Page 3 of 12 FirstFirst 12345 ... LastLast
Results 81 to 120 of 476
Thread: It's time
  1. #81
    Dec 05 2007
    You won't know till you try with your bumper, but you are going to have fitment issues with the piping that would sit in the lower corners of the bumper. They come out too far. On the outlet of the intercooler, I would have ran a 45* silicone coupler (longer ones are more expensive, but would do the trick here). Then based the rest of the piping off of that for the cold side. On the intercooler outlet, a 45* aluminum piping cut to fit. Then would have built off of that to the compressor outlet. Either way, I know I wasted about $100 on unused couplers and such to make my charge piping. It's a trial and error thing, but was necessary. Now, I share that info with others so they know the easiest way to go about it and not have to waste money testing fitment (people running similar setups to mine).
  2. #82
    Veteran Member Three Rings Grip99's Avatar
    Feb 15 2011
    ny, ny
    looks good man!
    If you wanted it to be alittle close in on the cold side, you could cut alittle off the 90 degree. Cutting the pipe leg off the intercooler to bring it in alittle and then cutting the 45 to the TB as well..
    EDIT: you dont have a 45, you have a straight to the TB... I would cut some of that to bring it in closer so your bumper wont hit it...
    Are you running ac anymore?
  3. #83
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Best to keep the pipes as tight as possible to the radiator support if you want them to sit behind the bumper/grills. So basically you want the pipe to be already behind the outlet/inlet of the FMIC by the time you reach the end of the radiator support down there.
  4. #84
    Feb 15 2011
    ny, ny
    heres what i did on my hot side since im running ac..
  5. #85
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    thanks for the ideas guys. i am not running a/c. i will chop some off of the 90's coming off the intercooler and report back. for piping, i got one 90 and three 45's left. a bunch of straight couplers and one 90 i believe. im sure i can make it work.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
  6. #86
    Feb 08 2011
    Quote Originally Posted by Grip99 View Post
    To tuck it even more a 45 deg hose at the FMIC inlet and a very short pipe with turning the 90 deg hose toward the FMIC could be used to line them up, but might need a 45 deg pipe to get into that 90 deg hose.
    The stock bumper cuts back really fast once you get out past the bumper shock, so things get really tight back there.
  7. #87
    Feb 15 2011
    ny, ny
    Quote Originally Posted by M-Hood View Post
    My bumper is hacked, so if you care for your front bumper, like i dont lol, yea that will help.
  8. #88
    Feb 08 2011
    You mean there is something left of your bumper you plan on using to cover that huge FMIC? lol
    Something like this?
  9. #89
    Feb 15 2011
    ny, ny
    lol here is what it looks like.
    No show...All go.. lol
  10. #90
    Feb 08 2011
    Well it looks like your showing a bit there, well of the FMIC that is. lol
    But Pete you really should try to find a used S4 bumper, lower your huge FMIC down to get way more of it into direct air flow or just cut the center of the bumper like in the picture of Mike's car.
  11. #91
    Feb 15 2011
    ny, ny
    Id love an s4 bumper...Just havent found one where i could pick it up locally.
    If one was around my area for sale, it would be on my car lol..
  12. #92
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    hotside piping 2.0. id do the cold side but its so fricken hot outside i just need a tiny reason (like posting a photo) to come in and cool off.
    2000 S4- Working?
  13. #93
    Feb 08 2011
    Quote Originally Posted by redline380 View Post
    Much better. It isn't the heat it is the humidity that gets you. It is so hot here in Arizona that the water in my sons 6 ft pool gets to 80-90 degs and it is in the shade. lol
  14. #94
    Feb 15 2011
    ny, ny
    lookin cleaner now..Nice!
  15. #95
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    the humidity is pretty killer here. but question before i go at the cold side. wheres the best place to weld on my map sensor adapter? just anywhere before the throttle body or closer the the intercooler outlet better?
    2000 S4- Working?
  16. #96
    Feb 08 2011
    Doesn't matter, anywhere on the cold side pipe will do.
    BTW here is a picture I took the about a week ago. I swear AZ is like living inside a hot side pipe. lol
  17. #97
    Dec 05 2007
    Just be sure that wherever you place it that the stock harness can reach it.
  18. #98
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    remind me of when i went to vegas last august. walking out of a 65 degree casino into 115 degree heat was like walking into a damn oven. i could literally feel the moisture being sucked from my eyes. good thing i had lots of beer to hydrate me is it true they purposefully report the high temerature as ten degress less than it actually is? i heard they do that so tourist still some.
    2000 S4- Working?
  19. #99
    Veteran Member Four Rings howardfootball's Avatar
    Oct 20 2010
    '57 Ford Thunderbird
    MD
    Arizona has some killer heat in the summer. I have family that lives out there and I remember a couple years back that it was about 125*F. Just breathing in that heat is difficult. At least it wasn't humid like here on the easy coast. Humidity is the real killer.
  20. #100
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    cold side piping 2.0. not sure if you can see the plug for the map sensor, but thats where i plan on placing the adapter, so it will only be a few inches away from the bov. and i ended up using a 45* pipe instead of a straight one going to the throttle.
    2000 S4- Working?
  21. #101
    Dec 05 2007
    Much better! Now it wrestling match time with the bumper.
