Page 3 of 8 FirstFirst 12345 ... LastLast
Results 81 to 120 of 308
  1. #81
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Just torch the f**k out of those cat bolts. You wont hurt anything. I got them red hot then just spun them off very easily.
    2016 S3
    Instagram- @Thisisastickup
  2. #82
    Established Member Two Rings heffer's Avatar
    Apr 22 2010
    Idaho
    Quote Originally Posted by b6Hate4 View Post
    Do you start cranking the bolts while they're still red hot?
    2009 A4 Quattro 2.0T Stock
    1999 1.8t/APR Stage 1/Supersprint Exhaust/APR R1 SOLD
  3. #83
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    Quote Originally Posted by oascom View Post
    I was about do do it by myself... Got all the tools, Pb blaster etc... But then I called shop to ask how much they would charge me with tune together and they told me they will do it for 150+tune cost... I said fuck it for 150 it is wort it.
    Lucky me! Shop spend 4h to get that shi.. out. All 4 bolts were stuck and corroded. They had to cut all of them and drill.
    Still they charge me only 150 like they said before :)
    I'm curious. Did you take it to a muffler shop or a EuroTuning Shop. When you say $150 + tune, what tune are you referring to?
    Does anyone here see a problem with taking this job to a muffler shop? I would imagine they would charge much less than a eurotuner shop.
    Update. It turns out a muffler shop isn't the best choice for this job because the catalytic converter isn't directly underneath the car. I'm gonna take in to a tuning shop.
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
  4. #84
    Veteran Member Three Rings Spm58's Avatar
    Nov 03 2014
    Long beach, ny
    Does anyone know if the bolts going from the downpipe to the hfc are screwed in or how they're held in? I snapped one of them and tried getting banging it out but that didn't work, and the shops I asked want to change $100+ to drill it out
    2015 sepang blue s4• Ecs luft-technik carbon Intake
  5. #85
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    I think they are bolt and nut. I snapped one having a brain lapse on lefty loosey and replaced it with a both and nut I had in my garage.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
  6. #86
    Nov 03 2014
    Long beach, ny
    Did it just slide/ fall out? Or was it held in there. I'm thinking of picking up more on blaster and just coating it and hammering it if it's supposed to slide out
  7. #87
    Oct 26 2012
    St. Louis, MO
    I think I had to encourage it out a bit, but not much. Just go under the car and look at the other side of that connection. If you see a bolt head, it's not a stud.
  8. #88
    Feb 19 2014
    RVA
    Quote Originally Posted by Spm58 View Post
    I think the bolt/thread is welded to the midpipe. Just get some metal drill bits and drill it out. Replace with a new but/bolt.
  9. #89
    Aug 10 2011
    North Whittier
    On which hole does the oxygen sensor go?
  10. #90
    Oct 10 2012
    Zionsville and Saint John IN
    Quote Originally Posted by doowopaudi View Post
    two oxy sensors. one in the front and one in the rear.
    Also, I doubt that spacer will work to keep cel light from popping up if you don't get a tune. You might get lucky though.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
  11. #91
    Aug 10 2011
    North Whittier
    Shoot, I was supposed to buy two?
  12. #92
    Veteran Member Three Rings goreckless's Avatar
    Aug 17 2009
    Stamford, CT
    Quote Originally Posted by richardm0025 View Post
    Huh????
    You only need one spacer and it goes in the second one, post cat.
    2014 Audi A4 | 6MT | Brilliant Black | S-Line
    APR | AWE | Eurocode | CTS
  13. #93
    Oct 10 2012
    Oh, are you asking where does the oxygen sensor SPACER go? That would be the rear. You already have two oxygen sensors on the car. one will connect in front of the HFC and one will attach to the spacer which connects to the rear of the HFC.
  14. #94
    Aug 10 2011
    North Whittier
    Thank You gentlemen yes I meant spacer
  15. #95
    Aug 17 2009
    Stamford, CT
    Oh I see now, my bad. I knew he meant spacer but didn't see he actually wrote sensor.
  16. #96
    Oct 10 2012
    Quote Originally Posted by goreckless View Post
    No worries
  17. #97
    Oct 10 2012
    Are you planning on a tune? I have that spacer and before I got a tune a couple months after I installed my hfc. When near Chicago the light would come on and when I was in Indy the light turned off lol. Let me know how it works out with that spacer.
  18. #98
    Aug 10 2011
    North Whittier
    It was my bad.
    No worries
    Yes, I plan on going stage 2 in July, but I plan on installing the HFC in the next week. I'll let you know.
  19. #99
    Aug 15 2014
    so whats the point of installing the spacer when it seems like most people still get a CEL without the stage 2 tune?
    For Sale: Mini Part Out
  20. #100
    Oct 26 2012
    St. Louis, MO
    I have only popped a cel once with a spacer in 4 months
  21. #101
    Jan 15 2015
    UT
    Great write up! I'm looking at a primary cat-delete option. What's the difference between a test pipe and a downpipe? Is a test pipe just a catless downpipe? Can't seem to see the difference.
  22. #102
    Nov 03 2014
    Long beach, ny
    Test pipe is a hi flow cat with out the cat, so it's just a hollow tube. The down pipe is what it bolts on to. Turbo, hfc, dp, rest of exhaust
  23. #103
    Jan 15 2015
    UT
    Ok thanks for the clarification.
