Results 1 to 7 of 7
    Senior Member Three Rings Winners Eat Pho's Avatar
    May 17 2008
    Why do my brakes sound like blue whales in the pacific ocean?
    It's the oddest sound, and used to only happen every once in a while - usually at low speeds while turning. I had my front rotors and pads replaced, and it's doing it still... but even more now. Except now, I don't have to be turning, but still only happens at low speeds. Any idea what this sound is? It sounds like a whale underwater.
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    Feed it some Krill and the noise will eventually go away? lol
    seriously though, you should be able to look for your self by removing the tire and checking to see if either there is something lose or stuck. That would be the obvious signs to look for.
    Veteran Member Four Rings CleverA4Name's Avatar
    Dec 09 2009
    2006 A4 2.0T Quattro 6MT
    Portland, OR
    Are your calipers greased properly?
    F.T.W.L.T.B.D.W.I.C.T.W.
    -Trent
    Oct 20 2008
    Denver
    Quote Originally Posted by CleverA4Name View Post
    Are your calipers blubbered properly?
    fixed.
    '14 Audi S4 P+ | Sport Diff | | Ice Silver | APR Stage II+ Ultracharged | APR Dual Pulley | TA Testpipes | APR DL501 | Accuair | Airlift | E-Codes | SB Leds | ECS Tuning Kohlefaser Luft-Technik Intake | Eurocode AK | P3 Cars | AWE Resonated | Deval | Enlaes | Strafe | Spulen Diff Mount | 034 Trans Insert | 034 Motor Mounts | Avant Garde F110 | VMR V810 | Vossen CV-3 | Stoptech ST-60 BBK | JHM 2-piece rears | AMS Cooling System | Eurocode Sways & Links
    Feb 07 2012
    New Fairfield, CT
    If the blow hole is not clear of debris you'll get that sound
    Jun 27 2011
    Sometimes the calipers can accidentally ingest small wooden men and when the start fires in the master cylinder it causes the brake noise, similar to a whale sneezing. Have you tried opening the bleeder screws to eject the debris/pinocchio?
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant)
    2012 Q5 2.0t - Stock Mommy Missile with new timing chains
    Former USP CLUB MEMBER #136
    Established Member Three Rings NickDaQuick's Avatar
    Apr 14 2012
    Ventura, California
    Too bad they dont sound like killer whales.....
    2006 Ibis White A4 2.0T
    Mods: 18" TSW Valencia ~ Street Edge Coilovers ~ AEM CAI ~ Custom Catback Exhaust ~ Magnaflow Mufflers ~ 20% Tint ~ RS4 Grille ~ Euro Plate ~ S4 Valance ~ Blacked Out All Stock Chrome ~ Tinted Headlights ~ CC Mod ~ Roof and Trunk Lips ~ Debadged ~ Hardwired Passport Escort 8500 x50 ~ Custom iPhone Dock
