Page 1 of 3 123 LastLast
Results 1 to 40 of 90
    Veteran Member Three Rings catbed's Avatar
    May 22 2011
    South Jersey
    B5 A4 01E Swap Info Thread
    Having just completed this swap, I found it very difficult to find all of the information necessary to complete it. There were many posts I found simply listing all of the parts related to the drivetrain, and others needed only a few of them. There are many parts needed to complete the swap, available from many different cars, and depending on which route you take and the year of your car it can be completed fairly easily. I figured I would make a thread where we can organize all of the information in one place to help anyone doing the swap later on.
    Some background: My car is a BAT 01 A4 Avant with an AWM 1.8t that is making close to 400AWHP. I saw full boost (25psi) at ~4800 RPM with the 01A. The reason I swapped a 6MT into my car is I had already blown up 2 5MT and wanted a transmission I could drive without worrying about breaking. So I used an 01E out of a 01.5 B5S4. I bought the trans used with 100k miles with the linkage and mounts for $800, which is a fairly low price. Most 01Es that don't require an immediate rebuild are around $1000, but you can score ones needing a 1-2 syncro or shift collar for around $4-500. The 1-2 syncros breaking and shift collars are common problems on 01Es.
    First things first, is this transmission suitable for a 1.8L 4 cylinder engine?
    This is the most asked question I have noticed when researching the swap. Having driven both now, around town and on the highway, I feel I can shed some light on the subject It isn't the ideal transmission, simply because it was meant for an engine that produced more torque than our 1.8Ts can, ie the 2.7t. Because of this, 1-3 gears are slightly taller, and 4-5 are slightly shorter. HERE is a thread that discussed the gearing of various transmissions, both 5- and 6-Speed.
    The gearing is not really noticeable in first gear, but I did notice a slight difference when driving around town in 2-3. It is not bad to drive at all, and with the shorter 4.11 final drive vs. the 3.89 of the 5 speed, it really doesn't struggle to accelerate at all around town. On the highway, it drives pretty much the same, but there is more shifting necessary to keep it in the powerband, but that is with any BAT car really. At 85mph, the engine is turning at 3500 RPM, a drop of about 500 RPM from the 4k RPM with the 01A. I did notice an increase in gas mileage on my 252 mile trip to school, averaging about 22 MPG with 630cc injectors and tune. That was not all just cruising either, as I did multiple pulls and a tunnel blast.
    Now that you've decided you want to get rid of your 5MT and swap in the much stronger 6MT, you'll need to gather your necessary parts. Depending on what year your car is dictates what parts you will need, and there are several options to take. There are several differences between the 5MT and the 6MT that need to be addressed before the swap can be completed. The option that I took is the easiest and the cheapest, IMO.
    I'll break it down into the problems that you will face during the swap, and solutions to them depending on which car you are swapping into. The first thing to consider is:
    Mounts
    1. If you drive a V6 A4, then you will be able to utilize the stock 01E mounts, since you share the same subframe as the S4.
    2. If you own a 1.8T A4, then you run into the problem of their subframe using a different style mount on the drivers side. To solve this problem, you can either:
      • make your own bracket for the stock 1.8t mount
      • cut the 1.8t mount off the subframe and weld in the V6 bracket
      • swap subframes
    Since my car is a 1.8T, I had to do something about my drivers side mount. I chose to make my own bracket for the mount since I had an 034 Street Density mount there already.
    Axles
    The S4 uses a 108mm inner axle flange rather than the 100mm flange that the A4s use. To make this work, you can:
    • Swap 100mm flanges into the 01E, but the ones from the 01A do not fit. Where can you find 100mm flanges that will fit into the 01E? The stock rear diff. They bolt into the diff using a hex head bolt, just like the 01E. So remove the screws, swap the flanges, and put the bolts back in. MAKE SURE YOU KEEP THE BOLTS WITH THE FLANGES. The 01E flange bolts will not work with the A4 diff cups.
    • Swap in the front axles from an S4. To do this, different parts are needed depending on the year of the car.
      96-00 A4 1.8t
      • S4 Axles
      • S4 Uprights & Hubs
      • S4 ABS Sensor
      01 1.8T & 96-01 V6
      • S4 Front axles
      Since the 01 1.8T and V6 A4s all have the same larger outer CV Joint as the S4, no uprights are needed to swap in S4 axles.
    Rear Diff
    Because the final drive of the 01E is different than the 01A, the rear diff has to be changed. There are two differentials that will work, both have the code DAK:
    • S4 Rear Diff
      Direct bolt in, requires use of S4 rear axles or swapping of the diff flanges
    • Tiptronic A4 Diff
      Direct bolt in, uses stock A4 axles
    Driveshaft
    The 01E is a few inches longer than the 01A, so a shorter driveshaft is needed. There are not many ways around this, you either have to use a S4 unit, or a aftermarket 1-piece unit made for the B5S4.
