Results 1 to 11 of 11
    May 11 2012
    Ireland
    Fiiting drls to audi a6 c6
    [IMG][/IMG]
    Hey all, I just got some new drls which I need help to wire up.
    I have them fitted neatly next to the foglight and need to know what power to tap into.
    It has three cables
    a positve
    a negative
    and one which has to go to "headlight".
    can anyone tell me where these wires should go to. I can take some pics of the install once I have them wired in.
    Jul 17 2011
    Sin City, USA
    I am waiting on mine to arrive from Germany. If I get them in before you find your answer, I will post up.
    '09 C6.5 A6
    May 11 2012
    Ireland
    I've done a considerable amount of reading and what most people do is run a wire to the drivers side fuse box and use fuse 20# heated window washer fluid to get their power. then they can connect the control cable to the headlights to control dimming etc. I haven't done it yet, as i'm waiting for my fuse tap(add a circuit cable) to come from ebay. I'm not looking forward to cabling it in, no idea how to run the cable can anyone help with this. I know there is grommets but where are they located? on the drivers side and the engine bay?
    thanks
    May 31 2011
    Virginia
    Could you post the link to the lights you bought, I have been wanting to do this and am still looking at different options.
    May 11 2012
    Ireland
    I actually got replica hellas, due to budget, this is what they look like.
    http://www.youtube.com/watch?v=_FvYflD5D0Y
    not bad at all picked em up for bout 50
    May 11 2012
    Ireland
    so i spent the morning trying to wire these drls up. I can't find how they come from the engine bay to the drivers fusebox. My car is right hand drive and i lost nearly 2 hours searching for a rubber grommet. anyone have any ideas or help?
    May 11 2012
    Ireland
    Anybody, I'm at my wits end! even if i could find an ignition source other than the drl bulbs already in the car.
    Jul 17 2011
    Sin City, USA
    Sorry that you are having issues and that I can't offer any assistance. Hope you can get some assistance.
    '09 C6.5 A6
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    Quote Originally Posted by bazery View Post
    Generally speaking since I haven't worked on any Audi's, follow the wire bundle to the fire wall. On North American left hand drive cars, they are usually on the drivers side since that 's where many wires terminate. In you case, they may be on the right hand side.
    The wires either go through the firewall by using a connector with the harness plugging into each side or the bundle passes through a grommet.
    You may have to drill a hole in an area that is clear on both sides. When you do find a way, add a couple of spare wires for future use.
    May 11 2012
    Ireland
    I found it, it was on the left hand side so i rang it through the grommet for the brake lines, I had a busy weekend. the drls are now running and looking mean. I installed reversing sensors and they are perfect. I also put in led drl bulbs but they are doing a flash every minute or two. Apparently I need to get load resistors to stop the flashing, very annoying as replacing bulbs is a nightmare. my arms look like a fella who's into self harming or something!
    Jul 17 2011
    Sin City, USA
    Would love to see pics when you get a chance. Oh, an stop cutting yourself, lol.
    '09 C6.5 A6
