well i drained the oil, and swapped out the oil temp sensor from my other motor. mind you the sensor i was using was out of an aug passat, but they had the same part numbers. replaced oil with 5w 30 and ran it around town. seemed to work much better. the oil temp slowly climbed up to 200, then sat between 210 and 225, and settled around 225, without ever reaching the 250 mark. 225 stills seems a little warm to me, but a whole hell of a lot better than what the other sensor was reading. guess ill put external oil cooler on my list of things for the future. also i picked up a 90 degree plastic bend and some 1 inch hose from the hardware store to make a pcv dump. ill just run a straight dump until i decide on a catch can setup
but the car is running pretty good now. afr readings are sub 12 at full boost, which is only 16 psi. ill get some more miles on it and crank it up to what the tune is written for, which is 22 i believe. spool is still slow, not really hitting 16 til 4500ish. i might mess around with my tune a bit to help, or if i get some more shingling jobs coming up ill have it tuned.
