Originally Posted by
A4 Quattro
If you run coilovers, you can slam it in the summer and jack it back up to skyscraper for the winter.
The highest any coilovers I've seen for the A6 will go is the same height at the OEM sport suspension. I scrape over some driveways and speed humps at Sport suspension height, coils will not fulfill what the OP wants if he wants to maintain the stock ride height. Besides, as the others have mentioned, upgraded sways will make a MUCH bigger difference in overall handling feel.
Teflon_synapses
Would upgrading to the S6 sway bars be worth it? Or would the difference be negligible, and I should just get hotchkis?
Just go with the Hotchkis H-Sports. They are thicker and much lighter than the S6/Sport sways. The closest suspension upgrade I was able to come to stock height was an Eibach Pro Kit/Koni Yellow combo. That lowered the car by 30mm from stock non-sport height. I still have about a 2 finger gap in the wheel well and have never had an issue in deep snow. The drivablity improvement from stock sways with (worn) OEM dampers and springs to the H-Sport/Eibach/Koni combo was unbelievable. Basically it's OEM Sport+.
Bilstein HD's will also work with your stock springs and that would allow you to keep your current ride height. The downside is the Bilsteins and reputed to have a much harsher ride than the Koni's, which is the main reason I didn't go that route.
