Page 15 of 15 FirstFirst ... 5131415
Results 561 to 591 of 591
  1. #561
    May 23 2019
    Perth, WA
    Quote Originally Posted by flyfishing View Post
    Attachment 217107
    Our cars are cousins. Nice mods!
    Haha they are! Mine just has 2 more doors and no chrome. Don't see the RS7 split style grill often!
    Sent from my Pixel 5 using Tapatalk
  2. #562
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    Just lowered KW HAS (purchased through Mops)
    KW HAS had good reviews. I wanted to be able to adjust the height as I did not know what I could have with my wheel setup and wanted to keep my ADS shocks.
    19x9.5 et40 (when initially installed had winter stock rotors on which are out 7mm further et33)
    275/35/19 (summer and winter tires) I like the beefier tires, did not like the stretched look of 255 on the 9.5 wheels and most import I bent rims and cut sidewalls on pot holes with the 255/35. I'll take the 275/35 extra 1/4" sidewall.
    20/25 mm spacers
    My son (three year auto mechanic) and I installed. He did the front and I did the rears. First side took about 6hrs of work. Front took longer than the rear. Second side was 3hrs after we knew what to do and not to do. https://www.youtube.com/watch?v=_NySIblxcB4 covers much of it. Later saw recommendations for lowering the rear subframe as opposed to spring compressors. May have been easier.
    I normally keep it in comfort. Ride is just like stock IMHO! Love it. I need to tweak a couple of the corners. Fender to ground in 26.75-27 f/r. I have a lot of adjustability to go down further but I like where it is at. I do carry people and things. No rubbing. Put over 200lbs in trunk and still good. Heard on tiny scrape this morning this morning going around a corner as I hit a bump. I have a week on it and will let go then adjust again and have my son align at his shop
    2014 Estoril blue Cab Chestnut brown interior
  3. #563
    Sep 28 2010
    NW NC / DE
    Looking good Neil! Excellent wheel/tire fitment, too. Thanks again for your business!
  4. #564
    Veteran Member Four Rings 03TLSinCO's Avatar
    Feb 02 2018
    '16 S5 Prem Plus; '13 Q5 Prem Plus S-Line; '09 Honda Odyssey (The Wife's, in the driveway)
    CO
    Quote Originally Posted by Neil F View Post
    20/25 mm spacers
    Looks nice Neil. How many miles on your ADS shocks? Will consider doing KW HAS springs on my car as well, but unsure when I'll need to do shocks and if the KWs will shorten their life.
    2016 S5 Prem+, Moonlight Blue Metallic/Lunar Silver, Sport Diff, Black Optic Plus, B&O, Adaptive Damping Suspension. 034 Stage 2 ECU/TCU, RS5 grill, AWE S-FLO Intake, 034 X-Brace, 034 Rear Sway Bar, CR-15, Magnaflow non-resonated X-Pipe
    2013 Q5 Prem Plus S-Line, Moonlight Blue Metallic, 034 Stage 1 ECU/TCU
  5. #565
    Jan 13 2017
    marlton/nj/usa
    The car has 120k and off hand I do not know the lifespan of the ADS shocks. Lowering is not going to affect the life of the shock. Really all you are doing is compressing the shock but it is still within it's range of movement.
  6. #566
    Junior Member Two Rings
    Sep 25 2005
    1939 Chevy Pickup
    PA
    anyone have any input on spacers for the stock 19" prestige wheels on the b8 4.2? it is lowered on H&R street springs (not sport). I was looking at 12/15mm. just looking for a little more aggressive look while I wait to figure out what +25mm offset wheels I want.
  7. #567
    Veteran Member Four Rings dbtong's Avatar
    San Jose, CA
    Quote Originally Posted by MUlrich07 View Post
    This might help you.
    https://www.audizine.com/forum/showt...hlight=spacers
    D a v e
    1996 A4 2.8 QM (SOLD)
    2016 S5
  8. #568
    Jan 13 2017
    marlton/nj/usa
    What is the width and et of the wheels you have and what size tires.
