Results 1 to 15 of 15
    Mar 27 2012
    Georgia
    Question 1.8T AMB Coolant Circulation problem need HELP!
    Hello i have big trouble with coolant, the water is not circulating well. It happened in winter when my heater was on. Suddenly I felt something like burning smell in the car and the heater started to blow cold air. Since that it blows only cold air. The heater works well only when I am driving on high RPM. First I thought that dirt was stuck in the radiator of the heater, but I removed hoses, started the engine and the water wasn’t spilling out. Only when I was giving a gas, little bit of water was starting to spill out. After that I thought that the problem was in water pump. I changed the pump, but nothing has changed. I still have the same problem. Can anybody help me?
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Sounds like a blocked heater core to me.
    Try searching on here for the post of a kind member took the time to type up with pics included.
    It has all the info u need.
    Guess I'm in a good mood today... Hope others link to this excellent DIY from here too:
    B6 A4 Heater Core Replacement DIY
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Mar 27 2012
    Georgia
    thanks for reply but my heater core is working fine (tested with water not blocked) coolant not circulating normally in whole system and now i burned cylinder head gasket :(
    Jun 27 2011
    Have you checked your water pump? Sounds to me like the impeller broke loose and isn't circulating coolant properly...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 27 2012
    Georgia
    I changed water pump and old one was fine
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    Thermostat?
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Mar 27 2012
    Georgia
    Thermostat is working, opening big circle
    Aug 26 2005
    Quote Originally Posted by lemon View Post
    You may believe the t-stat is working, but it is the only device that could be the cause of the low coolant flow, that has not been replaced yet. The t-stats on our cars have a history of failiing eventually.
    Vorsprung durch Technik
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Thermostat or Head Gasket. John (diagnosticator) knows what I'm talking about. ;)
    Some people say our thermostats FAIL while "open", this is not true. I've seen them fail cracked half-way open--thus preventing coolant from flowing to the heater core properly.
    Jun 27 2011
    My B7's Thermostat failed in that it was fully closed when cold, but opened prematurely. If its not the Water pump, i concur with everyone above that its the thermostat. Get wrenching!
    -CP
    2017 Q7 3.0t
    Established Member Two Rings MTS's Avatar
    Jan 04 2012
    Barefoot Nautique, k5 Blazer
    Austin TX
    What are the engine temps doing? Most obd2 code can read live data, get the temps then make an assessment. Think I would try bleeding air out of the heater core first if engine temps are normal.
    Mar 27 2012
    Georgia
    I have already tried bleeding air out of the heater core, i was reading live data with android device and engine temperature was jumping like 85-125C
    Thank you all for your reply. I am going to check T-stat and change burned head gasket.
    Veteran Member Three Rings POPO's Avatar
    Feb 02 2008
    2001 Chevy Tahoe, 2005 Audi A4, RIP 2003 Audi A4
    Somerset, NJ
    Are you sure you have enough coolant? I had problems getting air out my system after new turbo/water pump install. Today what I did when refilling the system was crack open the nut on the top hard coolant pipe then filled the reservoir. after I filled it, I lifted the reservoir in the air so that the coolant would flow faster into the system. I did this several times until coolant came out of the hard pipe. I topped of the coolant again and after starting up, I had no air in the system and the heat worked after about 2 or 3 mins. Hope this helps
    2005 A4 2.0L Stroker- New South Vent Gauge|034 RSB|2.75" FMIC|GHL 2.5" Catback|PSi Concepts TD05H-20g|PSi Concepts Exhaust Manifold|Turbo XS EWG|Motoza tuned|
    RIP 2003 A4 1.8TQM
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    20 Nissan Rogue ~ 08 Highlander Sport
    SE PA
    I had the same problem with only getting heat a highway speeds. I flushed and bleed the heater core. Still had the same problem. I ended up having the heater core chemical soaked and power flushed. Fixed the problem.
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    I didn't see anyone mention this, but have you checked your coolant flange? When mine leaked I didn't get any heat while sitting still.
    Sent from my DROID RAZR using Tapatalk
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