  24. #104
    Sep 09 2010
    Destin, FL
    I have a 90° spacer on my 034 HFC and I've never had a CEL or issue in the four years of having it.
  25. #105
    Aug 15 2014
    Quote Originally Posted by The Infiltrator View Post
    you also have a tune, no? i guess I'm wondering what the point is of getting the spacer when people are stage 2 anyways.
  26. #106
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Shimmy View Post
    Yeah I've been stage 2 since 2011 and when I installed the HFC back then everyone said to add the spacer so I did. Not sure if you need it now with the new tune but it doesn't hurt to have.
  27. #107
    Aug 10 2011
    North Whittier
    I think I'm gonna attempt this myself. I've called shops nearby and theyre all in the $150-180 range. May as well save that money for more mods right?
    How many of you guys who did this yourself wish you would have had a shop do it instead?
  28. #108
    Nov 03 2014
    Long beach, ny
    Doowopaudi it's a pain in the Ass. And that's an understatement. Make sure you have extensions for your ratchet and you'll probably want a breaker bar and I also suggest a ratcheting wrench, it works very well. I believe it's a 15 mm
  29. #109
    Aug 10 2011
    North Whittier
    Looks like I'll be taking a trip to Harbor freight for some tool shopping!
  30. #110
    Jan 15 2015
    UT
    I was really pumped for this mod cause it's super inexpensive, but now the install has me second guessing. Anyone get a quote on the install from a shop? I'm going to get one tomorrow, hoping to compare it to something.
  31. #111
    Sep 09 2010
    Destin, FL
    It's not that bad if it's on a lift and you have the right tools.
  32. #112
    Veteran Member Four Rings boomtime's Avatar
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    Quote Originally Posted by trackbaron View Post
    If your second guessing it then pay the shop $180, its not for a first time mechanic but its also not that hard. The real danger is rounding off the turbo flange nuts or snapping a stud.
    If $180 is too expensive then sell your Audi.
    I only work with cars on my buddy's lift, at his shop with 20 years of accumulated tools.
    When I was 20 years old I did everything on ramps or jack stands...and complained about having to buy a $5 socket to use once for that job...
    The eventual supremacy of reason.
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
  33. #113
    Aug 10 2011
    North Whittier
    Quote Originally Posted by boomtime View Post
    You're right, im gonna put it up for sale. Phew!
  34. #114
    Veteran Member Three Rings S-Liner's Avatar
    Oct 21 2014
    Illinois
    LOL
    Nothing on these cars is difficult to R2...all you got to have is the patience, tools, and the desire to learn.
    Anyone can disassemble shit, but taking it apart correctly is just as important as putting it back in.
    Good luck, dude.
    Sent from my iPhone 6+Trillion using Tapatalk
    '10 A4 Avant Prestige Plus S-Line w/sport pkg
    My Oil consumption results..."Oil consumption measurement found to be using 3.26 quarts per 1000 miles"
  35. #115
    Veteran Member Three Rings Fburg A4's Avatar
    Oct 06 2012
    Fredericksburg, VA
    Do it man, don't be scared! On the diy scale this ranks pretty meh. But I think it depends on your resources. If you don't have a lot of tools (or experience) you may find yourself having some issues. Then there is the "uh oh" factor if something bad happens. Like somebody mentioned rounding off a bolt, do you have the tools to address that? Given that you are working on exhaust bolts, there is more of a chance of fastener issues than with other tasks. I've probably removed my cat like 10 times by now and never had a problem, but others have had uh oh moments.
    But I am in the save your money camp with this task. My suggestion is that if you get a frozen bolt or are unsure what to do, just put things back together and don't force the issue.
  36. #116
    Veteran Member Three Rings Nastybutler's Avatar
    Apr 07 2014
    2010 C6 A6 (Wife's); 2012 Triumph Street Triple R (Phantom Black)
    United States
    So when I flash it back to stock so it doesn't get TD1'd when I take it into the dealer for service it's not throwing a code.
    For Sale: 2014 A5 2.0T (Scuba Blue) | APR Stage 2 v2.0 | 8spd Tiptronic | MMI 3G+ w/Nav | Advanced Key | B&O (w/ upgraded sub) | park assist | heated memory seats & mirrors |
    1/4 Mile: 13.39 @ 100.74 mph on fake 93 octane (90 + Lucas booster)
    Mods can be found in my Build Thread
  37. #117
    Aug 10 2011
    North Whittier
    Quote Originally Posted by Fburg A4 View Post
    Of course I'm gonna try it. $180 to remove 7 bolts, plus a diy thread??? This is a no brainer !
    But yeah, if i get stuck, eveything goes back and I'll happily pay the shop
  38. #118
    Veteran Member Four Rings Marko S's Avatar
    Mar 03 2015
    Hey guy, I have a question that I couldn't find any answers too.
    Im thinking about getting the 034 hfc with the O2 spacer. Was planning on running it on the stock exhaust with no tune. Is this even possible? Everywhere I've read people put the hfc after the tune and thats stage 2 i guess.
  39. #119
    Aug 10 2011
    North Whittier
    Quote Originally Posted by Marko S View Post
    Yes it's possible. You'll get like 10-15hp
  40. #120
    Mar 03 2015
    Thanks man.
    On another note does anyone here in ontario have any problems with hfcs and emissions? Another question i cant find an answer to
    Current: 2019 Audi A4 Allroad Technik
    Past: 2011 Audi A4 Prem+ Stage 2+