    Shifter
    The 01E shift rods can be used with any shift box in the car, but the 5MT shift boxes will NOT have a reverse lockout. The H-pattern isn't exactly nice, since I think the pivot ball on the 6MT shift boxes is moved slightly to the left.
    Other Issues
    I started a different thread asking whether or not I would have clearance issues with my CM FX400 240mm clutch/FW combo. The answer is there is no clearance issues and the cranks spins without issue when the transmission is bolted down.
    EDIT: I found out this is not actually true. My fx400 disc was rattling, so I pulled the trans after about 5k miles. The CM flywheel/fx400 combo rubs the bellhousing ever so gently. Not enough to make a terrible noise, but enough for there to be marks before it self clearances. I have included a pic below. I simply removed slightly more material using a die grinder. Re-installed everything and haven't had a problem since.
    The route I chose consisted of swapping the trans, driveshaft, and diff. The diff I got from an automatic A4 so everything else is stock A4. Because of this, I was able to complete the swap for just $1100.
    • Trans - $800
    • Driveshaft - $100
    • DAK Rear Diff - $200
    I am currently using my 01A shifter but plan on swapping in a 6MT very soon, and they are very inexpensive.
    That's pretty much it for now, if I come across any relevant pictures I'll edit this post and add them in. I have a few pictures of my swap, but I just need to get them off my camera. If anyone has any info to add, post it up and I can either add it to the first post, or at least it will be in the same thread if someone is searching.
    01 A4 Avant <- TwinScroll T3 jawns
    Built 06A|Built AEB|RR Stg3 Clutch|01E 6MT|60 Trim|1000cc EV14s|Bad MAF|Clunking Suspension|Cracked Dump tube
    NefMoto Tuned
    Senior Member Two Rings lorge1989's Avatar
    Jan 27 2012
    Buffalo
    http://www.audizine.com/forum/showth...or-01E-amp-01A
    Lots of info there. And it is a well know issue that the O1E has absolutely terrible ratios when compared to the O1A for any motor that has a decent size turbo. When doing this swap the question is not if the ratios are okay, but is the sacrifice worth it. That is, is the durability of the O1E worth the sacrifice of gear ratios. Most of the time the answer is yes if you go through all the trouble.
    Daily : 2012 JSW TDI 6MT
    Project : 1988 Audi 90 1.8T 20v, COMP 5858 + MS3X.
    Dubs in the Buff!
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    Get a taller 6th gear while you are doing it, its fucking awesome on the highway.
    RIP Daz, you will be missed.
    May 22 2011
    South Jersey
    Quote Originally Posted by lorge1989 View Post
    Thanks for the link, I'll add it to the post.
    Quote Originally Posted by Meow View Post
    So I have heard. My friend is planning on doing that in his S4 when the time comes to rebuild.
    Added info to first post, and formatting.
    NefMoto Tuned
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    i havent researched the 01e swap much (not really interested), but nice to have this info in one place. i really thought the swap couldnt be done for less than $2000, unless a donor car was had for less. kudos
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Veteran Member Three Rings Urtorsen's Avatar
    Feb 09 2009
    chicago
    FAQ....DIY ...STICKY!!! Please.....so we can have this in the future.
    Oct 19 2011
    Tacoma. PNW
    Just a thought here, I know it would be labor intensive, but couldn't you swap 1-5 gear of the 5 speed to the 6? And then get a taller 6th? Or since people seem to like the rs4 3rd gear have the gears be 1,2,4,5 from the a4. 3 from the rs4 and 6th as a tall gear?
    Jul 27 2010
    Queensland, Australia
    Good info!
    Vote for a sticky/FAQ!
    Jan 27 2012
    Buffalo
    No you can't. 1st and 2nd are part of the input shaft. I don't believe its possible, or it is but its not possible from a financial standpoint. The biggest issue with any of the 01Es is the 1-2 shift. 3rd and 4th are tall but manageable. If you ever get into 5th and 6th and need to know how fast they will take you there is a good chance you are going way too fast.
    On that note I don't think I'd ever get a longer 6th gear with a 1.8T. It might be cool for a 2.7, but it would bog and bog and bog if you ever had to pass at a speed under 80.
    Dubs in the Buff!
    Feb 09 2009
    chicago
    Quote Originally Posted by Ziggydub View Post
    maybe the input and output shafts are different on each
    Veteran Member Three Rings un1ko's Avatar
    Feb 10 2007
    Las Vegas
    Good info!
