Originally Posted by
belzebutt
2010 Canada Order guide:
Option Code PTC
Technology Package $2,200
- Audi Side Assist
- Advanced Key with Start Button
- Adaptive Headlights
- Homelink
No standalone option code for this in the guide.
US order guide for 2010:
(8Q5) Audi adaptive headlight (Prestige)
I finally got a clear answer... if your build sheet states 8Q3 they are not Adaptive/AFS headlights. You need an 8Q5 stamp and that would mean you have the real deal.
vtheman
It's easy to check. Put your lights on "auto" turn the wheel, if the lights follow you have AFS. I personally do not believe that AFS was available on any of the US pre-face lifted A4's. I just had a loaner 2012 Prestige avant and it didn't have AFS. My 2012 Tiguan has AFS and it does similar to what scottyuk just described. You can also take your headlight out (5min) and you should have a third module at the very bottom.
unfortunately this is not possible unless you are driving 10mph+ or you have showroom effect enabled. if you do then it will allow you to move the wheel and lights together when standing still.
