Results 1 to 5 of 5
Thread: B8 A5 seat
    Junior Member One Ring
    Jul 09 2018
    south africa
    B8 A5 seat
    good evening fellow audi owners
    i managed to source a set a set of S5 seats which i want to fit into my B8 A4, can someone advise they are direct fit? and will the back seat also fit in? will there be any error codes?
    thanks in advance for any input
    Feb 24 2013
    CA
    Yup, direct fit. Just make sure to switch out the module in the passenger seat from your old seat to the new seat so it doesnt throw a airbag error
    Jul 09 2018
    south africa
    thanks for the info....i got another question tho, my current seat are not electric, and the S5 seat are electric, is there power / plug in the original harness that can provide power tot the S5 seat?
    and i notice the S5 rear seat are split fold down unit....mine are a 1 piece non-foldable
    08 B8 A4 2.0tdi....FK coilovers, stage 2 tune, FMIC, CAI, Reiger front lip, CF spoiler and bits... work in progress
    Feb 24 2013
    CA
    Quote Originally Posted by audifanatics View Post
    That im not too sure about. You may be lucky and there maybe some plugs in place where you can plug them in but youd have to check. For the rears, you are able to make the rear fold down but you need latches and such. Not too hard from what i understand
    Active Member Two Rings paulrogue's Avatar
    Jun 25 2018
    2009 e90 328i
    If you don’t have power right now this would be what you’re looking for:
    https://www.kufatec.us/shop/en/audi/...t-harness-audi
    Will give power to driver AND passenger side.
    I’m sort of in the same boat. I’m buying sport seats, both power, but I only have power on the drivers side. Kufatec says that that cable won’t work for mine. Back to the drawing board 🤦*♂️
    Anyway hope that helps.
