Here are the 5 wires assigment that I've found. From the sensor side connector.
Pin6 (Red wire) = (I) pump
Pin4 (White wire) = Heater-
Pin1 (Black wire) = Voltage supply
Pin3 (Gray wire) = Heater +
Pin5 (Yellow wire)= Pump circuit ( that adds or remove oxygen from the O2 ) correct things...
Pin2 is dead end at the other side of the connector. (used to loop the calibration resistor with pump)
Source =http://www.megamanual.com/PWC/wire.htm
Remember. Never put a multimeter probe at other pins then heaters. Heater check is the purpose of this thread.
Hopefully that will help someone in the future.
