Page 4 of 66 FirstFirst ... 234561454 ... LastLast
Results 121 to 160 of 2601
  1. #121
    Sep 02 2005
    Montreal
    Quote Originally Posted by nicksena View Post
    Ill get some profile shots this week to see the flush fitment. I ended up going with the 35 profile cause the roads in updstate NY suck and I'd be pissed bending a rim and shelling ou another $600 between tire and rim. Not a fan of the whole "stretched" look.....doesnt seem right to me.... get tires that fit lol. The black makes the rims look alot smaller I think, although I really like how the black plays with the rest of the car. I planned on getting them powder coated gunmetal, but figured I should put them on and see how the black looked while I had the chance. Maybe springtime I'll switch it up.
    Your tires are nearly 6% larger in diameter than stock. Not only does that compromise the functionality of ABS/ESP, it also technically voids the warranty on those components and anything related to them. But since the road worthiness enforcement in North America is a joke, and people can get away with all kinds of stupid shit done to their vehicles... nevermind.
  2. #122
    May 07 2012
    2000 accord coupe, jdm f20b, t3/t4 turbo
    Hudson Valley NY
    My warranty expired at the end of September so I dont have to worry about that but thanks for the info. Didn't know the 5.6% diff compromises ABS and ESP. Not sure what you meant about "road worthiness enforcement" though. BTW, sick default..... LED's look so nice on ibis at dusk
  3. #123
    Sep 02 2005
    Montreal
    It's just that cops don't really seem to enforce stuff that gets you "grounded" by the TUV in Germany or other European states with strict rules concerning what is allowed on public roads... Tires over 3% larger in diameter are an example. ESP relies on ABS and ABS relies on several factors and real time measurements, one of those measurements is forward speed, and part of calculating forward speed is one constant in the formula, which is the tire diameter, the car basically assumes your tires are 26.1" in diameter, plus/minus a small percentage. Oversizing your tires will fool ABS, which can invoke undesirable operation of both ABS and ESP under certain conditions like emergency maneuvers.
  4. #124
    May 07 2012
    Hudson Valley NY
    Gotcha, good to know. Maybe I should stay away from the supercharger and keep driving this conservatively then :)
  5. #125
    Aug 29 2012
    Norway
    Quote Originally Posted by kevintilokee View Post
    Did you do any fender work to get such low offsets?
    No nothing, in front there is no problem , takes on the screw on full lock and bumpy road at low speed. In the back I rubb the innerfenders outside but I am not rubbing against steel, and its only in big dumps and/or with people in the backseat. No problem using it daily. Will take a checkup this week as Im going to change to wintertires.
  6. #126
    Established Member Two Rings omnupe's Avatar
    Jul 20 2010
    2007 PB RS4 - Sold
    Charlotte
    I guess I'll go...
    DPE SP-SC5
    20x10 All Around
    Phantom Black Powdercoat
    275/30/20
  7. #127
    Registered Member One Ring Phantom X's Avatar
    Oct 21 2012
    Charleston SC
    I am having a hard time understanding why so many people are running staggered wheel setups on an AWD car.
    2010 Evo X 800whp
    2012 Scion tC RS 7.0
    2010 F-150
    Hopefully an Audi in the lineup soon.
  8. #128
    Sep 02 2005
    Montreal
    Quote Originally Posted by Phantom X View Post
    Because the torque split is not 50:50, and suspension mods with aggressive wheel alignment can, for the most part, dial out any extra understeer.
  9. #129
    Sep 28 2010
    NW NC / DE
    ^Idk, some really like the look. Doesn't really matter if you are not driving the car hard/tracking. Even so, if you keep the specs tight its not a huge deal.
    Looks great omnupe! Someone is familiar with detailing. That is the best showing of BB I have seen since my old A4;)
  10. #130
    Oct 21 2012
    Charleston SC
    Ok, wasn't clear on the split.
    2010 Evo X 800whp
    2010 F-150
  11. #131
    Sep 17 2012
    Santa Clarita, CA
    +1. Regardless of the front/rear torque split, the car carries vastly more weight over the front axle. There is absolutely no justifiable reason from a handling perspective to run a staggered wheel/tire combo with larger rubber in the back.... Unless you want more under steer ;)
    In fact a reverse stagger setup like Audi offers on the RS3 would be likely better than a square setup to encourage more neutral handling. That the car handles as well as it does is a testament to the chassis engineers and advances like the sport diff. All that is there to overcome the inherent understeer that front heavy cars possess.
    While I recently bought an S5, I own several Subarus and work for a performance tuning shop specializing primarily in Subarus. We have prepped and built numerous track cars so I am rather familiar with the dynamics of front heavy AWD cars =p
    I can appreciate the aesthetic appeal of a staggered wheel fitment. As long as you understand that you will induce more at the limit understeer when selecting that fitment that's fine with me. If you don't drive hard you won't even notice the change in dynamics and can just appreciate the look. I'm about form following function so I have a non staggered set of Forgestars on order.
  12. #132
    Jul 25 2011
    Quote Originally Posted by omnupe View Post
    I guess I'll go...
    DPE SP-SC5
    20x10 All Around
    275/30/20
    looks amazing. Always a fan of those rimzes.
  13. #133
    Feb 04 2010
    Jeddah, Saudi Arabia
    I guess I'll go...
    DPE SP-SC5
    20x10 All Around
    275/30/20
    nice! got the same setup but brushed
    Instagram: @TheDapperDriver
  14. #134
    Jul 20 2010
    2007 PB RS4 - Sold
    Charlotte
    Thanks Mops! I can't take credit for the detail. I took it to a local guy here in Charlotte who did a phenomenal job, I just try to use the 2 bucket method and take my time hand washing in between details. Oh, and she is Phantom, not BB.