  9. #569
    Apr 16 2021
    Montreal
    Can anyone tell me the ideal drop and spacer needed for a 275/30/20 +30 20x10.5'' vossen cvt on a 2013 RS5 aggressive as possible
  10. #570
    Junior Member One Ring
    Apr 28 2021
    Boise, ID
    I’m looking to pickup a set of 20x10 et35 Rotiform RSE’s in Anthracite. Seems like 275/30/20 is the way to for tire size, based on what I’m reading here. Will be adding lowering springs at the same time. Suggestions on which springs to go with and how much drop to achieve this look?
  11. #571
    San Jose, CA
    Quote Originally Posted by Troxzilla View Post
    Search for H&R Sport and see if that does it for you. Definitely NOT the H&R OE.
    D a v e
    2016 S5
  12. #572
    Apr 28 2021
    Boise, ID
    Quote Originally Posted by dbtong View Post
    Yeah the H&R’s were kind of the way I was leaning. I’ve run them before. Just wasn’t sure how far of a drop to go with.
  13. #573
    San Jose, CA
    I have the H&R OE which is only a 1" drop at most so I can say they're not what you're looking for. I prefer the look of the drop of the H&R Sport but I didn't want to have to worry about being too low on this car. I'm old now and I've had my fill of "aw shit" moments with previous cars which were lower. Good luck!
    D a v e
    2016 S5
  14. #574
    Apr 28 2021
    Boise, ID
    Thank you for the info. The sports are 1.3” F and 1.25” R drop so that doesn’t seem too bad.
  15. #575
    Veteran Member Three Rings carrrnuttt's Avatar
    Mar 24 2019
    2013 Audi S5; 2009 Mazda RX-8 R3; 2022 Dodge Durango R/T AWD
    Phoenix, AZ
    Why not coilovers so you can set your drop as you desire?
    2013 Audi S5 Brilliant Black 6-spd Sports Diff
    APR Stage 2 Ultracharged (93 tune) - CPS Cooler - Carbonio Intake
    ECS light flywheel
    Spec Stage 3+ Clutch Kit
    JHM Short Shifter
    034Motorsport Insert Kit - Trans Mount
    • Custom Exhaust
  16. #576
    Apr 28 2021
    Boise, ID
    Quote Originally Posted by carrrnuttt View Post
    I’d rather go that route. However wasn’t really in the budget. Wasn’t planning to do wheels and tires just yet but a couple of my tires need replaced and rather than dump the $ into the stock tires I thought what the heck let’s just do the wheels now.
  17. #577
    Jan 13 2017
    marlton/nj/usa
    KW HAS (height adjustable springs) is 750. I just put them on my S5
    (ask Mops for his price)
  18. #578
    Apr 28 2021
    Boise, ID
    Thank you, I’ll reach out to him
  19. #579
    Senior Member Three Rings pdan's Avatar
    Oct 20 2019
    South Florida
    I ran RSEa for a little while on my A5. 20x10 et 30. Also ran a 275 30 20. I’m lowered on KW V1s, roughy 26” fender to ground if I remember. I’d have to measure again.
  20. #580
    Sep 02 2016
    Are stock struts sachs or bilstein for a b8.5 s5?
    Sent from my SM-G975W using Audizine Forum mobile app
  21. #581
    Apr 30 2015
    2006 Audi 8p A3 , 2005 Audi B7 A4 , 2011 Audi 8T S5
    San Jose, CA
    Did you run any spacers with this set up?
  22. #582
    San Jose, CA
    Quote Originally Posted by nguyenfatman View Post
    Who are you asking? If you already have wheels you can post the specs (diameter, width and offset) and tire size and I'm certain someone on here can answer your question.
    D a v e
    2016 S5
  23. #583
    Senior Member Two Rings LGHT's Avatar
    Jun 07 2018
    CA
    20/25 mm spacers
    Nice setup I run the same KW HAS and tires on my A4 Avant. Since it carries the kids in the back I wanted something better than stock, but didn't want to give the kids concussions over ever bump. Very happy with the ride!
