Page 5 of 5 FirstFirst ... 345
Results 161 to 190 of 190
Hybrid View
    Oct 29 2018
    Michigan
    From the grave....
    Keeping the allen wrench pointed towards the back and turning allowed me to break the bolt - thank you! Onward with the removal.
    Junior Member Two Rings
    Oct 04 2013
    Bucks County, Pennsylvania
    This is a great thread. Thanks for taking the time to put it together and embedding all the pictures. I am replacing the turbo on my 2010 B8 A4 and have bought the replacement OEM turbo and installation kit from ECS.
    Some questions:
    1) I realize this thread is for those upgrading to a K04 turbo, but I am assuming all the steps are the same as someone just replacing the turbo with an OEM one. Is there another thread or web link detailing the steps? This is the best one I have found so far.
    2) Since I am not replacing the cat or down pipe, can I just undo the four turbo to cat bolts and replace the turbo? Is there enough room to get the turbo out? If not can I undo the four turbo to cat nuts and unhook the hangers to drop the exhaust?
    3) Do I have to remove the O2 sensor from the cat?
    4) From reading this, it seems to be a real PITA if the nuts come off the studs holding the manifold to the block. Any tips there to ensure the studs come out with the nuts? I am guess there is not enough room to get an impact wrench in there and heating the nuts would make the nuts more likely to thread off the studs. Soaking the studs and not the nuts with PB blaster?
    5) is there a link to all the torque settings for the bolts during reassembly?
    Thanks. Good suggestions for all the tools to get in order to make the job easier. My Amazon shopping cart is full!
    Paul
    Jun 03 2010
    2010 A4 Quattro, 2017 VW Golf Sportwagen 4motion
    Fort Myers, FL
    Started the job of replacing my k03 today, got all the cat nuts off no problem, but now I'm stuck on the 6mm Allen heat shield bolt. I cant get a 6mm to fit into it like the original post said to. A 5.5mm fits all the way in but it's too loose. Every Allen wrench or bit I have hits the manifold. Thinking about cutting a 6mm L shaped allen down shorter, that's all I can think of at this point. Any other ideas?
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    2010 Audi A4 Quattro, Follow my repair videos on youtube: https://www.youtube.com/c/carsandcoding
    Jun 03 2010
    Fort Myers, FL
    Quote Originally Posted by cuda2000 View Post
    I think I'm gonna drill it out....
    Sent from my SAMSUNG-SM-G891A using Audizine mobile app
    Oct 04 2013
    I just did this job and had a 6mm 3/8 drive socket that got it out with no problems. I am guessing the one I have is a little longer than yours.
    Paul
    Jun 03 2010
    Fort Myers, FL
    Quote Originally Posted by PaulThBrit View Post
    Paul
    That's what I tried first. A 5 or 6 inch straight allen in a socket. I think that stripped it and it was downhill from there. If the metal is that soft I should be able to drill off the head in 10 minutes. I dont see a need for more than the 2 bolts on the sides. If she rattles, at least I have full boost with the rattle, gotta keep moving forward!
    Jun 03 2010
    Fort Myers, FL
    All right, after a call to suicide hotline and talked me out of jumping out 1st story window, I jammed a t40 torx bit into it and it turned out! Moving on to step #8!
    Jun 03 2010
    Fort Myers, FL
    Thanks to all for this thread and helping me vent my issues as I did the turbo swap.
    I used this info to film a DIY K03 Turbo Replacement and ebay test pipe Video.
    My 2010 A4 Quattro with 86k miles, which I have owned since brand new, had a faulty wastegate and p0299 code.
    So, I replaced the turbo and added an Ebay test pipe last week and I made a DIY video. Will go with Stage 2 Unitronic in a couple months.
    The video starts out diagnosing the problem, then I go through step by step how to do the install.
    Enjoy!
    https://youtu.be/bW70AlIyof8
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Senior Member Two Rings nataraki's Avatar
    Jan 15 2014
    Hayward, CA
    Subscribed for future use, thanks OP!
    Dec 13 2015
    Too%20many%20
    PA
    Quote Originally Posted by nataraki View Post
    Tip to remove that bastard hex fitting on the heatshield before mangling it. Buy one of those 40 piece bit sets from Harbor Freight, the kind that comes in a red rubber block.
    Use the 5mm hex bit and a long 1/4in wrench to remove it. A long bit hits the manifold; pretty much anything longer than 1/2in hits the manifold (bit, hex key, etc).
    Jun 30 2020
    Nashua NH
    I have a question not directly about installing a KO4 but moreover a little clarification for a different project. I'm putting in an Oil Pressure gauge into the car and those of you who may have taken on this job with any TFSI engine may know the turbo oil feed line is the ideal spot to put in a banjo port for a pressure sender. I was just trying to figure out specifically which port is on the B8 KO3. Would it be the oil line circle in step 12 of this DIY?
