Page 6 of 88 FirstFirst ... 456781656 ... LastLast
Results 201 to 240 of 3694
Hybrid View
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by black2.7t View Post
    So, I have a good chance to pickup a 2000 s4 tip, that was rear ended for pretty cheap, what would have to be done about putting an auto 2.7t into a 2003 b6 a4 5speed? I heard the cranks look different on the ends???
    You need SAI block off plates, ECU recode, pilot bearing for the engine. Maybe a manual harness would help. Otherwise just follow page 1
    - Clint
    Mar 06 2012
    Columbia, SC
    Mine came off of an 01 A6 TIP, So I got the SAI block off plates, Pull the spacer off of the crank and my lightweight flywheel bolted right up to it, Got manual harness, ecu from a manual S4, I deleted the 075 and the 249, So from what I been reading I should have no issues since my ecu is from a S4 and not A6
    Veteran Member Four Rings quattroloco's Avatar
    May 07 2012
    olympic penninsula/WA
    i dont see why not... the engine compartment is zactly the same far as i can tell
    B6 A4 AVANT swaped 2.7T 6MT S4 Drivetrain still illegal
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by quattroloco View Post
    im still waiting on a 034 tbb and the correct t-bolt clamps. inside is a Gates blue racing timing belt and all new OEM wp, tstat, tensioners and seals. i have piggie pipes to go on with a true dual catless 2.5" exhaust. stage 2? ill need good DV's and a Hitachi MAF.
    What exhaust? B6 S4 one?
    Also, yes the 034 kit will fit
    - Clint
    May 07 2012
    the exhaust is from the donor car, it is a custom job with 2.5" and strait from the cats (ill be deleting) to a 2in 2out magnaflow and then two tail sections that go to either side of the bumper. ill post a pic of it. very straight with only two bends each side, i may need to modify for the B6 but shouldnt be too bad. I may add a resinator where the cats were depending on the sound. i plan on adding flanges to the DP's for a "test pipe" to replace the main cats, that way when I goto the track I can swap the test pipe for a open dump off the DP's that exits behind the front tires. more flow and noise what do you think? ill see if EPL can do a mode for the open dump if it helps or do you think it wont matter as far as tune?
    Aug 21 2012
    Oslo, Norway
    I was looking into the 3.0 core support here in Norway.
    It seems like it's made of plastic; is that correct / a problem?
    May 07 2012
    its more like a fiberglass material and its tough as hell... shouldnt be an issue.
    Jun 27 2011
    Holy balls I thought the 1.8t was bad with the spiderweb of vacuum lines and random shit. Jesus...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    May 07 2012
    im pulling my motor moday and starting the swap but it includes a tip-6mt swap with it and im wondering about the gauge cluster coding... do i have to code the b6 cluster if im using a b5 ecu and if so do i have to do it before i do the swap?
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Do it before the swap and before you pull the ecu and the tip box. If you pull the tip box you will get a not found error code and you can't recode anything with error codes.
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    May 07 2012
    thats what i thought i remembered something about having to do it before... will it be totally confused if i code it to manual and then drive it home or do i have to do it here and then not use the auto again... its the only part im worried about of the whole swap. did you recode your ecu or did you put a b5 ecu in?
    Mar 06 2012
    Columbia, SC
    One more piece then I start dropping my engine in as well. Still trying to find those AC lines and need to do something about that snub mount.
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Quote Originally Posted by RKLamb View Post
    I just did the snub mount again, this time with a 3.0L carrier if it helps. Still needs to be cleaned up, but you get the idea.
    http://www.audizine.com/forum/showth...=1#post7928480
    May 07 2012
    i think the snub mount off my 3.0 will bolt to the 2.7 and stuff right into that sweet little hole in my 3.0 core support. what do you think?
    Dec 18 2011
    Colorado Springs
    maybe its just me but this thread didnt tell me a damn thing with regards to swapping...........
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Quote Originally Posted by B6A4Dave View Post
    Lots of info here. If you want specifics, look at Clint's build thread and/or my build thread. There is info in AfourQ's thread as well.