    New Build - S4 with A4 Heart| 01 Audi 2.0T S4 6MT | CT43-6465 TBB | 82.5 Supertech Pistons | IE Tuscon Rods | Supertech single Groove Valves & Springs | 3660 Cat Cams | SEM Intake Manifold | 75mm RS4 TB | | 1000cc FIC | Eurodyne Maestro 7 | 450 Walbro Fuel Pump | Clutchmaster FX400 8-Pad Clutch | 44mm Tial Wastegate | 50mm Tial BOV | Treadstone TR1035 FMIC |
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    Great info, was thinking about the swap... maybe in the future.
    Jun 16 2011
    996tt
    MA
    needed to subscribe sorry guys
    Oct 19 2010
    2012 Jetta TDi
    Lexington, KY
    Is there any wiring that needs to be done?
    I was under the impression that you needed to wire in a connector from an S4 harness into the A4 harness.
    Thanks!!
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    I just wish there was a trans with the same gear ratios but one more for 6th. I drove down to NM from Denver and was cruising at 80+ and I would really like to save the gas. Out west there are many stretches of road where cruising well over 80 is possible. I even ramped it up to 140 for a sec.
    May 22 2011
    South Jersey
    Quote Originally Posted by derekb727 View Post
    Thanks!!
    The only thing that is different wiring wise is the reverse light. 01A uses a 5-pin and the 01E uses a 2-pin.
    Quote Originally Posted by nynoah View Post
    The B6 A4 3.0 USP 01E has slightly friendlier ratios for a 1.8t.
    EDIT: Added info about CM/fx400 clutch combo.
    NefMoto Tuned
    Jan 16 2006
    LA CA
    Yeah but what does it take to put that trans into my 01 1.8T?
    Oct 19 2010
    2012 Jetta TDi
    Lexington, KY
    Quote Originally Posted by catbed View Post
    So the speed sensor has the same clip and you will use the sensor for the trans. So 01E sensor stays in, you do not have to swap speed sensors?
    For the reverse light you need to wire in the correct clip in order for it to work?
    Thanks
    May 22 2011
    South Jersey
    Same process as this thread.
    Thanks
    Speed sensor is the same, it stays in the trans. No need to touch the connector for that either.
    For the reverse lights, you just need to clip the old wires and solder in about 12" of wire with the 2-pin connector. You can use any 2-pin connector i.e. N75, fuel injectors, etc.
    NefMoto Tuned
    Oct 19 2010
    2012 Jetta TDi
    Lexington, KY
    Is there polarity or can i just connect either wire?
    Thanks for the help
    May 22 2011
    South Jersey
    Thanks for the help
    Just a switch, so doesn't matter the polarity.
    NefMoto Tuned
    Veteran Member Three Rings b518's Avatar
    Jun 20 2011
    long island
    Re: B5 A4 01E Swap Info Thread
    Nice was looking for this
    Sent from my SPH-D710 using Tapatalk 2
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Nice would love to do this later on, driving my GFs 3.0 6speed is a dream on the high way.
    SOLD the GOINHAM A4 ---> GT2860 Project
    Nov 03 2011
    All Over!
    I did just that - but I replaced 4th, 5th and 6th with gears from a 2004 C5 Allroad 2,5 TDI. I feel replacing just 6th (depending upon the source, and how tall) will create quite an rpm drop when shifting from 5th to 6th.
    1986 Type 85 Audi 90 quattro
    Oct 19 2010
    2012 Jetta TDi
    Lexington, KY
    Okay, last question.
    On the 01E trans that I have there is a sensor that it towards the top that came from the donor car. it is close to the edge of the bell housing and looks to go over the flywheel.
    Can anyone tell me what it is and if I need to use it?
    If I remember correctly there was no sensor there for the 01A
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    That's the crank sensor on the S4. You do not need it.
    1990 Audi Coupe Quattro - 4.0t 6spd swapped
    4.60 60-130mph Xona 10569s E70
    Oct 19 2010
    2012 Jetta TDi
    Lexington, KY
    Trying to do the install right now.
    I read everything I think.
    Do you use the spacer or not?
    The one that goes between the engine and trans?
    Jan 16 2006
    LA CA
    Spacer is for the 2.7
    Active Member One Ring lepermessiah's Avatar
    Jul 12 2013
    Slovakia
    Hi guys,
    I came here few months ago when I was searching for some hints for swapping my old 01A transmission to 01E. Well, nothing is perfect and that's why I need to ask for your help :/
    Reasons for transmission swap were:
    1. my old 01A wasn't in her best condition - when breaking with engine, after shifting from 4 to 3 and 3 to 2 whole car was wincing
    2. I'm driving 60% out of city with average speed 70-90mph, so tall 6th gear was really good reason
    After swapping (my mechanic did it) transmission and putting new Valeo 228mm clutch in, I had big problems with starting engine and shifting. When I started engine, clutch (I think it was clutch) was making scratchy sounds and it stopped after few minutes. I couldn't change gears without turning off engine because when I pressed clutch pedal, nothing happend. When the car was towed with engine runinng and without gear, after 2 miles there was terrible smell from clutch (RPM on cluster were at 900). After asking catbed throught my friend I swapped clutch slave cylinder and problems with shifting are gone. Scratchy sounds are gone too, but I think it's because that something just got chipped of from transmission body or clutch plate.