  24. #584
    Jun 07 2018
    CA
    Quote Originally Posted by BirdsA5 View Post
    Attachment 159437
    Thoughts on these coilovers? Anyone running them?
    Did you get those? My audi guy said to get this for the 13 A5 Cabriolet I'm working on as it's a good balance between budget and performance so I'm also considering them.
  25. #585
    Jan 13 2017
    marlton/nj/usa
    Quote Originally Posted by LGHT View Post
    You run the Avant kit I assume (not the S4/S5 kit). I have read in a number of posts that people found the S4/S5 springs sag and loose height. A number of posts indicate to get the KW Avant springs which have a higher spring rate. With that said, after a few months, I swear my rear has come down a tad. I know when I installed, I had the f/r fender to ground height the same. Forgot what was but last I measured, my ass was a littler lower. I have plenty of adjustment and will raise it up some when I change to the A/S tires for winter.
  26. #586
    Established Member Two Rings fivefan's Avatar
    Nov 23 2017
    2015 S5
    virUS
    For a B8.5 S5, which springs would create a more level stance: H&R OE or Eibach Pro?
    Just need a mild drop with no reverse rake.
    I do not have adaptive dampers.
    2015 Daytona S5 coupe / S tronic / quattro w sport diff / tech pkg / black optic pkg
    Unitronic Stage 1+ 93oct ECU & Stage 2 DSG / Ross-Tech VCDS / RSNav / Michelin PS 4S 265·30ZR20 / 20x9 RS5 rotors / Michelin PS A⁄S 3+ 255·35ZR19 / 19x9 AudiSport rotors / StopTech lines, pads, cryo drilled rotors / KW HAS / Bilstein dampers / 034Motorsport arms / ECS shields / AWE intake / deAutoLED fogs / SunTek Ultra / Opti-Coat Pro / STEK DYNOflex
  27. #587
    Established Member Two Rings Promartinez90's Avatar
    Apr 16 2016
    Tri state
    Guys,
    I recently purchased S8 Rotor wheels for my A5 and need to stretch the tires. Right now the tire size on the wheels are (275/35ZR21)
    Does anyone know how many sizes down I can go or set up I can run for the stretch look ?
    Please help !
    Rim size 21X9
  28. #588
    San Jose, CA
    Quote Originally Posted by fivefan View Post
    My H&R OE's sit a little lower in the front than the rear.
    D a v e
    2016 S5
  29. #589
    Established Member Two Rings Boston RS5's Avatar
    Sep 13 2017
    Mansfield, MA
    Quote Originally Posted by Bartprim View Post
    Hi all, I have stock 19x9 ET33 rotor wheels on my lowered (KW) sportback (100mm clearance) but am not happy with the stance, so seeking some guidance on spacers.
    Looking at a few posts already I'm seeing a lot of coupes go for 20F/25R or 15F20R. Anyone know what is best for the sportback? I don't want the wheels to poke at all (parking) but I feel they are a bit lost in the arches atm. TIA
    Sent from my SM-G960F using Tapatalk
    Glad I'm not the only one who only parks in end spots and says as far away from the line as possible. Nice ride.
    2013 Audi //RS5
    Daytona Grey Pearl -- Capristo exhaust | 35% Pinnacle F1 ceramic tint | Signature SV302S 2 piece wheels - 20x10.5 et 27, 20x10.5 Michelin Pilot SS | Xpel Ultimate partial bra | Carbon Fiber Mirror Caps | Blacked Out Badges | Red Calipers | 380mm JHM front rotors | MMI | Driver pack | Stage 2
  30. #590
    Mar 14 2022
    California
    2017 B8.5 S5:
    Air Lift Performance 3H system
    034 Motorsports Stage 2+ tune
    034 Lightweight performance rotors and pads
    Miltek active valve control catback exhaust
    I am interested in hearing from anyone that is running this system in their B8/B8.5 with regard to front and rear bag psi and damping adjustments.
    Thanks
  31. #591
    Sep 20 2022
    Colorado
    Need Help
    Purchased Megan racing euro series coilovers and springs, having an issue with front install. Confused on how to put on oem top mount
