin - Moderator, Audizine
    Veteran Member Four Rings howardfootball's Avatar
    Oct 20 2010
    '57 Ford Thunderbird
    MD
    You would probably bog down since you won't be building any boost. It's not anti-lag. I'm not sure on the B8's, but you can self tune for an anti-lag feature using the stock ECU. Builds about 6-7 pounds of boost.
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    Quote Originally Posted by panhandledubs View Post
    removable with APR stage 2
    2010 A4 quattro, Tiptronic, Ibis White
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Quote Originally Posted by dracolnyte View Post
    confirmed
    Jul 07 2009
    Lebanon
    Its standard on all B8s but....
    Quote Originally Posted by pierreb View Post
    confirmed
    Really? that's interesting....
    SOLD: 2010 A5
    Sep 14 2006
    My revo stage 2 won't let me do it.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    My APR stage 2 does not let me? Not that I really care to, but just interesting. Only know because revved it up a bit after getting my new IC installed. Maybe I'm missing something (or maybe I'm accidently in stock mode and I have more power left?).
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
    Veteran Member Three Rings ryank382's Avatar
    Aug 21 2011
    Bergen County, New Jersey
    this has bothered me as well. And what do you guys mean the turbo doesn't spool in neutral? what is the reason for this? i dont understand why its so hard to launch our cars
    2012 A4 2.0T Quattro: Brilliant black on black, 6MT P+ w/Nav
    flickr
    2020 A4 allroad
    NH
    ok I should clarify that I only tried this in Park. I guess I will try this while in gear tomorrow to see.
    Jul 07 2009
    Lebanon
    x2
    Quote Originally Posted by ryank382 View Post
    I don't have a problem launching the car at 4k rpm. Not sure why you are saying its hard...
    SOLD: 2010 A5
    Veteran Member Three Rings ryan_sn's Avatar
    Jun 01 2008
    2016 Audi S3 Daytona Grey
    Ontario, Canada
    I've tried launching my car at like 3500rpm's but I find when I let my foot off the brake the rpm's just drop and the car accelerates as normal.
    2007 Audi A4 2.0TQ Quartz Grey
    2012 A4 Quattro 2.0TQ Monsoon Grey
    Present:
    Future:
    2023 BMW M3 Competition xDrive - Toronto Red
    Aug 21 2011
    Quote Originally Posted by Wah View Post
    x2
    Do u drop the clutch or use a 2 step method? I thought dropping the clutch lead to bogging unless u had a tune. In that case idk
    flickr
    Jul 07 2009
    Lebanon
    I have the 7-speed Stronic gearbox so no clutch for me. Well there are two clutches, I just don't have control over them
    SOLD: 2010 A5
    Sep 13 2010
    Niceville
    This is "feathering" a clutch...and will burn it up pretty quick. Also, once you get into aftermarket clutches, this is much more difficult to do.
    You're going to have bogging unless you have more torque than stock...but I plan on doing a lot of upgrades, so I also wanted to know how to remove that limiter, so I can launch at 4500-4700, where it should be for this AWD car.
    Aug 21 2011
    haha well then its a little different
    you seem like you know more than me so im going to take this opportunity and ask a couple questions lol. Isnt it safer on the transmission but rougher on the clutch if you feather it? and why is it more difficult to feather an aftermarket clutch? i always thought dropping the clutch was really bad because of transmission shock. clutch is always replaceable but the transmission is a bigger deal.
    flickr
    Established Member Two Rings mgm's Avatar
    Aug 04 2009
    Pittsburgh, PA
    I believe the rev limiter turns off when you turn off DSC. Press and hold for 8+ secs.
    Delivered 5/9/09: 2009 A4 2.0T Quattro 6MT, Premium Plus, 18" Sports Package, Quartz Grey/Black Interior
    Added: APR Tune, Chrome Tips, 35% Tint, A4 Rubber Mats, 16GB SDHC Card, Rieger Lip Spoiler, Vag-Com Tweaks, Interior LEDs, Custom "APR TUNED" License Plate Frame, H&R 15mm Wheel Spacers, EuroCode HF Intercooler Pipe, Yellow Tinted Fogs
    Sep 13 2010
    Niceville
    I don't claim to know a lot, but I have spent a lot of time at the track and have built up several cars. I would never recommend "dropping the clutch"...feathering is going to be better, but that doesn't mean it needs to be drawn out too longer either...and higher RPMs are still needed to get the desired launch. The reason feathering is harder on an aftermarket clutch is because the "space" between when the clutch BEGINS to engage and is FULLY engaged is much much shorter and very exact on a good clutch (especially higher in the "Stages" that you go and "Street" vs "Race" clutches). Hope that makes sense.
    Aug 21 2011
    most definitely makes sense, thanks for the info!
    flickr
    Sep 13 2010
    Niceville
    Quote Originally Posted by mgm View Post
    Didn't even think of that...that did it. Held down the ESP button until it completely shut off, then I can rev past the 4k...peeled out a few times too ;)
    Established Member Two Rings Countryboy's Avatar
    Jun 05 2011
    2010 Toyota Tundra SR5 CrewMax 5.7L V8
    Edenton, NC
    Corrected.
    2012 Glacier White A4 Prestige 6MT, Sport Package, S line Plus, Debadged, Tint
    Aug 04 2009
    Pittsburgh, PA
    This is a joke right? The only fluid in a manual transmission is in the gear box and hydraulic fluid to operate clutch. The clutch/pressure plate itself is a dry system.
    Jun 05 2011
    Edenton, NC
    Sorry, woke up on wrong side of my brain. Thinking of AT & MT at the same time. Thanks for correcting me. Not looking to spread bad info.
