Page 635 of 635 FirstFirst ... 135535585625633634635
Results 25,361 to 25,396 of 25396
  1. #25361
    Senior Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    Quote Originally Posted by Shaun543 View Post
    Swapped original std interior of my 13 A4 with S4 suede seats. Put on 20Ē A8 wheels (245/35r20).
  2. #25362
    Registered Member Four Rings kingofnyc's Avatar
    Jul 01 2007
    Queens, NY
    Quote Originally Posted by Poodini View Post
    Nice. How are you liking them? Any appreciable improvement compared to stock?
    Very minor improvements. Slightly more consistent pedal feel.
    Had to do my rear brakes anyway. Took a while to source all the parts. Did not want to pay $500+ for small improvements.
  3. #25363
    Veteran Member Three Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Rear main seal arrived, and installed. Engine goes back in tomorrow.IMG_4365.JPG
  4. #25364
    Oct 26 2015
    Fremont, NorCal
    What did you do to your B8 today?
    Quote Originally Posted by a4lownslow View Post
    Just got the reseal kit as well. Praying thatíll take care of at least THAT leak..
    Man, this Fín PCV diaphragm blowing on me and the ensuing carnage on my rig has been nothing short of Hell! You think youíve isolated the culprit re vacuum leak/ engine running lean in simply replacing the diaphragm, nope. Oh look at that puddle of oil on the floor, ooh, look at all that splashed along the bottom of the undercarriage too! Installed the iABED RMS kit, we good now right?..NO SIR. Looks like your vacuum pump as well as your valve cover are leaking as well as that ongoing one near the turbo compressor. That P2015 re intake manifold solenoid is usually the signal to replace that also. Did I mention Your fuel line may have been affected as well so best you replace that while your at it, donít forget any hoses that are suspect...oh, almost forgot, your oil drain pan...🤬 omfg!!
    I took it to my local Audi guy since the dealership wanted nothing to do with it given all the mods. Gave him the rundown, basically told him to just stop the bleeding so that Iím not s rolling fire hazzard! Had it all day. He then texted after 4:30 to come get it. Asked what he saw/fixed, DEAD SILENCE...
    Let us pray
  5. #25365
    Registered Member Three Rings Nano909's Avatar
    Jul 25 2016
    California
    Let us pray
    Well?
  6. #25366
    Established Member Two Rings rolandoa1324's Avatar
    Jan 28 2016
    Orange CA
    Kida late but last weekend I took my car to test out a new exhaust set up.IMG_0058.JPGIMG_0059.jpg straight pipe all the way back to s4 mufflers. A little bit of drone but Iím planning on messing with it still and going to shop that actually welds good.
    Instagram @cavesb8
  7. #25367
    Established Member Two Rings J_PapaPapa's Avatar
    Jun 08 2013
    2012 S4, 2004 S4, 03 GSXR 750
    New Franklin, OH
    Poodini, Bro that sounds like a rough time! Just one thing after another. I know how that goes for sure, I feel ya brother. Sounds like you found yourself a bombass mechanic tho! Let us know how everything's running after driving it a bit.
    So what I did today to get it prepped for my sub install. I actually just bought this car on Saturday, I had to drive down to Virginia to pick it up. It's a bone stock 2012 S4 Premium Plus. It was a 5.5 hour drive back. I wasn't in the door 20 min before buying parts First thing I bought was the JHM short shifter. After having it in my B6 S4, driving the new one back was like shifting with a brookstick stuck in a potato. I had to swap that nonsense out. So I should have that in by the end of the week. And tomorrow I'm throwing in the amp and the sub that I pulled out of the other S4. Kinda excited. The whole reason I bought this one was because my other one has been in the shop for 2 months. I've been riding my motorcycle as my daily the whole time. It gets to be annoying after a while believe me lol So I found this one at a price I could afford couldn't let it get by me. The color I wanted and everything.
    2004 S4| H&R sport coils| custom 2.5" straight pipe catback| Avant Garde M310's, 19x8.5 et 35| Hankook V12, 225/35/19| Apikol snub mount| CF wrapped interior trim| JHM short shifter | Ashiko shift knob| Sony 701HD deck| Powerbass tweeters| Rockford 10" T1 | Earthquake 2000W amp
  8. #25368
    Established Member Two Rings Tineo's Avatar
    Jul 08 2013
    Dairy Land, Asturias. Spain
    Took my steering wheel off to inspect the G85 steering angle sensor and clock spring. I have been getting a G85 steering angle implausible signal everytime I start the car. I have cleared it many times, re-calibrated the sensor with VCDS. but it keeps coming back.
    Does anyone know what a bad clock spring would look like? Please PM me.
    This has been making a slight squeaking sound for over a year now but this was the first time I inspected. I found grease outside of where it should be, even a little was on the back of the steering wheel.
    Your g85 is at the back if the module, i have changed the complete piece (ebay item: clockspring+arms+g85) due to g85 internal failure.
