I have an a4 2004 that I can no longer open the trunk lid from either the trunk button on the door, or from the remote (note: remote does not work for anything else either). I can however open it with the key in the trunk lock. Whenever you open it with the key you can hear the actuator noise, (I assume that's normal?) However you cannot hear this noise when pressing the button on the door, or the remote.
After reading various diagnostic info I removed the actuator, and tested out of the car by connecting it to a 12 power source...it works fine.
My next thought was a broken wire/bad connection, however I doubt this since the actuator makes a noise when opening with the key. So at least that wire must be good.
My conclusion is that the computer is not telling the actuator to run...what could cause this? I can borrow Vagcom from a friend if it would help at all.
