Originally Posted by
ddun
There are 2 holes for the coolant on the side, one should be plugged. Use whichever allows for easier installation should be able to thread it by hand. Also the plug needs a crush washer too.
If it doesn't look crushed it's Probly not seated all the way, you might be cross threading. Should be a crush washer on each side of the banjo bolt.
There's also another coolant line behind the turbo under the manifold, that one is installed when out of the car, check to see if that is dripping.
I only have a single coolant port for the lower coolant line, as I did an OEM swap. I got a great deal on an OEM turbo, and couldn't support all of the associated mods at this time to go KO4. I have become very comfortable with this process, due to the fact that I spent all of last Saturday following your 2 DIYs, only to re-do everything in about 5 hours on Sunday due to this leak, so maybe I'll go K04 after a tune and some time.
Referencing Mod.Kill.Yut's picture in post #53, it looked like coolant was dripping from the M8 bolt you can see on the oil return line in the picture when under the car, but clearly coolant doesn't run through that line, so it has to be the crush washers on the lower coolant line. I used new washers, but then never looked crushed. I ordered a new coolant line, new banjo bolt, and 4 new crush washers, but am waiting for these parts to arrive. I plan to try just the new crush washers first, because they are aluminum OEM, and not the copper aftermarket ones the ECS install kit provided.
I really can't thank you enough for this DIY. You saved me a ton of cash, and helped me tackle a job I wouldn't have dreamed of previously. I'll report back this weekend when I have all of this sorted out. In the meantime, I'm driving the family 8.5 allroad; could be worse.
