Quote Originally Posted by KR_A4 View Post
Since you've now got new tie rods and tires, and you're going lower with coilovers. I would recommend adjustable upper control arms all around, but at a minimum up front. This will dial in your alignment and make your tires last.
I was 23.5"-24.5" fender to ground for 6 years depending on wheel setup, and never had a set of tires last longer than 6 months because of bad camber. Did 034 upper arms all around and now at factory spec'd alignment.
Control arms are just standard oem ones with good life still in them, I am getting my custom alignment from Imola motorsports www.Imolamotorsports.com check them out, they are a high class shop, I don't think I will have any problems
