Results 1 to 33 of 33
    Feb 23 2010
    Emmaus Pa
    not hitting requested boost.
    Lately I have not been able to get up to requested boost. I see about 18-19 psi in 2nd and 20 psi in the upper gears. I should be seeing 22-23 psi. Boost also comes on slower than it should. Pressure tested, no leaks. Dvs held vacuum fine, so I'm thinking its a bad n75. I Usually don't have my s4 at school, but my old man took out a family of deer so I gave him my mighty 12v 2.8 until his is fixed. Of course now that I'm 200 miles from home its acting up. I have a buddy here with an s4 but his n75 is bad, so I can't swap it out. ECUX refuses to log with my ecu and I don't know anyone here with vcds. But does this sound like an n75 issue? Boost doesn't fluctuate, it just holds too low of pressure. And if anyone is in the state college pa area and wants to lend me their n75 for an hour that would be awesome.
    TIA
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    sounds plausible.. I started to have similar issues yesterday... I'm also thinking it's the N75
    Feb 23 2010
    Emmaus Pa
    Yea idk what else it would be. I just want my boost back
    B9 S4- EPL/AWE
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Hmm that sucks. I'm actually from state college but at school in Bethlehem sorry.
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by MileMan402 View Post
    I live 500 feet from Bethlehem (palmer township) but in school in state college
    B9 S4- EPL/AWE
    Mar 14 2012
    PHL | BOS | SEA
    Haha small world.
    2014 S6 - SOLD
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    pm'd
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Three Rings DanS4's Avatar
    Oct 03 2008
    01.5 Audi S4, 00 golf Tdi
    Reading, PA
    TIA
    log. check the sticky
    SOLD Silver 01.5 S4 ; VAST tuned k04s, piggies, ASP exhaust, FMIC, Tracksports, DTS, ...
    http://www.socals4.com/
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    I have a spare n75 and vagcom but am in central nj
    Sep 03 2007
    Wichita, KS
    I had similar issues and here is the cause of mine: http://www.audizine.com/forum/showth...=turbo+failure
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by jerodmetcalf View Post
    I found the issue of the boost coming on slow (ic coupler was crimped) so I doubt this is my problem. Boost comes on fine now, and the car still feels strong, its just 1 or 2 psi short of what it should be boosting
    B9 S4- EPL/AWE
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by DanS4 View Post
    ecux will not work with my car and that is currently all I have access to. 3 different people and 3 different laptops including josh from jfonz could not get it to connect.
    edit: Didn't see the new sticky. Ignore^^
    B9 S4- EPL/AWE
    Jan 11 2007
    Salt Lake City, Utah
    If I was a betting man, I'd be willing to wager that you didn't read the sticky Why is ECUx all you currently have access to, no internet connection to download MELogger?
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by jibberjive View Post
    you would have won that bet. I didn't notice that there was a new sticky. I'll be downloading it in the morning.
    Thanks and good write up
    B9 S4- EPL/AWE
    Feb 23 2010
    Emmaus Pa
    Still having this issue. Haven't been driving the car much so I put it on the back burner. But today I threw a pressure control negative deviation code. Car has no leaks and runs strong besides being about 2 psi under what it should be. I'm thinking n75? it still has the factory clamps so I am guessing it has never been replaced.
    B9 S4- EPL/AWE
    Feb 06 2012
    Lake Lanier, GA
    Home depot made pressure tester will probably help
    Feb 23 2010
    Emmaus Pa
    B9 S4- EPL/AWE
    Jan 25 2006
    A4 2.0T
    MD
    Put an ohm meter on the n75 pins and report back what it read.
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by Don Supreme View Post
    I'm swapping n75s with a buddy in the AM. If that doesn't do it I will look into wastegate issues.
    B9 S4- EPL/AWE
    Jan 25 2006
    A4 2.0T
    MD
    perfect!
    Veteran Member Four Rings Trigger Happy's Avatar
    Jun 17 2008
    2K S4
    Rockville, MD
    I have a feeling my n75 is bad. What should the pins read? I've been trying to figure out a sure fire way to tell if it's my n75 or not.
    "Clearly, a liger is not as practical as a Katana. S4s can't carry ligers. fucking 500lb cat in my backseat using my alcantara as a scratch post for its HUGE FUCKING CLAWS? I dont' think so bro"
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Jan 25 2006
    A4 2.0T
    MD
    27-29+.. (ohm) higher the worse.
    Jun 04 2009
    Central NY
    Has anyone thought about pressure drop/loss? Or maybe your gauge is just inaccurate or not receiving the correct?
