Page 49 of 88 FirstFirst ... 39474849505159 ... LastLast
Results 1,921 to 1,960 of 3694
Hybrid View
    Active Member Two Rings Kristof's Avatar
    Mar 03 2015
    st-hubert,quebec,canada
    i have same isue for max oil level if you find out the problem let's me knows
    any way to bypass the sensor ? with vag com can we delete the option of max oil level sensor ?
    Envoyé de mon iPhone en utilisant Tapatalk
    Mar 05 2012
    11 Q5 2.0T, 18 Q7 3.0T, 89 Foxbody!
    Bucks County, PA
    Quote Originally Posted by Kristof View Post
    Kristof...
    ABS still working good? The 5.7? No warning lamps?
    Sent from my XT1080 using Tapatalk
    2012 Q5 and 2018 Q7
    Mar 05 2012
    Bucks County, PA
    Did anybody other than Kristof do the 8.0 to 5.7 ABS swap??? I started mine today, but I realized there is no VSS wire coming from pin 33 of the 5.7 module I got for the swap. I was wondering if others had experienced this. I can easily install a terminal there, but I am confused why it is missing.
    2012 Q5 and 2018 Q7
    Saint Cloud, Fl
    Has anyone successfully installed an AUTO 2.7T into Manual 6-Speed car yet ? I'm having difficulty locating Manual Trans engines for a good price, but I'm locating complete Automatic cars for around $1300.00
    - Yes I researched and I didn't locate a successful swap
    - I did however learn (or was led to learn that the cranks on both AT and MT cars are identical)
    - I also read that a Pilot bearing was needed
    - Then I read that the Pilot bearing was not needed and is actually built into the flywheel
    instagram ------------> low_enforcement
    Nov 17 2009
    Quote Originally Posted by 7speed View Post
    my motor came from an 01 allroad which was auto. posed no issue mating up with the 6-speed.
    996 TT
    MKIV Supra TT
    LX570
    Saint Cloud, Fl
    Quote Originally Posted by Ali View Post
    Did you take any special steps to bolt it up ?
    Nov 17 2009
    Just a B5 S4 trans spacer plate.
    996 TT
    MKIV Supra TT
    LX570
    Dec 03 2005
    2 pedals 1FG
    connecticut
    the 2.7T auto crank and manual crank is the same part Sam. The auto uses a spacer on the crank that the flex plate is bolted to. The manual flywheel is pressed onto the crank where the auto spacer is. Its great in that you don't have to touch the engine.
    engine crank sensor trigger is on the trans bellhousing triggering off the ring on the flywheel.
    Pilot bearing is in the flywheel. another gem I like over the 1.8T stuff. I hated having to remove the pilot bearing from the 1.8T crank. removing and installing it on a flywheel is so much easier.
    I can send you some pics tonight. My first engine was from an S4 MT and my latest engine that I'm currently using is from an A6 AT. My trans is a 6spd from a B6 S4. I'm using the 01E trans adapter/spacer plate and cobbled bellhousing bolts together out of my box of bolts.
    -Doug
    Established Member Two Rings Mr. Wolfsberg's Avatar
    Jun 02 2015
    Indiana
    I bought a whole 2.7 car with an auto but have done the swap yet, there is most certainly always a pilot bearing in a flywheel but as to if it built into the flywheel idk as this is my first 2.7 but if it is it would be the first one I've ever seen
    Sent from my XT1049 using Tapatalk
    Veteran Member Four Rings Dutchsider's Avatar
    Aug 19 2010
    NEPA
    Not to derail the questions being asked, but update.
    Got the engine in to it's cradle.
    To do list:
    Fuel Return line
    Figure out ac lines
    Extend downpipes
    Stare at current flow charts for many hours and cut and splice dozens of wires
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    The cranks are the same. But the auto cranks sometimes have a plug in the end of the crank. The pilot bearing does go in the flywheel, but there is a small stepped extension at the end of the input shaft that goes past the pilot bearing. Just put some heat on the back of the crank and give the crank a whack with a rubber mallet to get the plug to come out.
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Nov 10 2015
    Sudbury, ON
    Is there a member on here who makes harnesses for people? If so, who that may be? Feel free to PM me if your that member.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Apr 07 2011
    Quote Originally Posted by jesse500 View Post
    Here's a link to his profile. Click
    Jun 18 2014
    Long Island, NY
    His name is Clint, and he's the OP.
    Nov 10 2015
    Sudbury, ON
    Thanks lads
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Sam. If you want my S4 2.7T I'll sell it to you really cheap. It needs a bore w/ new pistons and a valve job on the heads (broken valve). Perfect candidate for a solid high HP build.
    -Doug
    Jun 18 2014
    Long Island, NY
    I'm sorry guys, I know this has probably been covered. But which power steering line will I need, and will an allroad line fit ok?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by superhero View Post
    I flashed my car with an MBOX file, and no dice. I don't believe I have the right MAF, but how does the MAF interact with the tach?
    When I scan my car with VCDS, live data shows the correct RPM.
    I am stumped, any ideas?
    What's your actual problem?
    Quote Originally Posted by Boost_creep View Post
    It should. Any B5/C5 line
    - Clint
    Jun 18 2014
    Long Island, NY
    Thanks so much for your quick response. But which line? There is more than one. Is it the feed line or the return?
