Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 308
  1. #161
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    I think all models require the oxygen sensors to be removed since they are mounted to the cat...
    Either way, good morning mate.
    Holden Ute, so Aussie.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
  2. #162
    Veteran Member Four Rings boomtime's Avatar
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    Quote Originally Posted by blbroo View Post
    Yes
    The eventual supremacy of reason.
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
  3. #163
    May 21 2015
    Nissan R32 GTR, Ducati 659
    Melbourne, Victoria, Australia
    yeah your are right cant see the cat coming out with the oxygen sensor on.
    We love utes so much, wouldn't consider selling mine if it wasn't manual. They get so tail happy.
  4. #164
    Veteran Member Three Rings jamesj2k's Avatar
    Feb 17 2008
    Ashland, KY
    Do you guys know if this DIY works on an Audi B8 S4?
    2019 SQ5, 2021 Q7
  5. #165
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by jamesj2k View Post
    Look at the DIY on the first page... you tell me. You have an S4, this is for an A4.
  6. #166
    Feb 17 2008
    Ashland, KY
    MOST A4 diy's are same if not similar to S4's. Yes, I can read.
    2019 SQ5, 2021 Q7
  7. #167
    Jan 15 2015
    UT
    For cosmetic things yes, but the exhaust systems on these two cars are entirely different. Removal of the converter out of the pipe should be similar but uninstalling the pipe is different.
  8. #168
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Are you drunk Andrew? After a while, they change color to that brown / copperish tone that the stock one has when you take it off. I am not sure they would notice my HFC but the spaced out O2 sensor is obvious. Luckily, the guy that just installed my muffler mentioned that he doesn't go looking for trouble if the ODB2 scans ok on inspections.
    I'm going to pretend I didn't make that post...
    Quote Originally Posted by adamazing View Post
    If it were to be an issue, I was thinking more along the lines of heat wrapping it.
    Dammit it got quoted twice...
    10-4 we're all clear. Nothing to see here people. Move on.
    My 2009 A4 Prem+ Build thread
  9. #169
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by trackbaron View Post
    This!
  10. #170
    Oct 26 2012
    St. Louis, MO
    B8 A4 DIY: Catalytic Converter Removal & HFC or Test Pipe Install
    I am pretty sure that there is no performance benefit of HFCs on the b8 S4. Never see it talked about up there and have seen some old poor reviews of the 034 product.
    The S4 forum is a much better place for the question than here.
    ^ I typed that with my thumbs! using tapatalk
  11. #171
    Jan 15 2015
    UT
    FINALLY get to use this diy! Been shopping for awhile now but finally pulled the trigger. Seems like end of the season gave way to some good discounts and I'm super pumped to get this bad boy on!
    http://www.audizine.com/gallery/data/500/testpipe2.jpg
  12. #172
    Jul 07 2012
    Boston, MA
    Anyone have a link to the mini cat spacer? I can't recall who made it but I have a feeling I'm going to need one for emissions.
  13. #173
    Jan 15 2015
    UT
    Quote Originally Posted by Lambda13 View Post
    +1 I'm on stock tune so I expect a cel without it. I'm guessing there are different sizes too.
  14. #174
    Oct 12 2015
    Orange County, CA
    thx for the write up!!!!
    my test pipe will be in any day!!!
    ANYONE FROM AZ with vcsd tool?? i need to code my headlights :)
  15. #175
    Established Member Two Rings heffer's Avatar
    Apr 22 2010
    Idaho
    FINALLY got mine installed! It freaking sucked! But honestly I expected it. I definitely hear the turbo more now. I noticed a decent amount of power gain on my first run with it, I had my brother in the car so I'll be able to tell better tomorrow. Regardless, thanks for the DIY but I'll never attempt this install again! I'm on a stock tune BTW.
    Oh I almost forgot. My car is smoking a good amount, PB blaster burning maybe?
    2009 A4 Quattro 2.0T Stock
    1999 1.8t/APR Stage 1/Supersprint Exhaust/APR R1 SOLD
  16. #176
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    Surprisingly, this was my only mod where I didn't have a single hiccup. Everything went smoothly.
    It took 175 miles for my CEL to come on due to test pipe. No spacers.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
  17. #177
    Jan 15 2015
    UT
    Quote Originally Posted by Townending View Post
    Surprisingly, this was my only mod where I a single hiccup. Everything went smoothly.
    What did you go with?
  18. #178
    Aug 29 2014
    Ebay test pipe. Only paid 60$.
    It's been on for 4k miles so far, full throttle up to 150+MPH, no issues at all.
  19. #179
    Established Member Two Rings lostkeyz's Avatar
    May 20 2013
    San Diego
    Are you still running a stock tune or using a spacer. I decided not to mess with the spacer anymore and go stage 2.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    2013 Audi A4 2.0 TFSI quattro Manual Sedan "never owned an automatic, man tran all day everyday"
  20. #180
    Aug 29 2014
    Quote Originally Posted by lostkeyz View Post
    I run Stage 2 on E85. My whole reasoning to get the ebay test pipe was to go from Stage 1 to Stage 2 as cheap as possible to hold me over until I'm ready for Stage 3.
    -Test pipe : $60
    -OEM Gaskets/Nuts : $20
    -Labor Fee for Stage 2 flash : $55
    Total Cost to go from Stage 1 to Stage 2 : $135
  21. #181
    Apr 22 2010
    Idaho
    I have the 034 spacer and threw a cel already....
  22. #182
    Aug 29 2014
    Quote Originally Posted by heffer View Post
    What's stopping you from getting a tune?
  23. #183
    Apr 22 2010
    Idaho
    lack of funds. I will at some point, but don't know when that will be.