    I mean, if you haven't been logging boost, all you have to go on is what you can read on your boost gauge? That isn't the most accurate way to determine how much boost you are hitting.
    And the idea of pressure drop, the N75 receives its boost source directly from the compressor on the turbo. Where is your boost gauge tapped into? If it is the intake manifold, that should account for your lower readings. The air has to travel all the way through all the IC piping and FMIC first.
    Thoughts anyone?
    EDIT: nevermind. i just realized that the ECU uses the charge pressure measured by the MAP sensor to determine how to control the N75. the N75 never actually measures anything from its boost source, it just follows orders from the ECU.
    which brings me to ask, if the N75 were misbehaving, shouldnt the ECU modify the signal sent to it in order to behave properly? you really need to run some logs to see whats going on :)
    2001.5 S4 - AWE Stage 3
    2000 A4 1.8T - APR Stage 1 - SOLD
    Feb 23 2010
    Emmaus Pa
    put in a new n75 this morning and problem solved. holds 22~24 psi. If the n75 isn't functioning like it should the ecu will not be able to correct it. If it could there would be no point of replacing it. The car will usually throw a code for positive/negative deviation implying there is a boost leak/vac leak/wastegate/n75 issue.
    B9 S4- EPL/AWE
    Jan 25 2006
    A4 2.0T
    MD
    Excellent!
    Jun 17 2008
    2K S4
    Rockville, MD
    Nice Jesse. Mines shot too, thanks don for the tip.
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by Trigger Happy View Post
    fix that shit. It feels good to have your boost back. And when you put on those coils I know someone who will buy your springs.
    B9 S4- EPL/AWE
    Veteran Member Three Rings PovGRide742's Avatar
    May 07 2009
    2001.5 Audi S4, 2010 Audi A6
    Womelsdorf, PA
    Had the same issue last year when I was on GIAC-X with K03s... was boosting about 2psi low. Replaced the N75 and it fixed it. Just started boosting about 2psi low during this past week. Had a hiss for a while (since before I got tuned) that never prevented me from hitting requested boost. Figured I'd trace it down. Spent HOURS today between tracing the leak (fuel injector o-ring into intake manifold) and keeping the leak away (swapped o-rings, reinstalled injectors, rail-to-injector o-ring started leaking, replaced, reinstall injectors, another injector started leaking at intake manifold). I now have absolutly zero hiss when boost leak testing at 20psi. STILL boosting about 2psi low.
    After reading this, although hesitant as I just replaced my N75 last year, starting to think, yet again, I need a new N75. Maybe I'll look into that 034 one and have Josh re-tune my PID.
    2001.5 Pearl White Audi S4
    034 Carrier / DPs / Exhaust / Inlet Hoses / MAF Hose / Y-Pipe / X-34 | AAM DS | Apikol Diff/Snub Mounts | APR Bipipe | AWE Gauge / DTS / SMICs | B&M Oil Cooler | CM Clutch / Flywheel | DW FP | Enkei RPF1s | EPL Fueling / Tune | FT F21-BTs / Inlets | H&R Premiums | Hotchkis Sway Bars | INA FSI | JHM BBKs / Knob / Trio | SAMCO Hoses | STE PPD | Stern Motor/Trans Mounts | Zeitronix ZT3
    Jan 30 2012
    01 golf TDI, 03 Mustang GT, 08 GSXR 1000
    Pittsburgh, pa
    Im having the same issues as -2psi than normal... i usually spike 14 psi, than settle at 12psi and holds strong.. starting yesterday.. i sometimes hit 10psi and holds right theres.. sometimes hit 12 and back to 10 and holds there as well... also seems like the boost isnt coming on as fast.. i really hope its just my n75 as well... would hooking up a mbc w/ the n75 still pluged in.. temparly let me know if my n75 was bad or not?? like if i set the boost for 15psi? and it holds? that would be a bad n75
    Jan 30 2012
    Pittsburgh, pa
    Forgot to mention there's no cel coming on.. Hoping it's just a faulty n75.
    Jan 30 2012
    Pittsburgh, pa
    Tonight I was hitting as low as 6-8 psi. But steady 10 psi.. Even sometimes 12-14. I'm really thinking its my n75?? If it was a boost leak. I wouldn't be having odd boost sequence? It wouldn't hold boost
    Feb 23 2010
    Emmaus Pa
    pressure test first. If it checks out then its a good possibility your n75 took a shit
    B9 S4- EPL/AWE
    Jan 30 2012
    Pittsburgh, pa
    I gotta find someone that can check for me. Until my pressure test kit gets here.. Thanks for the input
