Man, I know OG had some great information on bleeding the system, which you'll have to do to relieve any leaks and check that possible cause off your list. I can't find it for the life of me, though.
There's a bleeder screw (an allen head) on a hard coolant pipe over the manifold that you can unscrew partially to relieve pressure. I would take the screw off the coolant reservoir and hold it upwards, so the coolant hoses that go to the radiator are pointing down. You can squeeze the radiator hose to see if any air bubbles come out of the pipe.
Additionally, you can take off the rain tray and loosen the hose that goes to the heater core - the left one, I believe - and do the same squeezing procedure to force coolant out of there. You only want to pull that hose back until the little hole in it is off the hard pipe.
I'm pretty sure you can do this cold i.e., without having to warm the car up. Hopefully someone else can chime in and correct anything I missed.