  24. #184
    Established Member Two Rings Linksman72's Avatar
    Jun 23 2015
    Orland Park IL
    I just installed mine and noticed a lot of white smoke coming from the hfc area. I'm wondering too if it's the PB blaster burning off or something more serious
  25. #185
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    Quote Originally Posted by Linksman72 View Post
    Anything other than metal will burn off after 100 miles. The new ss pipe usually has a glaze from being made but also fingerprints and pb blaster will smoke too.
    If anyone else is interested im selling my 3" SS TP and SS downpipe section to remove the pretzel resonator after the flex joint shoot me a PM. $200 for both pieces. 034 and USP...
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
  26. #186
    Established Member Two Rings RW12's Avatar
    Dec 28 2015
    1997 Safari van, SV650 Superbike, YZ85 supermoto
    Vancouver
    I haven't installed a HFC, but from having done other exhaust work, I would suggest after you install the pipe, spray it down with brake clean. That will remove most of the oil and grease and minimize smoking.
    F*ck I love brake clean.
  27. #187
    Established Member Two Rings julianwh's Avatar
    Feb 09 2016
    2000 B5S4 Stage 3, 2006 S2000, 2000 Miata, 2015 F-150 XLT Ecoboost
    Austin, Texas
    Great write up, my mechanic friend and I were able to complete the install. That one bolt till about 15 mins to figure out and ended up getting it out with a short ratchet with the little space behind the engine. I'm very happy with the 034 & I feel like I have a new car. Sounds great and better pedal response. CEL came on almost immediately but I was expecting it. APR Stage 2 flash fixed it.
    2013 Allroad Premium Plus Glacier White/Grey, B&O, Sport Seats, APR Stage 2 2.2, 034 HFC, 275/35-19 on 19x9 S5 Peelers , Bilstein PSS-10 Coilovers, Power Stop Z23 Evolution Sport Rotors & Pads, Silver S Mirrors, Window & Sunroof Tint, JL-12" Sub, K&N Air Filter & Cabin Filter, Hoen H11 XenonMatch Fog Lights, Interior LEDs, Audi Projector Puddle Lights, Misc Vag Codes.
  28. #188
    Established Member Two Rings Zactastic's Avatar
    Mar 13 2016
    Martinez, Ca
    Should i disconnect the negative battery terminal or both + and - when doing this install? just curious if that helps for when i turn the car back on with the new cat to avoid CEL
    2010: 6 speed MT - 034 HFC + a few other parts my wife disagrees with :)
  29. #189
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by Zactastic View Post
    No, it won't help the CEL will eventually come on regardless, you have to go stage 2 from revo or apr.
  30. #190
    Mar 13 2016
    Martinez, Ca
    Quote Originally Posted by o1turbo30v View Post
    well, i do have a 90 degree spacer going in while i wait 2 more weeks for the RocEuro 45 degree spacer i have on back order. If i do get a CEL i guess ill have to go stage 2 :) If that's the case, when i do need to smog out here in CA, would i need to revert back to stock ECU? I am aware ill have to swap out the HFC for stock cat again at that point. the reason im hesitating going stage 2 is because of smog check. basically, would a stock cat with stage 2 be able to pass smog? I probably wouldnt want to drive it like that because of the stock cat restricting flow on stage 2 programing. please elaborate if you will, im clearing new at this
  31. #191
    Mar 13 2016
    Martinez, Ca
    Got it all hooked up except that "shock absorbing link assembly that connects the lower portion of the cat pipe to the engine" . it's at a slight angle, cant get the bolt threaded in there. anyone else have this issue and how did you resolve it? ill send a picture, right now it's attached to the cat only, no bolt in place.
  32. #192
    Mar 13 2016
    Martinez, Ca
    Here's where I can't get the right angle for the bolt to engage and thread
  33. #193
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Have you tried unbolting it from the cat, bolting it up to the transmission and then trying to thread it onto the cat instead? I believe that's what I did and didn't have any issues.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
  34. #194
    Mar 13 2016
    Martinez, Ca
    Quote Originally Posted by lettuce View Post
    I loosened it from the cat to give it more play... but ill try your suggestion. thanks man. time for a beer after that!!
  35. #195
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    ^^^figure that out and you can help me with mine when I go stage 2! I'm 5 miles away from you in Hercules 😬
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
  36. #196
    Mar 13 2016
    Martinez, Ca
    Quote Originally Posted by earhythmic View Post
    Nice man, ill be cleaning it up tomorrow morning and checking all the bolts again before i take her for a spin. This DIY thread really helps.
  37. #197
    Jun 23 2015
    Orland Park IL
    I had this same problem a couple weeks ago, unscrew the link and rotate or flip it so the spring is attached facing the opposite direction. Attach it on the other side of the cat. It fits perfectly this way.
    2010 Audi A5 Prestige 2.0t, Brilliant Black, APR Ko4, AWE Touring catback exhaust, AWE downpipe, 034 HFC, Kohlefaser Luft-Technik Intake System, Wagner competition intercooler, RS5 Grille, H&R Coilovers, Vorstiener vff 104 20x10, interior LED upgrade, 034 drivetrain mount inserts, Basslink subwoofer, VAG-COM mods
  38. #198
    Mar 13 2016
    Martinez, Ca
    I ended up unscrewing it off the cat, gave it a slight bend, and it fit nice and snug.
  39. #199
    Mar 13 2016
    Martinez, Ca
    Went for a spin, felt the added response and it sounds just bit deeper than stock. More noticeable in the sound when accelerating. I'm really happy with the 034 so far. Great DIY
  40. #200
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    I'm just gonna leave this here:
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
