Results 1 to 40 of 46
Hybrid View
    Veteran Member Three Rings b6a41.8tbagg's Avatar
    Oct 07 2010
    Nashville
    b6 a4 cluster with s4 needles and face plate install
    I recently acquired an 05 b6 s4 cluster and swapped the needles and face plate im not sure how to set the needles they all seem fine besides the rpm sits a little lower than it should how would i go about setting the needles back to normal do i take it off and re position or would i be able to turn the needle counter clockwise til it stops and than set it on the mark any help would be greatly appreciated,thanks [IMG][/IMG]
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    remove the needle and put it higher..
    usually if you doing yourself I recommend taking photos of the needle position before you remove them, this way at least you can match to your original ..
    Oct 07 2010
    Nashville
    Quote Originally Posted by audifirst View Post
    yeah i took pics i put the needles on there marks when i turned the key over the rpm needle dropped just a little below the the last line,i havent fired it up yet to see where it moves. ill have to take it apart and re position that needle thanks
    Veteran Member Three Rings chad99's Avatar
    Apr 21 2012
    Fremont, CA
    Quote Originally Posted by b6a41.8tbagg View Post
    Did you find a s4 with Red needles?....also any reason why you didn't want the color dic?
    Jun 08 2008
    Calgary AB Canada
    Color display wont drop in. You have to swap the whole cluster for that
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Apr 21 2012
    Fremont, CA
    Quote Originally Posted by onceover View Post
    I meant why didn't he just swap in the whole cluster instead of just the faces...but then again it might not work since hi car is listed as 2003
    Oct 07 2010
    Nashville
    thanks for the replys im not sure if i would be able to swap the whole cluster my car is an 03 with a build date of sept 02 ive heard the color dis is compatible with 02 for some reason.yeah the needles do look a little pink just slightly they look crisper it looks really good though i was still wanting to maintain the red needles on white backlighting,ill have to do the output tests on vagcom to calibrate there positions.i have a color dis laying around if anyone wants it pm me
    Sep 16 2010
    Central Wash
    I have the same car, same build month. Once you get the SKC to do the adaptation it should install just fine- there ARE a couple versions of the S4 cluster, but good odds it would install just fine.
    P.S. I need ONE white fuel / temp gauge needle! One of mine broke..... so I'm running RED needles on an S4 cluster..which, isn't so bad I guess.
    Oct 07 2010
    Nashville
    thanks for the info much appreciated next time im at the yard i can look for a broken cluster and grab a set of needles for ya ill let you know add me ill pm ya
    Quote Originally Posted by rollerton View Post
    Jul 14 2009
    Pasadena
    i have a s4 cluster for sale :]
    OP why didnt u just put the whole s4 cluster in?
    IG: @matthewee
    Jun 30 2008
    Erie, Pennsylvania
    The way to calibrate these properly is to use vag-com "output test mode". It will put both needles at a certain position. I believe it puts them to 3k RPM and 100 KPH (62 MPH). Obviously you could care less if they are perfectly accurate at '0'. What you want is for the speedo/tach to be accurate within their normal operating range. The guys that rebuild clusters will hook them up and do this test before they put them back together so they get the needles set properly.
    Example:
    Oct 07 2010
    Nashville
    Example:
    thank you for this much appreciated
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    What's the benefit of this? Just to get the S4 badge on your A4? Different fonts?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Account Terminated Four Rings
    Oct 26 2009
    Beaver Creek, CO
    Quote Originally Posted by kwimberly View Post
    I'm wondering the same. Only difference I'm noticing is the S4 badge. What am I missing?
    Oct 07 2010
    Nashville
    Quote Originally Posted by Greedo View Post
    just a few things nothing major the s4 badge being one the rpm starts at 0 and goes to 8k the 2 lines after 160mph i just wanted the grey face plates and white needles mostly it looks sick in the daytime
    Dec 03 2005
    2 pedals 1FG
    connecticut
    That is the most ridiculous reason for a mod I've read. All that effort for what? To keep the red DIS still (which sucks moose cock), grey face plates (which are meh) and face plates that say "S4" which from a badging standpoint is 'Poser'.
    The colour DIS is what you want (my '02 has that and its fucking awesome). But then again what do I know? My views on mods to these cars are not really inline with the industry and general public.
    -Doug
    Oct 07 2010
    Nashville
    [QUOTE=dougyfresh;7886955]That is the most ridiculous reason for a mod I've read. All that effort for what? To keep the red DIS still (which sucks moose cock), grey face plates (which are meh) and face plates that say "S4" which from a badging standpoint is 'Poser'.