    Now I can start without problems, shift without problems, but clutch still smells as it's slipping and I can't go faster than 20mph.
    Here is video of my problem, you can see it best between 2nd and 10th second (RPM vs speed). Does anyone know what's wrong with it? My mechanic says that clutch is mounted OK, clutch fork too, slave cylinder too... :/ He doesn't know what to try and he also doesn't have time to investigate that problem... when I was asking about clutch plate setup (as I saw something on YT from ZF for proper setup of plate) he told me, that there is no setup needed for clutch in B5
    Oct 06 2004
    Minnesota
    Did he bleed it?
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Jul 12 2013
    Slovakia
    of course he did :/ clutch pedal is working normally as before, only clutch is slipping
    May 22 2011
    South Jersey
    So it sounds like the clutch is not engaging fully. What TOB did you use?
    Which clutch/flywheel did you use?
    NefMoto Tuned
    Jul 12 2013
    Slovakia
    hmm I don't understand what "TOB" is :/
    flywheel is stock from my 1.8T AEB, it was in perfect condition. Clutch set is Valeo 228mm (I will switch to Stage3 later so I just wanted something in normal price)
    EDIT: so I've searched for TOB :) .. it's used from Valeo set
    EDIT2: I've asked mechanic about clutch set. He doesn't know what brand of flywheel is there (but it's the one from factory - 162k miles on stock clutch, not bad :) ) and whole clutch set (clutch, clutch pressure plate, release bearing) is Valeo 228mm set. He told me, that he mounted over 200 clutches and the problem that my clutch is not working is because there is that 01E transmission and so it won't work. I wonder why everybody else here doesn't have such problems ..
    PS: I read somewhere on net that Valeo release bearing is little bit thicker than Sachs/LUK and that Sachs pressure plate won't fit on LUK flywheel, so I hope that I don't have LUK flywheel
    May 22 2011
    South Jersey
    Quote Originally Posted by lepermessiah View Post
    I'm not so sure the AEB flywheel will play nicely with the 01E, especially a stock flywheel. And I know that some TOBs are longer than others, as you have said. I believe the problems lies in the flywheel and TOB.
    NefMoto Tuned
    Jul 12 2013
    Slovakia
    well, let's give that Valeo set a chance, what flywheel will you recommend then ? I don't want super lightweight flywheel because I'm not using car for racing or so .. I'm planning to have GTRS mounted before winter, so I don't know what to get. the problem is that 1.8T has 6 bolts but 2.7 has 8 bolts, so S4 flywheel won't fit :/
    Nov 03 2011
    All Over!
    TOB is the same for 01A and 01E. Sounds like the clutch is too far from the TOB / lever. This can occur if the flywheel is too thin, giving a combined clutch stack height of less than 83mm.
    Was the spacer plate used?
    May 22 2011
    South Jersey
    You have it backwards. The TOB is pressing against the fingers causing the clutch to be disengaged slightly, causing slip.
    ECS has the RA flywheel, or you could just get a SMFW. My ClutchMasters SMFW weighs 19lbs.
    S4 flywheel is too thick for the 1.8t block anyway.
    NefMoto Tuned
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Catbed,
    Did you happen to look into rebuilding the 01A transmission? And if you did, what was the that cost vs. the 01E swap?
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Jul 12 2013
    Slovakia
    @catbed I see that clutchmasters have dealer in our region, so I will try to ask him, but can you tell me which flywheel ? I'm lost on their page, I like their FX-250 kit but it's without flywheel. I don't know if I should go for 240mm or 228mm flywheel (or is it the same?)
    ECS is only in US so it would cost +40% to deliver and pay duties etc.
    Jul 27 2010
    ^^ suggest contact mike@ringer racing for flywheel and clutch deals. I just placed an order for a 240mm FX350 clutch kit with a 2500lbs PP. I already have a Spec 16lbs 240mm flywheel.
    99.5 A4 1.8TQ MT
    1.9L built/blueprinted motor, JE assymmetrical pistons, IE Tuscan Rods-JNL racing custom ported head, IE CVA2 camshafts-BW EFR7064 .92 IWG-Full-race T4 manifold-1150cc injectors +++++++++
    Instagram : e85.A4
