Results 1 to 2 of 2
    DIY subframe bushing
    I had a little trouble finding a reciever to my ball joint service tool to accommodate the large ~3.5" subframe bushing so I figure if anyone else had this issue I post up what worked for me.
    3" PVC pipe adapter w screw in top. I didn't know if the PVC would hold up to the force needed to remove the bushing so I went hand tool the first bushing. After that a 1/2" impact or bigger worked fine.
    Needed:
    3" PVC adapter
    3" PVC screw cap
    Ball joint service tool
    Impact/ breaker and socket
    *after the bushing gets pressed out it might get stuck in the piping, undo the screw top and just tap it out.
    Veteran Member Three Rings mkemk3's Avatar
    Oct 11 2010
    Central MA
    Thanks for posting this !