  15. #135
    Jul 20 2010
    2007 PB RS4 - Sold
    Charlotte
    Quote Originally Posted by bader.abbas View Post
    Bader,
    That is how I had them originally as well...but decided to color match them...
  16. #136
    Sep 28 2010
    NW NC / DE
    Nice, yea a few extra steps and a little bit of time makes all the difference. One thing I always try to do is rinse the car really well, then move on to the wheels, tires, wells etc and let and leftover dirt/debris soften before I touch the paint. You are located in Charlotte? I am about 70 miles away if so.
  17. #137
    Jul 20 2010
    2007 PB RS4 - Sold
    Charlotte
    Yup, Uptown!
  18. #138
    Sep 28 2010
    NW NC / DE
    Nice, myself and another forum member JOS4AUDI from Charlotte get together about once a month and take a day and go drive some nice roads. In fact, he is coming up this weekend and we are spending the day in the Boone, Blowing Rock, Linville areas for pics and driving. Let me know if you ever want to get to together. I often come to Charlotte for C&C and other gtg's.
  19. #139
    Jul 25 2011
    Bader,
    ah I remember your car from the detailing section, nice purchase that car with all the mods right??
  20. #140
    Oct 25 2012
    Charlotte NC
    Vossen CV3's
    20x10.5 all around
    H&R 20mm spacers in rear, 10 mm up front
    H&R Race Springs, 2" up front - 1.5 in rear
    .... AWE Exhaust
    https://sphotos-b.xx.fbcdn.net/hphot...75294527_n.jpg
    https://sphotos-b.xx.fbcdn.net/hphot...02721636_n.jpg
    https://sphotos-a.xx.fbcdn.net/hphot...73433708_n.jpg
    I dont know how to put them in the thread, sorry... but enjoy!
  21. #141
    Oct 25 2012
    Charlotte NC
    Let me know! I am in Charlotte!
  22. #142
    Senior Member Two Rings Yakk's Avatar
    Apr 13 2012
    2012 Ram 2500 6.7L Turbo Cummins Diesel
    Calgary, Alberta, Canada
    Quote Originally Posted by TraceNYoface View Post
    Here ya go:
    '13 Suzuka Grey RS5, Titanium trim pkg, carbon interior, 20" Rennen R10X concave wheels (summer), Capristo exhaust, KW V3's, carbon side mirrors, carbon dash trim__Previous: '07 Daytona Grey RS4
    My pics & vids link Instagram: Yakk_k
  23. #143
    Sep 02 2005
    Montreal
    Hmm, think I want five spoke wheels for next season... Gonna start looking for trades, my Y spokes +300, I reckon that should get me something good
  24. #144
    Jul 25 2011
    You will be surprised. ;)
  25. #145
    Sep 28 2010
    NW NC / DE
    Welcome to come ride with us this Sunday. How old are you, married, are you hot? Lol, playing. I am Ben and JOS is Jeremy and we both have women friends.
    http://charlotte.carsandcoffee.info/
    Hitting this next on 11/3.
  26. #146
    Sep 02 2005
    Montreal
    That was... subtle.
  27. #147
    Sep 28 2010
    NW NC / DE
    LMAO.
  28. #148
    Jul 20 2010
    2007 PB RS4 - Sold
    Charlotte
    Looks like I am going to miss out this time. I will be out of town for 2 weeks. Let me know next time you guys go out and I will definitely join!
  29. #149
    Jul 20 2010
    2007 PB RS4 - Sold
    Charlotte
    The guy who detailed my car for me posted up pics. I didn't purchase my car with all the mods, I bought it bone stock and completed the transformation one piece at a time!
  30. #150
    Sep 28 2010
    NW NC / DE
    Nice, will let you know for sure. Jeremy lives in Ballentine off Rey Rd. You could follow him in.
    Only way to do it
  31. #151
    Oct 13 2012
    Australia
    Quote Originally Posted by Yakk View Post
    Here ya go:
    What are the specs on these Vossens?
  32. #152
    Apr 13 2012
    Quote Originally Posted by RS5 LE View Post
    Just to be clear, I posted those for "TraceNYoface" as he was having issues getting pictures into thread. His initial post was 2 posts above the pictures.
    From his post:
    Vossen CV3's
    20x10.5 all around
    .... AWE Exhaust
  33. #153
    Oct 13 2012
    Australia
    Vossen CV3's
    20x10.5 all around
    .... AWE Exhaust
    Looks very nice. What size tyres are you running?
  34. #154
    Aug 29 2012
    Norway
    Winter setup:
    OEM RS5 silver
    20x9 et 26
    275/30/20 Dunlop wintersport (tried with 20mm spacer rear , but that was a no go )
  35. #155
    Jul 25 2011
    Looks amazing.
  36. #156
    Jul 07 2009
    Lebanon
    SOLD: 2010 A5
  37. #157
    Sep 28 2010
    NW NC / DE
    Looks really good, Wah! Love the second pic.
  38. #158
    Senior Member Two Rings tenbosch's Avatar
    Sep 08 2012
    Northwest NJ
    Wah - Love the pics. I'm hoping to pick up a set after the new year. Looks fantastic!
    2013 A5 P+ Phantom Black on Black
  39. #159
    Veteran Member Four Rings flatsick's Avatar
    Oct 25 2012
    991 Porsche 911
    Middletown, Delaware
    Re: *** Official B8 A5/S5/RS5 Aftermarket Wheel Gallery ***
    this is gorgeous
  40. #160
    Sep 28 2010
    NW NC / DE
    Yes it is Check his link.