    Veteran Member Four Rings daihashi's Avatar
    Apr 03 2010
    houston, tx
    Re: The Official B6 2.7T DIY/Swap Guide
    Probably because it's almost plug and play.. especially if you have a parts car.
    Sent while taking an "on the clock dump" using Tapatalk 2.
    May 07 2012
    ok, lets start. if everyone would grab thier 10 mm socket and ratchet we will begin with step one...
    Veteran Member Four Rings gottaBdope's Avatar
    Apr 07 2012
    '99 Clown Shoe
    Colorful, Colorado
    ^Rory^
    *2014 Audi S6* <- Daily
    *1999 BMW Z3 Coupe* <- Street-legal Track
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    Go on...
    -Tim
    Aug 14 2008
    2001 Audi S4 Avant and Fiat 500L
    Tampa
    hate to thread jack... but i can get a 2005.5 b7 S4 with an engine issue. could i swap in the 2.7 from 2002 S4, the motor has 49k on and comes with turbos and all harnesses...for 3K. Is this worth a shot?
    "let me tell you about the time i almost died"
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    If the price is just the engine, turboes, and harness then that is high. I got that for 1700 shipped.
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Can someone please clarify the exhaust setup? it says in OP's post that SSAC's downpipes work, has this been confirmed? And are there any other options other than those?
    And also it says to use S4 stock exhaust, is this the B5 or B6 catback I'm confused because the motor we are swapping on the B5 S4 uses a single catback, and the B6 body uses dual, so which is it?
    Jan 16 2011
    Earth
    Quote Originally Posted by A4QuattroV6 View Post
    bump
    Oct 29 2005
    10speed
    San Francisco, CA
    Dave, no offense, but if you didn't get anything from this thread maybe this swap isn't for you
    - Clint
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by gpoole30 View Post
    Yes. Curious how much you can get the car for
    - Clint
    May 07 2012
    is that "man on a buffalo?" lol.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    you sir win a cookie!
    Oct 29 2005
    10speed
    San Francisco, CA
    If you use the stock B6 mount- NO downpipes fit.
    If you use the B5 mounts with the correct subframe- ALL downpipes fit
    You would use a B6 catback, not a B5 one
    - Clint
    Feb 16 2008
    Iowa
    Can you define what you mean by "correct subframe"?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by S4iowa View Post
    manual subframes don't have those half circle pieces welded in there that the 01E uses. Only the automatic ones have them I think
    - Clint
    Apr 03 2010
    houston, tx
    So the auto subframe is the "correct" sub frame?
    Coincidentally I'm an Auto.... and coincidentally I am also running B5 S4 motor mounts already. Unfortunately thought things have come up and getting a parts car for the swap will have to be put off until 2013 :(.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I think early B6 chassis came with them regardless.
    My 2002 was manual from the factory and had them before we cut 'em off to fit my downpipe.
    Most ideal trans mount is the B6 crossmember and was used in the 01E for the 2002-2003 B6 3.0L 6spd.
    -Doug
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by daihashi View Post
    This is about transmission mounts not engine mounts
    They were asking which ones were best to fit B5 downpipes with no modding. In that case, b5 ones are best.
    - Clint
    May 07 2012
    I feel so proud to have earned his respect! Lol!
    Senior Member Three Rings Ori0n's Avatar
    Sep 26 2010
    Saskatoon, SK
    What kind of mileage do you guys get with the swap on a quattro car?
    I shouldn't have to ask haha, but I'm very curious!
    2004 Audi A4 Avant 1.8TQM - Stage 2+ [ SOLD :( ]
    2007 Audi A4 Avant 2.0TQM - OEM+
    Oct 29 2005
    10speed
    San Francisco, CA
    20mpg with a bad MAF (running very rich)
    - Clint
    May 07 2012
    I just drove my car for the last time with a 3.0... the swap begins...
    Mar 06 2012
    Columbia, SC
    Man I wished I had a 3.0 I finally got all my parts except the AC line. So tomorrow Im starting the process of putting it in.
    May 07 2012
    I started today! first one to fire up is owed one frosty beer.
