Hey guys, I recently purchased the VCDS-lite from Ross tech and still learning how to use it. Anyway 2 weeks ago I had the APR stage 2+ software installed with the 225 TT injectors. I still have not installed my test pipe but plan to do it this Friday . I have not had any CEL until today when I did a few pulls up to 120 mph to around 6800 rpm in each gear. I had these codes pull up :
Address 01: Engine Labels: Redir Fail!
Controller: 8E0 909 518 BC
Component: 1.8L R4/5VT G 0010
Coding: 0016711
Shop #: WSC 12850
VCID: 7297D6FD2DA1
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
18339 - Coolant Fan Control Module (J293): Malfunction
P1931 - 002 - Lower Limit Exceeded - Intermittent
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded Readiness: 0000 0001
I also have a OEM Audi TT 710N DV that I need to install. Any help would be much appreciated :)
Nik