    The colour DIS is what you want (my '02 has that and its fucking awesome). But then again what do I know? My views on mods to these cars are not really inline with the industry and general public.[/QUOTE
    well its my car i enjoy adding s4 interior parts they are made to a higher standard than regular a4 not so meh! but more fuck yeah in my opinion if you think that thats poser cool we all have our opinions ill probably be more of a poser next week when i put the entire s4 cluster in an s4 tiptronic steering wheel with paddle shifters s4 recaro seats and porsche boxster front calipers..ill be getting my pose on.
    Sep 16 2010
    Central Wash
    When I do mine I plug the cluster into the car with the needles removed, turn the key on and install the needles at the bottom stop or " 0 " . Or run the VCDS output test and set them that way. If you just lightly set the needles you CAN turn them CCW to get them right, then push them on fully.
    So-- O.P; You just installed the white needles and S4 gauge faces on your A4 cluster? Doesn't it look kind of funny? The S4 back-lighting is WHITE as opposed to the A4's RED. So, when you do this doesn't it make the needles kind of a dim pink color? Also the cutout for the center display is just barely larger...so the screen doesn't look right (to me) this way.
    Apr 21 2012
    Fremont, CA
    Haha stupid flakey internet connection at airports
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by chad99 View Post
    Really?
    Stock. For now...
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    He probably found an S4 cluster on ebay for cheap that didn't work and used it for parts. I saw one not that long ago for like $40.
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Oct 07 2010
    Nashville
    Quote Originally Posted by GTRchop88 View Post
    no i got out an audi salvage yard i baught 2 of them for $100 not bad
    Apr 21 2012
    Fremont, CA
    Currious which salvage yard... are they in the bay area?...or up by sac
    Oct 07 2010
    Nashville
    sacramento pm me ill let you know the spot
    Aug 22 2004
    I was close. Pm me if you wanna sell your other S4 cluster so i can throw it in my car. I have an 05 that I put 152k miles on so i think it should work.
    USP CLUB MEMBER #7
    Oct 07 2010
    Nashville
    nice..if the front screen wasnt cracked i would sell you it not sure of mileage on it,next time im down that way i can grab a few more in really good condition depending on price and see if you still want one add me and ill pm you when i pick some more s4 stuff up should be that way in less than 2 weeks
    Aug 22 2004
    sounds good.
    USP CLUB MEMBER #7
    Oct 07 2010
    Nashville
    another pic or just more ridiculousness [IMG][/IMG]
    Aug 26 2005
    Sorry, I still don't understand why you wanted to do this, the modified cluster still looks the same as the original A4 cluster to me.
    Vorsprung durch Technik
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    This is so ridiculous. First of all the S4 cluster goes to 170 mph. Since the dial is symmetric your speed is now incorrect. You will actually be driving faster than your speedometer tells you. You have to mod the cluster eeprom for the needles to match the S4 readout. Following what everyone else has said the reason to get the S4 cluster is for the color DIS. So Doug's poser comment was spot on and it was meant to "sting". Swapping the S4 backing only is the equivalent to just slapping an S4 badge on the trunk. You are correct, you do not own an S4. I'm not saying you shouldn't swap on some parts but there are ways to do it without being tacky. What you have done here is tacky and frankly embarrassing. Good luck with the rest of your modding.
    Oct 07 2010
    Nashville
    Quote Originally Posted by Kittrell View Post
    embarrassing go fuck your self, good luck with the rest of your day
    Oct 07 2010
    Nashville
    i didnt mean that if you see me on the streets u have my permission to punch me in the stomach good day
    Apr 21 2012
    Fremont, CA
    I agree what he did was a lot of work for not much payout BUT I also agree that the font on the S4 face is nicer than the stock faces; its a minor change and honestly I didn't notice the difference till I looked at both gauges side by side
    Jul 14 2009
    Pasadena
    lol this got funny. incase anyone else wants to pretend they have an s4 they can buy my s4 cluster hahah
    IG: @matthewee
    Oct 07 2010
    Nashville
    hahahahahahahahahah your cute heheheheheh
    Quote Originally Posted by itsmatt33 View Post
    Oct 07 2010
    Nashville
    [IMG][/IMG] so its off how would i correct this through the eeprom if possible can i just get another S4 cluster and do the adaptations to get it to work
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    So it's off, how would I correct this through the eeprom? Is it possible to just get another S4 cluster and do the adaptations to get it to work?
    Modding the cluster eeprom takes specialized $1,000 software. If you contact mpower on the board he can do the modification for a reasonable price, but it will require shipping him your cluster.
    Veteran Member Four Rings daihashi's Avatar
    Apr 03 2010
    houston, tx
    Is it color?
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by daihashi View Post
    Is it color?
    all S4 clusters are
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    MPOWER did the color DIS mod for me last year. He had a cluster that worked in my 03 A4, and I flipped him a color DIS I had that would not work in my model that I had purchased off ebay. Makes the RNS-E much more functional. Great guy, nice to meet him. He's in the Chicago area and will meet up with you in person.
