i am in the process of upgrading my symphony II bose to rsne with bt, and dension ipod control.
When i connect the kufatec fiscon bt, and start the car i can pair the phone make calls ect. What happens is i get massive feed back from the rear speakers. a massive ammount of hissing and popping.
I have tried the nave with just the bose symphony II to rsne quadlock and don't have the sound, i have tried it with BSymp II to Dension quadlock to rsne and don't have the sound. It is only when i add the kafutec fiscon quad lock cable (don't even have to add the fiscon box) that i get the feed back through the rear speakers when the car is running.
any ideas
2005 audi a4 3.0l ultrasport.
rnse,
fiscon basic plus
dension gateway 100
Update
Last friday i was running a high fever and was out most of the day. While i was a ran down my pin outs of the connectors and i could not find anything glaringly wrong other than the original pin plug and play adapter from vagnavs did not have set of wires for the left front speakers. I kept getting errors when i checked them in vag com.
Today i received a new wiring harness from my old symphony II to rsne quad lock. I still have the same popping and high pitch wine.
The re seller Vagnavs says the fiscon must be coded. I am un able to get vag com to recognize it.
When using the Dension gateway. I am having difficulty with it. It wants to skip tracks, songs, audio books . There does not seem to be any consistent way to move through it. Dension says to select cd 6 then track 3 and hold fast forward for 3-5 seconds. How is that done on a system that does not have fast forward button?
Thanks for any help. I have received nothing from vagnavs or kafutec. I am at a loss as what to do next.
here is the latest faults from vagcom
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E1 909 559 B HW: 8E0 909 059 A
Component: 3.0L V6/5V G 0030
Revision: 00000000 Serial number: AUZ6Z0D0229206
Coding: 0013711
Shop #: WSC 63351 000 00000
VCID: 356B19AC5F5A571
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 4529
Coding: 04495
Shop #: WSC 06435
VCID: 2649CEE0C2FC2C9
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 63351
VCID: 63CF97F4F14E991
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul KAN 0517
Coding: 01014
Shop #: WSC 63351
VCID: 356B19AC0F5A571
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 A HW:
Component: SDAR XM
Revision: Serial number: AUZ4Z7C4013318
Shop #: WSC 00000 000 00000
VCID: 2757C3E495F6351
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
VCID: 3F877B846D669D1
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01041
Shop #: WSC 63351
VCID: 3E7906803A6C949
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01229
Shop #: WSC 19411
VCID: 36691EA0125C5C9
WAULT68E85A021460 AUZ6Z0D0229206
4 Faults Found:
01304 - Radio
49-10 - No Communications - Intermittent
01303 - Telephone Transceiver (R36)
01311 - Information Data Bus
37-10 - Faulty - Intermittent
80-10 - Single-Wire Operation - Intermittent
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0F04
Coding: 00002
Shop #: WSC 06435
VCID: F1E36DBCBBB2BB1
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 T HW: 8E0 035 192 T
Component: RNS-E US H80 0260
Revision: 03S Serial number: AUZBZ7M0097111
Coding: 0309677
Shop #: WSC 02197 758 00200
8 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 208
Time Indication: 0
Date: 2012.05.18
Time: 13:04:51
Freeze Frame:
Mileage: 655350 km
Count: 2105
Clock: 16:20
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 208
Time Indication: 0
Date: 2012.05.17
Time: 11:29:15
Freeze Frame:
Mileage: 655350 km
Count: 2105
Clock: 16:20
00858 - Connection; Radio ZF Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 208
Time Indication: 0
Date: 2012.05.17
Time: 11:29:15
Freeze Frame:
Mileage: 655350 km
Count: 2105
Clock: 16:20
00852 - Loudspeaker(s); Front
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 165
Time Indication: 0
Date: 2012.05.17
Time: 11:27:09
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 165
Time Indication: 0
Date: 2012.05.17
Time: 11:27:59
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 164
Time Indication: 0
Date: 2012.05.17
Time: 11:12:43
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 210
Time Indication: 0
Date: 2012.05.17
Time: 11:28:40
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 207
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1612
Coding: 11884
Shop #: WSC 63351
VCID: 72E1E2B03EB4009
Subsystem 1 - Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0204
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0205
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 040DB46814003E9
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309677
8 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 208
Time Indication: 0
Date: 2012.05.18
Time: 13:04:51
Freeze Frame:
Mileage: 655350 km
Count: 2105
Clock: 16:20
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 208
Time Indication: 0
Date: 2012.05.17
Time: 11:29:15
Freeze Frame:
Mileage: 655350 km
Count: 2105
Clock: 16:20
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 208
Time Indication: 0
Date: 2012.05.17
Time: 11:29:15
Freeze Frame:
Mileage: 655350 km
Count: 2105
Clock: 16:20
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 165
Time Indication: 0
Date: 2012.05.17
Time: 11:27:09
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 165
Time Indication: 0
Date: 2012.05.17
Time: 11:27:59
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 164
Time Indication: 0
Date: 2012.05.17
Time: 11:12:43
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 210
Time Indication: 0
Date: 2012.05.17
Time: 11:28:40
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 207
End ---------------------------------------------------------------------
Again any help is greatly appreciated
