Results 1 to 4 of 4
Thread: Control Arms
    Jan 23 2005
    Control Arms
    I know this has been talked about often but i have a question if the dealer is lying or not. I went in becasue there were squeeks comming out from the front left wheel. As the dealer said "need front tie rod, and wish bone left side" Now is there anyway that the wishbone got bent or anything or are they trying to get money from me? Should i go ahead and just buy a new control arm assembly and see if the sounds goes away? And finally can the shock ever go bad to produce a "psshhh" sound when ever i go over a bump?
    May 06 2004
    B5 B8.5 S4s
    PA
    Could get bent somehow, but I'd guess they were talking about the joint in the arm with no further details... Either one could be making noise. Shocks normally make the pshhh sound over speed bumps and such, is that what you mean?
    Keep right pass left, it's the law!!
    Jan 23 2005
    no just over all when i go over a little bump or just rolling on gravel it will make that sound.
    Veteran Member Four Rings TheBlueMartin's Avatar
    Jan 06 2005
    2006 A6 3.2, 2009 Q7 4.2 Prestige, 2014 Regal GS M/T
    Ann Arbor, MI
    Well, if they really said 'wishbone' they are lying....Audi's from '96 up have 4 link independant front suspensions. The ball joints on the outer links of the suspention can make noise, and can bend.
    http://www.ecstuning.com/stage/edpd/...ory=Suspension
    "Mastering others is strength, mastering yourself makes you fearless" Lao Tzu
    2006 A6 3.2 Avant- Black.
    2009 Q7 4.2 Prestige - Lava.
