hi guys i am the owner of audi a8 yea 2008, i have some errors codes but the one that it's killing me is the one of auto hvac .i discovered today that under driver sit (on right side) the blower is not working mybe somebody can help me with this errors code
Thursday,16,June,2011,06:37:41:10074
VCDS Version: Beta 11.3.0
Data version: 20110601
Other codes
Monday,20,June,2011,06:24:20:10074
Address 34: Level Control Labels: 4E0-910-553.lbl
Control Module Part Number: 4E0 910 553 K HW: 4E0 907 553 H
Component and/or Version: LUFTFDR.-CDC H07 4590
Software Coding: 0015510
Work Shop Code: WSC 02313 785 00200
VCID: 2B51039FF620
2 Faults Found
01487 - System Function Test
008 - Implausible Signal - Intermittent
Freeze Frame
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 96510 km
Time Indication: 0
Date: 2012.04.16
Time: 16:39:40
01398 - Signal Conductor for Central Locking; Doors Open
004 - No Signal/Communication - Intermittent
Freeze Frame
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 151
Mileage: 96510 km
Time Indication: 0
Date: 2012.04.16
Time: 16:39:49
Monday,20,June,2011,06:24:52:10074
Address 52: Door Elect, Pass. Labels: None
Control Module Part Number: 4E1 910 802 B HW: 4E2 959 801 F
Component and/or Version: Türsteuer.BF BRM005 0180
Software Coding: 0028462
VCID: 204BE4B38FE6
1 Fault Found
01482 - Motors for Central Locking
007 - Short to Ground - Intermittent
Freeze Frame
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 0
Reset counter: 146
Mileage: 96384 km
Time Indication: 0
Date: 2012.04.16
Time: 09:55:26
Monday,20,June,2011,06:23:47:10074
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Control Module Part Number: 4L0 910 468 A HW: 4L0 907 468 B
Component and/or Version: J533__Gateway H06 0071
Software Coding: F5F99F7F20028C00
VCID: 2D550D87C834
2 Faults Found
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 146
Mileage: 96447 km
Time Indication: 0
Date: 2012.04.16
Time: 11:52:20
01310 - Level Control System Control Module (J197)
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 96510 km
Time Indication: 0
Date: 2012.04.16
Time: 16:38:42
Monday,20,June,2011,06:25:27:10074
Address 5F: Information Electr. Labels: Redir Fail!
Control Module Part Number: 4E0 035 670 B HW: 4E0 035 670
Component and/or Version: H-BNT-EU H65 0047
Software Coding: 010101000000D3EF40000305FF7F00030000
Work Shop Code: WSC 00216 210 81315
VCID: 204BE4B38FE6
3 Faults Found
03276 - Please Check Software Version Management
000 - -
Freeze Frame
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 96281 km
Time Indication: 0
Date: 2012.04.13
Time: 09:29:05
Freeze Frame
Voltage: 14.00 V
Freeze Frame
Fault Priority: 5
Fault Frequency: 1
Reset counter: 146
Mileage: 96447 km
Time Indication: 0
Date: 2012.04.16
Time: 11:52:04
Freeze Frame
Voltage: 12.60 V
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame
Fault Priority: 6
Fault Frequency: 4
Reset counter: 158
Mileage: 96719 km
Time Indication: 0
Date: 2012.04.17
Time: 16:53:16
Freeze Frame
Bin. Bits: 00001000 01000000
Bin. Bits: 00000000 00000000
Monday,20,June,2011,06:26:26:10074
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Control Module Part Number: 4E0 910 181 C HW: 4E0 915 181 C
Component and/or Version: J0644 BEM H12 0550
Software Coding:
Work Shop Code: WSC 00216 210 91058
Additional Info: 4E0915105A von VA0 3809100862
Additional Info: Geraet 91058
VCID: 204BE4B38FE6
1 Fault Found
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 159
Mileage: 96514 km
Time Indication: 0
Date: 2012.04.16
Time: 23:11:08
PLEASE HELPPP
Address 08: Auto HVAC Labels: None
Component and/or Version: KLIMAAUTOMAT 017 0050
Software Coding: 0018449
Work Shop Code: WSC 02311 785 00200
VCID: A95D79977CDC
1 Fault Found
00066 - Right Rear Footwell Heater (Z43)
015 - Cannot Be Tested at this Time - Intermittent
Freeze Frame
Fault Status: 00101111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 158
Mileage: 96758 km
Time Indication: 0
Date: 2012.04.18
Time: 06:31:52
Freeze Frame
Voltage: 13.80 V