    2008 A4 B8 3.0tdi Quattro Sedan 6MT EuroSpecs
    Ibisweiss | TLR remap to 301hp | S-Line interior | Rotor 19" rims | S4 front and rear brakes | RoadRover gps | Depo taillight LEDs | 80mm exhaust tips | S4 blackgloss grill with blackgloss valence | S4 pedals | fulldynamic LED turn signals ...and more
  9. #25369
    Established Member Two Rings B8Brit's Avatar
    Sep 27 2016
    NE Ohio
    Well...Iíve blown my last coil pack. Going in tonight for a new intake manifold. FML
    2011 Audi A4 2.0T Quattro Auto
    IE Stage 2 tune, CTS high flow cat, EC inlet pipe and AFE dry filter, Neuspeed springs and KYB sport shocks, slotted rotors w/ SS lines, RS4 grille with CF wrapped badge.
  10. #25370
    Established Member Three Rings Steelerhater37's Avatar
    May 29 2017
    BMW E36(98)M3 convertible//VW B6(07)Passat
    Bel Air Maryland USA
    Still... canít believe we donít see. Waiting. Drool
  11. #25371
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    E46 325ci
    CA/NV
    245's!! Jesus I'm running 275 35w on my 20s no rub and very nice ride
    Sent from my SM-G935T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 2.0t Ibis white/black
    AKA: A4QuattroV6
  12. #25372
    Aug 17 2015
    Michigan/Ontario
    Quote Originally Posted by Audi 4 Life View Post
    You all just wait until your wheel bearings start to object to these setups...
  13. #25373
    Aug 01 2016
    Pewaukee, WI
    Except the RS5 has low offset 20x9 wheels with 275/30 tires and the same wheel bearings...
    Daily Driver: 2013 Allroad Premium Plus (OEM+ Build Thread)
    Summer/Fun Car: 2005 Jetta GLI (OEM+ Build Thread)
  14. #25374
    Jun 05 2009
    Ducati Panigale 1199S (Red of course)
    Denver Colorado
    ^Yup wheel bearings seem to be the same across multiple platforms.
    Black B8 A4 Avant S-Line Prestige Package, CPMB Engine, Tiptronic 8 speed, JHM K04-R, V1 & Beltronics, Eurocode HFC, APR FMIC, Alu Kreuz, Vogtland Coilovers, Stoptech 380mm BB Kit, H&R Swaybar, APR K04 Tune, Rev. "d" DV, R8 Coils, Folding Mirrors, S5 Rear Brakes, 034 Street Density Mounts, OEM Facelift LED Brake lights, Forgestar CF5, and more mods to come!
  15. #25375
    Aug 17 2015
    Michigan/Ontario
    Quote Originally Posted by A4 Centaur View Post
    Yea, crazy they can use the same wheel bearing on the RS5. I know it is also used on the S4, S5, and A6.
    I have one failure at 85k miles.
  16. #25376
    Jun 05 2009
    Denver Colorado
    ^ I put S5 half-shafts and Timken S5 bearings on the front end a few years ago.
  17. #25377
    Jan 16 2011
    E46 325ci
    CA/NV
    Got my ceramic kit finally from Adam's.....
    Cant wait to detail the car after I get it back. I finally have a full kit after slowly pricing together full Adam's kit mixed in with few better items like leatherique, forever black, and simichrome metal polish to make kit better as a whole. The rest is all Adam's products tho which I've been happy with.
    Also got their paint correction kit with color matched pads to make it easy for newbs polishing and paint correecting.
    AKA: A4QuattroV6
  18. #25378
    Veteran Member Four Rings if6ws9's Avatar
    Feb 08 2012
    Grand Cherokee
    Palm Harbor, Fl
    Powder coated brakes Crimson Candy Step 2
    2014 A5, Brilliant Black, Black Optics, Sport package, MMI+, B&O, AWE Touring w/Black Diamond Tips, AWE DP, USP HFC, CTS CAI, APR Stage 2, ST Coilovers, Alu Kruez, 034 TX insert, ECS diff bushing, Apikol blue diff mount, VAG's, Escort Redline, ZR4 shifters, 20% tint, Sprint Booster, ECS dipstick, FB steering wheel, piston diverter valve, ECS rear lower control arm brace, 10mm & 12mm spacers, BFI shift knob, CR 15, powder coated calipers, extended paddles
  19. #25379
    Established Member Two Rings vincent_nguyen2's Avatar
    Oct 05 2016
    Fort Worth, Texas
    Installed my ecstuning deck lid. Apparently no rush shipping means 2 day shipping, but Iím not complaining. No damages or scratches and looks good, but not as much from the side oh well
    2014 Brilliant Red A4 Premium + w/ S-Line
    VAG-COM | Hoen H8 35w xenonmatch | RS Style Honeycomb Grill | Deval CF Rear Diffuser | AWE Tuning Quadtip Catback Exhaust | Niche Misano 19x8.5 | Solowerks S1 Coilovers | EBC Slotted Rotors | APR Downpipe | APR Stage 2 Tune | SPC Adjustable Control Arms | Michelin PS4S 255/35/19 | ECS Tuning CF Front Lip | Strafedesign Side Skirts | Animated Illuminated Door Sills | ECStuning CF Decklid
  20. #25380
    Senior Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by vincent_nguyen2 View Post
    man that looks sick!
    i just ordered those diffusers from their scratch and dent inventory. f man i dont wanna spend anymore money this year but that decklid sure looks fn great!
