Results 1 to 16 of 16
    Veteran Member Three Rings rowdysaudi1's Avatar
    Apr 05 2005
    01 A4 1.8T FWD
    Kabul, Afghanistan
    Lemmiwinks, Ross-tech, etc....
    I saw this on one of the VW forums; they started a page basically explaining what each program does and how to use it. So, if you can - post your knowledge about the software and anything else you can think of that would help us DIY people out...thanks in advance. Also, make any comments if you dont think someones info is right...
    Lemmiwinks:
    Ch01 : Idle Speed Offset
    Adjust idle RPM level
    - Higher number: increase idle rpm
    - Lower number: decrease idle rpm
    Ch02 : Fuel Tweak (Accel Pump); Increasing Loads
    -This channel adjusts a fuel enrichment under load
    -Modulates Throttle Response
    Ch03 : Fuel Tweak (Accel Pump); Decreasing Loads
    -This channel adjusts a fuel enrichment term coming off the gas or decelerating.
    Ch04 : Start Up Fuel Enrich
    Amount of fuel on any start ups?
    - Higher number: enrich the mix
    - Lower number: lean out the mix
    Ch05 : Warm Up fuel Enrich
    Amount of fuel on start ups E.G. on the first start in the morning?
    Ch06 : Lambda Regulation
    Controls how fast ECU adapts:
    - Higher number: faster adaptation
    - Lower number: slower adaptation
    Ch07 : Additive Offset To Speed Limiter
    Controls speed limiter in increments ok 1km/hr
    Ch08 : Secondary Fuel Tweak
    Controls fueling at idle, ussually alters additive fuel trims
    - Higher number enrich the mix
    - Lower number lean out the mix
    Ch09 : Ignition Timing Offset
    Controls timing in steps of 0.75 degrees, all RPM range is altered
    - Higher number advances timing
    - Lower number retards timing
    Ch10 : Primary Fuel Tweak
    Controls fueling on run, ussually change multiplicative fuel trims
    Ch11 : Unused
    Unused
    Ch12 : SEL Scaling (Turbo Cars Only)
    Adjust fueling maps according to boost settings
    - Higher number increase injection period for higher boost
    - Lower number decrease injection period for lower boost
    Ch13 : OFF OFF
    Unused
    Ch14 : Idle Torque Additive Offset
    Controls engine load at idle
    - Higher numbers: spec load at idle is increased
    - Lower numbers: spec load at idle is decreased
    Aditional Information from Revotechnik:
    Adaptation Channer Explanation
    Revo Comparison of Adaptation Channels and Tuning
    Download Lemmiwinks Now from Ecodetuning
    Download Lemmiwinks Now from Unixprohost
    How to:
    1. Place key in ignition, turn to on position.
    2. Attach VagCom 'dongle'.
    3. Bring up Lemmiwinks software
    4. To store original ECU settings Click ON "Read". This reads your current settings.
    5.Adjust settings at will.
    6.Click on 'SET' to connect to the ECU and adapt settings.
    7. When asked to cycle ECU, simply turn it off, then turn the ECU back on.
    8. Enjoy (hopefully) new settings.
    "No Lexus convertible...Infinity only!" - Three Kings
    Apr 05 2005
    01 A4 1.8T FWD
    Kabul, Afghanistan
    wow...you guys dont know, or just dont care? It would help me out...
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    youll find very few b5 a4s run lemmi. A lot of the b5 s4s on aw do as well as the b6 a4s.
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Apr 05 2005
    01 A4 1.8T FWD
    Kabul, Afghanistan
    so what options are we left with? besides the expensive ross tech software.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    What are you trying to use it for? These software should only be used to help the owner fine tune the setup he has.
    I use the lemmiwinks, but only to make changes to my idle speed, startup fuel and timing.
    May 13 2004
    New Jersey
    hey mike did you decrease your start up fuel enrich?
    im having little issue with my J31 and ko4, my afpr is set to 3.5bar and at top end sometimes I tend to hear pinging, but when i check block 032 my average for wot says -18% which is pretty rich, and the 031 at wot indicates 0.84-0.87V, should i increase my CH02: fule tweak(accel Pump), or what do you think shoud i adjust?
    thanks
    Jul 07 2004
    socal
    thanks
    Yes I decreased my startup fuel because I was getting too much fuel and it was a bit harder to start the car. Once I lowered the startup fuel the car would start right away.
    Well your block 032 is for part throttle only not WOT. THis means at part throttle your ecu is pulling out 18% of fuel to keep it in spec. Sounds like your problem at the top end might be just that you have either too much timing or the IAT's might be too high with that boost level. What heat range plug are you running? With the 31 I would run something that is 2 steps colder since it runs very high boost levels.
    Do you have any logs of block 031 at the top end where you hear it ping? If its at .84 at that point your still good and it might just be the issue of the fuel burning too soon because of the high IAT's.
    May 13 2004
    New Jersey
    currently i'm running NGK BKR6e, i ran BKR7E but I killed them in like 2000 miles, I believe due to my running rich issue, is there a way to lower my part throttle a little or should i just leave it that way?
    what is IAT?
    thanks
    Jul 07 2004
    socal
    what is IAT?
    thanks
    IAT = Intake Air Temps
    The J31 does push the K04 to its limits on air flow, so the temps will be pretty high.
    Do you know what your idle fuel trim is on block 032? If it is also rich you can always try playing with the secondary fuel tweak (CH 08)
    Another thing you might want to check is the knock sensor voltage on block 026. If it goes too high the ecu will pull timing. You can always remove some timing with the lemmiwinks (ch 09) but only a little at a time.
    Apr 05 2005
    01 A4 1.8T FWD
    Kabul, Afghanistan
    I havent used any program for anything. But there are a bunch of program defaults on my CPU that I would like to fiddle around with. Any cheap alternative to the ross tech software? if not, which package should I get from their site to do just minor adjustments, (i.e. windows, old vs. new DBW tranny adj., etc.)?
    May 13 2004
    New Jersey
    my idle fule trim fluctuates at about +/- 2% that never bothered me because it always looked pretty adequate and near 0%
    Jul 07 2004
    socal
    Well then I would try to find out what is causing the ping at the top end. Since it doesn't seem to be lean, I would look at the knock sensor readings and go from there. Could just need a little timing off the top to keep it from doing it.
    BTW when you run a higher octane fuel does it still ping at the top end?
    Feb 16 2004
    audi is chit
    rowdy- lemmi doesn't do any of the things you mentioned. only rosstech does. why don't you ask them directly what package you need
    May 13 2004
    New Jersey
    like I said the pinging is rare and if it happens it not really loud but sometimes it's there, you said that i could adjust the timing on the top to keep it from doing it, but if i do adjust Channel 09 wont that alter my entire RPM range?
    I ran 104 octane with my J31R and it ran really smooth
    thanks
    Jul 07 2004
    socal
    thanks
    Yes it will drop that value across the board.
    May 13 2004
    New Jersey
    thanks MIke
