Results 1 to 12 of 12
    Apr 19 2012
    Montreal, Canada
    What is needed for a complete tune up
    My car is due for an overall tuning I'm gonna be placing an order to ECS for my springs figured i might as well order at the same time and my mechanic can start on it what do I need to order and are there kit available, any other suggestion than ecs?
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    Veteran Member Four Rings Widebody4.2's Avatar
    Jan 08 2012
    S6 Avant
    Central MA
    ECS has the dealer 40k kits plugs filters oil ect
    Veteran Member Three Rings Brens's Avatar
    Jan 07 2012
    B5 S4, MK1 TT 225, 3rd Gen Tacoma, 3rd Gen 4Runner
    Charleston, SC
    And, even though its not tuning, clean up headlights if needed. give the car years off its age
    -Brendan
    Brilliant Black B6 A4 Avant - 5spd 1.8T - Recaro - RNS-E - VMR - Daz - Woody Insides - Clutch/ Tune - Pink Coolant
    Jan 07 2012
    Charleston, SC
    Welll I'll just list everything worthwhile
    -Cabin Filter
    -Air Filter
    -Coil Packs
    -Spark Plugs
    -Fuel Filter
    -Mounts (Engine/Tranny, for better ride and better for engine power)
    -Oil change with filter change, maybe a few flushes
    -Coolant flush
    -Transmission Fluid (if TIP, if 6speed then consider a new clutch, hell why not)
    -Rear Diff fluid change
    -Engine bay cleaning+ cleaning of ypipe, pressure pipes, throttle body boot
    -POssibly gaskets? if you need to.
    EDIT :Oh yeah and a full TBelt kit. Def. Do this while having all this other work done and put it. Get the one with the belt, acessory belt, water pump, thermostat, pulleys, coolant, the whole 9 yards. A nice running engine wont be so nice with a broken tbelt and bent valves, messed up cylinders.... just get the kit before anything else.
    -Brendan
    Apr 19 2012
    Montreal, Canada
    Quote Originally Posted by Brens View Post
    -Cabin Filter
    -Air Filter
    -Coil Packs
    -Spark Plugs
    -Fuel Filter
    -Coolant flush
    Thanks really appreciate it , is ECS my best bet or got any other suggestion?
    Apr 19 2012
    Montreal, Canada
    ECS vs. OEM
    What's better some pieces ECS has their own "Brand/Kit" I.E Timing belt which is the "better" one ECS or OEM?
    Jan 07 2012
    Charleston, SC
    Get as much oem as possible. You can and should order it all through ECS as they carry genuine Vw/Audi parts. Things like fluids don't need to be from them as long as they meet the specs. Spark plugs can be NGK, ect, ect... Mounts should be OEM unless you get something like 034 mounts...
    Brendan
    -Brendan
    Apr 19 2012
    Montreal, Canada
    I try to stick to OEM as much but what I'm saying is the price of ECS tuning is somewhat higher is the quality higher?
    For example when it comes to the Air Filter I got OEM (15.36$) vs. K&N (49.95$) we all know K&N is a reputable company is it's air filter "better" than the OEM
    Edit: I realised that the timing belt kit ECS brand is more expensive because more items are offered so it wasn't that the quality is better but that there is more than just the timing belt
    Jan 07 2012
    Charleston, SC
    Yeah its not entirely safe to say that OEM is better than EVERYTHING out there, but for the most part it's best to stick with them.
    Right now i'm riding with a Duralast front axle, which i'm only waiting for it to blow. Meanwhile i'm trying to fix my OEM axle, but i'd rather get Raxles all round.
    -Brendan
    May 29 2011
    2000 VW passat B5 2.8
    Bay Area,CA
    you didnt mention how many miles the car has.
    that plays a huge role in weather or not you need alot of those things.
    Apr 19 2012
    Montreal, Canada
    Quote Originally Posted by -C5- View Post
    285 000
