Results 1 to 9 of 9
    In, Out and Around...
    Fog Light Aiming...
    Anyone here have the specs for a proper fog light aim?
    Seems the beam pattern for the foglights is a bit off and i would like to adjust them to factory specs.
    Thanks.
    Dec 01 2011
    i didnt know you could aim them? i thought the bulbs just fit into the slot but not adjustable. i know projector lens you can aim but the fog lights are just regular housings.
    IG @theshawon
    Veteran Member Three Rings bengtc's Avatar
    Mar 13 2009
    2012 S4
    Dallas
    I aimed mine as high as they go since I am lowered an inch. The light still doesn't go out as far as I would like at the highest point.
    2012 S4 black, prestige, titanium, sport diff
    ** stasis tune ** kw street comfort coilovers ** vmr v701 19x9.5 midnight blue ** awe res exhaust res dp's quad black diamond tips ** injen intake **
    ** alu kreuz ** hotchkis front and rear sways ** spc adj control arms ** 034 end links ** akebono ceramic pads ** ecs slotted/drilled rotors
    ** rs4 grille ** blesk led plate bulbs ** hoen yellow fogs ** drive tech interior LEDs **
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    Quote Originally Posted by bengtc View Post
    What did you do to aim them higher? When I switched mine out, wasn't trying to aim, but didn't notice a way to change it? Thanks.
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
    Mar 13 2009
    2012 S4
    Dallas
    Quote Originally Posted by maga4 View Post
    Take a look here http://forums.audiworld.com/showthread.php?t=2772389 in the 5th picture at 7 o'clock you see a black piece where you can stick a flathead/phillips screwdriver in there and turn. Can't remember which way rises or lowers but you can test it out.
    Aug 12 2011
    Olathe, Kansas
    Awesome, thank you!
    Quote Originally Posted by Liquid Smoke View Post
    there is a screw by the foglight housing to adjust the height/level however i cannot find anywhere what they should be set to. not only is one higher than the other but now that i am lowered i would like to adjust them better.
    turn to the right to raise turn to the left to lower. the tighter you make the screw the higher the beam goes and vice versa.
    Veteran Member Four Rings jschrauwen's Avatar
    Aug 08 2013
    08 R8 TT, 08 A5 3.2 QTip, 90 300ZX TT 572whp 590wtq, Ducati TT2
    Frankford, Ontario, Canada
    I'll have to try this. Thank you iconoclast.
    For others trying to set to oem spec, the worm gear adjusters has paint on the gears itself to help to find the oem setting. However, I found that after multiple turns of the adjuster screw in the same direction, you can actually align those paint marks a few times in succession.
    2008 A5|Ice Silver|3.2 QTip|Premium Pkg|Technology Pkg|B&O & JL10W0-4 sub|15/20mm spacers|HID Fogs|Ext. & Int. LED's|RS5 grill|AWE/K&N Intake|Quad tipped OEM mufflers|CF Mirrors, Spoiler & Diffuser|Facelift Ecode Tail lights|CR-15 Strut Bar|Ecode headlights|Alu Kreuz|ProdigyWerks 6pot 2pc 356mm front 350mm 2pc rear BBK|Eibach springs
    2008 R8|Ice Silver|R-Tronic|Huffman TT Conversion|Focal/Mosconi stereo upgrade|H&R Coilovers|HRE wheels
    Jul 16 2018
    Atlanta
    The intended light beam angle is 2% (vs the 1% on our headlamps). So if the wall you're aiming at is 100 inches away, the beam center on the wall should be 2 inches below the height of the lamp centers.
    Lots of prereqs listed for a correct angle, like for the headlamps. 165 lbs in the driver's seat, headlamps on low not auto, full fuel tank, parking brake not on.