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
  21. #25381
    Established Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    ^ I agree. Lookin' good!
    I'm as cool as a cucumber in a bowl of hot sauce.
  22. #25382
    Oct 05 2016
    Fort Worth, Texas
    Quote Originally Posted by JeriQo View Post
    Thanks! Overall I like the Deval diffuser over ECS's and luckily the decklid was on sale when I randomly checked on it
    Quote Originally Posted by BeerBrent View Post
    Thank you to you too!
  23. #25383
    Apr 26 2014
    San Diego, CA
    Agreed x2.
    I also have the ECS wing and I absolutely love it.
    build / instagram / flickr
  24. #25384
    Oct 05 2016
    Fort Worth, Texas
    Quote Originally Posted by adamazing View Post
    Agreed x2.
    How do you feel about the side profile though? It doesn't look as great to me. I think if it was extended inward a little bit or flowed into the trunk better then it'd be completely perfect
  25. #25385
    Apr 26 2014
    San Diego, CA
    I like it. I used to have the Caractere-rep CF lip, so that's what I have to compare it against. I thought the profile of that trunk lip was pretty bad.
  26. #25386
    Oct 05 2016
    Fort Worth, Texas
    I also was able to completely finish the illuminated door sills this past Tuesday. All 4 of my door sills and footwells are working and the wires are tucked nicely. Video isnít great and theyíre fairly bright, but Iím sure youíll get the gist of it.
  27. #25387
    Jul 08 2015
    ok link to this please dammit lol
  28. #25388
    Oct 05 2016
    Fort Worth, Texas
    Lol didn't take much convincing. I bought mine off of eBay. The exact seller I bought mine from don't have any more, but if you search Audi A4 LED door sill, you'll find a couple listings on there. They all look the same as mine, but I can't tell you if they're exact
    That is true. The Caractere has its angles, but side profile does look worse
  29. #25389
    Oct 10 2016
    Madrid, Spain
    good job!!!
    Sent from my SM-G965F using Tapatalk
  30. #25390
    Registered Member Four Rings AUDIMAN33's Avatar
    Jan 11 2014
    2014 Audi A4, Porsche Cayenne S, Mercedes Benz S430 4matic
    New York
    I never think spoilers look good from the side on the B8 something about the way it sticks on top. Donít flow to well. But itís something we gotta live with
  31. #25391
    Jan 16 2011
    E46 325ci
    CA/NV
    Got some parts in the mail thanks to Fordperfect my carbon cleaning adapters, and picked up my rear brakes that I beyond rebuilt to new. New actuators, bolts, powder coat, etc for my unicorn stasis B8 330 rear kit which was never released that I am lucky to have so I dont look funny with bbk front and non matching oem rear.
    And here they are next to the fronts still much smaller but at least they match. And keep the bias proper for better handling.
    AKA: A4QuattroV6
  32. #25392
    Oct 23 2014
    '77 MGB Roadster
    Buffalo, NY
    Replaced my battery with a new Bosch AGM and updated the VCDS coding.
    Then I tried to adjust my ECS charge pipes to free up some space between the turbo outlet and the support bracket below, but I sheared the t bolt clamp with little effort. Actually, this is the second ECS provided t bolt clamp that has broken; the one from today has been on the car for just about a year, the first broke the day I installed the IC. They all be replaced in the spring, but Iím thankful to be able to get the car back together with a worm hose clamp from Home Depot for $1.25.
    2011 A4 P+ QGM | Sport Package | 6MT | MMI | B&O
    GIAC (stage) | Eurocode HFC & Alu Kreuz | Stasis Exhaust | H&R RSB | DV+ | CR-15 | ECS Intercooler w/ Piping & Street Shield | P3
    the egyptian prescription
  33. #25393
    Nov 20 2016
    Quote Originally Posted by bakedziti View Post
    How much torque are you putting on them? lol
  34. #25394
    Oct 23 2014
    '77 MGB Roadster
    Buffalo, NY
    Hahaha. I canít recall what they were at when I installed the IC, but it could have been too much. Hereís what they looked like yesterday, itís pretty clear which one broke day one and which one broke yesterday with my WNY winters.
  35. #25395
    Senior Member Four Rings 14S4GWM's Avatar
    Mar 21 2015
    Yeah those clamps suck, awe used to send those with their exhaust tips. Theres definitely better out there.
    2014 S4 P+ Glacier White DSG EPL Stage 2/TCU
    Black Optic/ B&O/ Sports Diff/ Carbon Atlas/ V1/ P3/ Carista/ ECS CF Intake/ ECS CF Diffuser/ Bilstein B8/ H&R OE Springs/ H&R 10-12mm Spacers
    C-Quartz/ Suntek PPF/ AWE Touring 102/ 034 X-Brace & Inserts/ Eurocode Sways/ Akebono Pads/ CR-15/ VLED VX3 LED Fogs
  36. #25396
    Feb 08 2012
    Grand Cherokee
    Palm Harbor, Fl
    Installed paddle extensions