    Oct 29 2005
    10speed
    San Francisco, CA
    Just the feed line that goes from the rack to the rear center of the engine.
    - Clint
    Jun 18 2014
    Long Island, NY
    Thanks so much!
    Senior Member Two Rings Poopcorn's Avatar
    Nov 17 2014
    Calgary/AB/Cansda
    Have you guys heard Ard design? How's their 3'' down pipe, compare with ebay 3'' down pipe?
    Here is their link
    http://www.ardesign.org/ARD-27T-Downpipe-Kit_c10.htm
    And, does anyone have a economy choice for the downpipe? looking for something is affordable for now...
    Thx
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Poopcorn View Post
    Here is their link
    Thx
    Modified piggies will be cheapest. ARD used to make stuff but it looks like they're not in business anymore... $375 is dirt cheap but make sure that you'll actually get the product
    - Clint
    Nov 17 2014
    Calgary/AB/Cansda
    Is that meanining this ard design is kinda fraud?? what about the silly rabbit motor?
    I was thinking about getting one from ebay... But I found the silly rabbit.... They seems better than the ard
    http://sillyrabbitmotorsport.com/eng...i-s4-downpipes
    Oct 23 2010
    2004 Atlas Gray A4 Avant
    Cranberry TWP, PA
    SRM downpipes = SSAC
    2004 Atlas Gray B6 Avant, built 2.7T w/ BB K24's on E85
    2005 Touareg 4.2 gas guzzling daily
    2002 Triumph Daytona 955i
    1997 BMW M3 Coupe (sold, sad reacts only)
    Nov 17 2014
    Calgary/AB/Cansda
    Quote Originally Posted by Steve Bassen View Post
    Okay.... any ideas which is better tho? the ssac? or ard 3''?
    I know they are all aftermarket parts.... and the prices are pretty close...
    And btw, what about the x-power downpipe? Are they all same?
    Thx
    Oct 23 2010
    Cranberry TWP, PA
    XS Power = SSAC, as well. They're fine, just don't expect the stainless to stay stainless for too long. I'm blasting and coating mine with Cerakote to keep them from getting surface rust...
    Nov 17 2014
    Calgary/AB/Cansda
    what about putting the heat wrap on?
    Oct 23 2010
    Cranberry TWP, PA
    Cheap stainless shouldn't be wrapped, IMHO... risk of making a corrosion issue worse since it traps moisture in, when the car's not running.
    Aug 31 2014
    United States
    Are you still doing the wiring harness need one
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by ketchup6624 View Post
    yes
    - Clint
    Deactivated Four Rings
    Oct 16 2010
    DavidhogAJ
    https://t.me/pump_upp
    Clint, PM sent for harness. thanks
    Mar 05 2012
    Bucks County, PA
    I am using the 3.0 AC compressor from a B6. I think I used the wrong bracket, but I dont remember which one it was!!!! My AC compressor is not sticking out enough and it is chewing up the belt. Which bracket should I have used?
    2012 Q5 and 2018 Q7
    Aug 15 2015
    Southern Maine
    Hey man, hope you're still checking this thread, I just did a 2.7T swap from an 01' A6 into a 98 A4 2.8, and I need some help with the wiring part, I just realized that my plugs don't match up at all and I was hoping you could either give me some help with how to splice in new connectors to plug in behind the Ecu or even better would be if you could maybe make an adapter or something, this is the last part of my swap and I'm like down in the dumps trying to figure it out on my own, any help at all would be much appreciated!
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by QuattroB5love View Post
    If I get the B5 diagrams I may be able to do something, but you're going to have to swap to DBW at the very minimum, I would have never used an early 98 for this swap.
    - Clint
    Aug 15 2015
    Southern Maine
    I'm going to end up doing a facelift conversion with an S4 body harness and pedal and the entire center console, it will be a pain in the ass but at least it'll be right
    Dec 09 2013
    Spokane, Washington Northwest
    Hello everyone. So I got the 2.7t mounted in to my 2004 A4 and got into the wiring with the auto tiptronic trans. Everything seemed to be too good to be true, until it was time to hook power up and see what happened on the Vag-Com. That's when the thunder and lightning struck. Not good news for me. Being that the TCM is mounted right under the ECM in the cowl on the B6, the communication wires go from one, right into the other. On an Allroad, the TCM is mounted under the seat and the communication wires go from there to the speedo and then to the ECM. The shop that is working on the wiring told me that being that the Allroad TCM is mounted farther away, the speed or wave length of the communication that is sent is different and will not communicate with the 2.7t ECM. I'm in no means a wiring expert but seemed to make sence, just not what I wanted to hear. I'm told the only way to cure this issue is to swap a manual transmission. Seeing if anyone has any ideas or am I stuck swapping the trans also? A 6 speed would obviously be preferred, just not quite in the cards right now. Any ideas would be greatfully helpful. Thank you.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Rlbarlow2 View Post
    Sounds like a load of BS to me, I just don't think they feel like figuring out the wiring.
    - Clint
    Dec 09 2013
    I thought it was weird also. They tell me that everything is fine until the plug the TCM in and all communication is lost. Unplug the TCM and everything comes back up.
    Mar 12 2014
    uk
    clint
    Hi I'm from uk been watching this thread for long time ,is there any wiring info on put a 2003 BES 2.7t into a 2003 1.8T b6 or is the wiring same ason the other 2.7T looms
    Many thanks carl