  22. #102
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    i placed the bumper on and it really seems like there wont be that much cutting involved. the first thing i cut were the plastic section that the grills clip into, then i tried placing the bumper on and i almost got it to clip in. i got the map sensor adapter welded on tonight, so im getting ready to get done. things on the list yet:
    install fuel pump and make sure it works
    install wideband gauge
    run fuel lines and vacuum lines
    flash ecu with maestro when it gets here
    2000 S4- Working?
  23. #103
    Feb 15 2011
    ny, ny
    Nice job...Looks good man
  24. #104
    Feb 15 2011
    ny, ny
    Hows the head light fitment with the filter right there?
    I remember i had to mod the headlight housing to fit with the filter so close.
    I guess i should also mention the headlight on the passenger side as well looking the recent IC piping fitment
  25. #105
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    funny you ask. i completely forgot about headlight fitment. i checked after i put everything in and i barely squeaked by
    2000 S4- Working?
  26. #106
    Feb 15 2011
    ny, ny
    ok cool
  27. #107
    Jul 27 2010
    Queensland, Australia
    Can't wait to see this monster run. :)
  28. #108
    Veteran Member Three Rings Tropicgreena4's Avatar
    Oct 07 2004
    South Central, PA
    what's with the green?
    -Wes
    2023 A6 Allroad
    2019 S5 Sportback
    2011 A4 Avant
    2016 Scuba allroad - Sold
    2004 Nogaro Avant 6MT - Sold
    98.5 Audi A4 2.8 - Tropic Green - Sold
  29. #109
    Feb 08 2011
    Quote Originally Posted by howardfootball View Post
    It is monsoon season here in AZ so it can get pretty humid too, right now it is raining.
  30. #110
    Veteran Member Three Rings CCA4's Avatar
    Oct 25 2009
    Ford Raptor
    Erie, PA
    I like what you did with the BOV. Looks way cleaner that way than having that coupler/adapter thing in the middle of the cold side pipe, then another coupler to the TB. Well played! That's the one from 034, yeah?
  31. #111
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by CCA4 View Post
    that one I actually got off siliconeintakes.com. http://www.siliconeintakes.com/produ...d0e52332eb00ae i cut the "t" part down a little to move the bov closer to the charge air. but i figured just using the t coupler to mate the charge pipe and the throttle body would have the advantage of getting the bov that much closer to the throttle. i do want things to look good under the hood, but at the end of the day it should still be form over function
    2000 S4- Working?
  32. #112
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    well good news is things are getting ready to start up. i dont have much left to do and the tracking number for maestro finally got emailed to me. should be here tomorrow.
    the bad news is i picked up another shingling job. this time its around 25 square, so it will take a couple days. i think its only supposed to be around 85 tomorrow, so that helps. with any luck ill be getting this thing going by sunday or monday. after i get it started ill just have ti weld up the exhaust. my projects for today include- installing fuel pumo, fitting bumper, running gas and vacuum lines.
    2000 S4- Working?
  33. #113
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    ok bad news first- the tracking on maestro says it went from mississauga, ontario to pettysburg, oh which is nowhere near minnesota. this means it wont be here till monday not all that big of a deal since i got a big shingling job which will take all weekend
    the good news- got the fuel pump in, fuel and vaccum lines ran. happy to report no leaks in the fuel system (yet), but my pressure goes from 60 psi on priming, to around 50 psi sitting. then it goes below 40 psi after sitting an hour. where is my fuel pressure going? there are no leaks that i can see. a stupid move on my part though. i cranked the motor over to check fuel pressure and the damn thing accidentally started, without the oil line to the turbo primed. the car idled up to 3000 right away and i killed it. hopefully no damage was done to the turbo bearings, but its a used turbo so im hoping enough oil was still in there for the second it was running. after that, i pulled the oil line to the turbo, removed the coil packs and fuel pump fuse, and cranked till my buddy saw oil coming out the line. but as of now i just gotta wire up the wideband this weekend and wait for maestro.
    2000 S4- Working?
  34. #114
    Feb 15 2011
    ny, ny
    Sometimes people install a check valve that doesnt alow pressure loss.
    Some of its probably going back into the tank.
  35. #115
    Feb 08 2011
    The pressure is always going to leak off a bit even with a check valve at the pump, the fuel will leak off at the FPR. This is why the pump will prime the system when you first turn on the key.
  36. #116
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    good to know guys. what do you think about the the motor starting without oil in the turbo? it only reved up to 3000 and i shut it off right after. two seconds max
    2000 S4- Working?
  37. #117
    Feb 15 2011
    ny, ny
    Has there been oil in the turbo before?
  38. #118
    Oct 25 2009
    Ford Raptor
    Erie, PA
    IIRC most of the stuff is lightly used, including the turbo. I think there'd be at least a little oil left in it from the previous owner.
  39. #119
    Veteran Member Four Rings thenj3's Avatar
    Dec 25 2009
    North Jersey
    Your good bro
    2001 2.0l ct-5858 parting out- ringer racing, full race, comp turbo, maestro
    BUY MY STUFF: http://www.audizine.com/classifieds/...partout&cat=20
    http://www.audizine.com/classifieds/...-skirts&cat=54
  40. #120
    Feb 15 2011
    ny, ny
    Yea your fine