    If I'm not mistaken the circled port is the turbo feed and the turbo return line is on the other side and had a gasket connector rather than a banjo bolt.
    If anyone could confirm that if they happen to know I'd be very appreciative.
    Thanks, guys!
    Senior Member Two Rings unmarkedA4's Avatar
    Jun 11 2017
    Bonney Lake/ Wa
    Quote Originally Posted by Assetto31 View Post
    Thanks, guys!
    Correct
    Jun 11 2017
    Bonney Lake/ Wa
    Correct
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    So I'm way behind on this thread, but I'm finally installing a K04 on my Allroad. Everything went fairly well so far. New turbo is bolted in, but now I'm hung up on the passenger side coolant banjo. I cannot get the thing to thread in correctly. If I pull the banjo back, and try to thread the bolt straight into the turbo, it goes in pretty easy. When I try to thread it through the banjo fitting, I cannot get the treads lined up.
    Is there any sort of trick to this? I've removed the M8 screw below which bolts the coolant line down. This gives me some extra play in the coolant line, but I still can't get it. This has been going on for hours, I'm at a loss. CTS K04.
    Sent from my Pixel 2 XL using Tapatalk
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Jun 11 2017
    Bonney Lake/ Wa
    Everything lines up. Just take your time. The only thing i had attached to the turbo was the oil drain and the top coolant line.
    Dec 27 2009
    Edmonton/Alberta
    Quote Originally Posted by unmarkedA4 View Post
    I got it today. I finally got over my fear of cross threading it, and gave it a turn with the wrench. After that it went in smoothly. The thought of cross threading something this late into the job was unnerving.
    Kyle
    Dec 27 2009
    Edmonton/Alberta
    So that same coolant banjo was dripping a bit after startup. I was able to tighten it a little further. It seems to be seeping a little bit still. I've tightened it as much as I'm comfortable doing. I'm hoping it sort of seals itself after a couple heat cycles of the turbo.
    Other than that it's looking pretty good. Had the outlet hose pop off on the first test drive. And it came off with some authority. Scared the shit out of me and some pedestrians in the area. It's tightened up better now.
    Kyle
    Jun 11 2017
    Bonney Lake/ Wa
    Quote Originally Posted by KFizz View Post
    Did you use new crush seals? Should be using 2 Crush seals
    Dec 27 2009
    Edmonton/Alberta
    Yeah I used 2 new washers, the inside one was a thicker spacer washer as well. I'm pretty positive that it's installed correctly, it's just not quite sealing.
    Kyle
    Nov 09 2019
    Earth
    My KO4 goes on Next week. Stock K03 is dying at 125K miles.
    Jun 30 2020
    El Monte, Ca
    Did anyone have any issues connecting intercooler house to turbo? I noticed my cts intercooler did not fit properly on my hpa k04 turbo? I noticed the intercooler house is bigger and the hpa doesn’t have a turbo muffler delete like the k03 does. Please help I don’t want to drive with a loose house :(
    Nov 09 2019
    Earth
    There is a 2.5" to 1.8" or so coupler conversion piece. This is what I have on my cat to adapt the 2.5" intercooler tube to the HPA K03.
    Feb 13 2004
    Silicon Valley, CA
    Going to do this later today.
    Do I need any gasket adhesive for this?
    Kevin - Moderator, Audizine
    Jan 18 2022
    2015 A4 Prem. Plus, 1987 Scirocco 16V
    Raleigh, NC
    I dont think you will. Just a new exhaust manifold gasket, new oil line gaskets & oil line O rings. and maybe some coolant line crush washers.
    Feb 13 2004
    Silicon Valley, CA
    Ok, started this today about noon my time and gave up around 445 as it was getting dark outside. I'm doing the CTS turbo. Overall, everything went fine, just a few hiccups of how the hell do I get a tool there.
    Two minor adjustments to the DIY on the first page. The torx holding a bracket to the front of the engine right be the fan I was actually able to get a full length driver in there. I just had to slide it up into the fan housing rotate it, then into the screw so I could use it, that went pretty smooth.
    Also, the exhaust heat shield that is supposed to be one 6mm allen and two M9 or M8 was actually three 6mm allens.
    Got the new turbo in, just need to finish connecting up all the lines for it.
    Feb 13 2004
    Silicon Valley, CA
    ok, got it all together. Used option 2 for the first start up (run for a few seconds to pump oil and coolant then shut off and refill both). Restarted the car and it runs smooth, no code (P3 gauge), but lots of smoke. I don't see anything leaking, no puddles under the car or even drips. But lots of smoke. My guess is that when the coolant line came off the turbo and all that coolant came out, a lot went through the little "blanket" that wraps that line so its probably saturated and just needs to burn off.
