Page 1 of 7 123 ... LastLast
Results 1 to 40 of 268
    Jul 14 2009
    Pasadena
    How to LED your car the eff out
    Update as of 1/2014
    the current best LEDs are as follows
    LED License plate bulbs
    R'dash is still king (can be bought from ecs or drivtech)
    http://www.ecstuning.com/Audi-B6_A4-...ate/ES1899488/
    LED interior
    brightest kit is still britewerks/drivtech
    http://www.drivtechonline.com/LED_In...edan-avant.htm
    LED reverse lights
    bright is now britewerks/drivtech
    http://www.drivtechonline.com/Audi_A...ext-rev-b6.htm
    Ebay LED city lights
    http://www.ebay.com/itm/130893016563...563%26_rdc%3D1
    IG: @matthewee
    Veteran Member Three Rings Unleaded20T's Avatar
    Mar 27 2008
    Ducati Streetfighter V4S
    Allen, TX
    Pics...! :)
    [Current] 22' S6 | Daytona Gray | BO | Prestige
    [Sold] 21' S5 SB | Glacier White | BO | Prestige
    [Sold] 19' SQ5 | Ibis White | Prestige
    [Sold] 2016 A6 | Moonlight Blue | 3.0T P+
    [Sold] 2011 A6 | Black | Prestige
    "If everything seems to be under control, you are not going fast enough." - M.A.
    Veteran Member Three Rings A4SUM's Avatar
    Mar 03 2004
    Quote Originally Posted by Unleaded20T View Post
    Pics...! :)
    x2
    2004 B6 Black A4 1.8t | 2001 B5 Casa S4 | 2000 B5 Silver A4 1.8t
    Jul 14 2009
    Pasadena
    ask and ye shall recieve
    IG: @matthewee
    Jul 14 2009
    Pasadena
    my sonic tuning kit shall be up for sale shortly
    IG: @matthewee
    Veteran Member Three Rings TheKid23's Avatar
    May 26 2011
    PA to IA
    Website tries to add a resistor to the reverse lights, is it needed or not?
    Owned
    Jul 14 2009
    Pasadena
    Quote Originally Posted by TheKid23 View Post
    not needed as I have no errors
    IG: @matthewee
    May 26 2011
    PA to IA
    Guess I should also specify that I'm a B7 A4, I don't know if that would make a difference though. It's the same bulb.
    Owned
    Jul 14 2009
    Pasadena
    i dont believe it makes a difference.
    IG: @matthewee
    May 26 2011
    PA to IA
    Perfect, I'm in for those. I'm one of the few around here that likes some tint on tail lights, so these should really shine through.
    I'd also be interested in some brighter brake light and signal bulbs for the tail lights. Couldn't find anything on iJDM for the 5007 bulb, looks like the rear turn signal is the same 7506?
    Owned
    Jul 14 2009
    Pasadena
    These shine clearly through my 5% window tint and im sure they will cut through your tail lamp tint.
    I would give them a call they have pretty much anything you need just tell them what car you have...the key however is to tell them it must be error free
    IG: @matthewee
    May 26 2011
    PA to IA
    Yea, I'll keep searching around. You have a promo code?
    Owned
    Jul 14 2009
    Pasadena
    i believe its "fool". it changes rather often but there is always one
    IG: @matthewee
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    I'm a fan of LEDs too. Entire rear tails are all LEDs (Depo LED tails w/ LED reverse, turn signals, and rear fog lights). Have you replaced the front and rear turn signals? If so, what did you use for the front turn signals? I also have ecodes, and the LEDs I use for the rear turn signals won't even light up for the front turn signals.
    USP CLUB MEMBER #34
    Veteran Member Three Rings foley803's Avatar
    Sep 29 2011
    is the outdoors
    San Antonio, TX
    While we're on the subject has anyone found a license plate bulb that is just whiter, but not too much brighter than the OEM bulbs?
    I think the Ziza and racing dash ones are a bit bright for my taste. I don't like to draw too much attention to myself (call me anti-social).
    -Rich
    "Because magic, and science, and learning books" -Dan[FN]6262
    Mar 03 2004
    That look really good Matt! Nicely done =]
    Senior Member Three Rings PurduinaM3's Avatar
    Jul 13 2010
    SQ8 S5 M3 Q7
    White Plains, NY
    Thanks for the write up and pics. 'Fool' doesn't work, but if you could get us an updated discount code that would be great!
    Sep 29 2011
    is the outdoors
    San Antonio, TX
    GOJDM gets you 10%. As much as is pains me to type that...
    -Rich
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    I want some brighter than stock tail light bulbs. I bought turn signals and brake lights off of ebay and both are more dim than the stock bulbs. Any ideas?
    Established Member Two Rings Zaknull's Avatar
    Mar 09 2012
    05 A4 1.8T
    Quote Originally Posted by evo_ski View Post
    I found your problem.
    Mar 15 2010
    Bothell
    Lol, I know they were cheap as hell so I figured I would give it a shot. All in all I am down $10 for each set, so not much to worry about.
    Mar 09 2012
    05 A4 1.8T
    i was just joking with you.
    Mar 15 2010
    Bothell
    Haha I know, I knew it was a bad idea after I bought them.
    Mar 27 2012
    02 A4 1.8T Quattro, 03 YZF 600R, 02 Isuzu Trooper
    Seattle WA
    "like"
    Jul 14 2009
    Pasadena
    Quote Originally Posted by foley803 View Post
    well sonic tuning has like three different levels of brightest for the plate lights check out their group buy thread
    IG: @matthewee
    Jul 14 2009
    Pasadena
    Quote Originally Posted by CyberPMG View Post
    i have not used LEDs for the turn signals because I am running stealth bulbs i am sure i will change them to LEDs and when I do itll be on here
    IG: @matthewee
    Jul 14 2009
    Pasadena
    thanks for that they change like very month if you are local to socal you can just go in and they will give you the price with the monthly discount
    IG: @matthewee
    Jul 14 2009
    Pasadena
    youll have to pay to play
    IG: @matthewee
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    According to Joey Cucarro (old B6 S4 guru) this can be modified using VAGCOM. Brett, I have a full cable now so let me know if you want to give it a try.
    Increase Tail Light Brightness
    Here we can increase or decrease the brightness of the rear taillights, brakes, and foglights.
    From the start screen hit SELECT under Select Control Module
    You will now be taken to a list of the control modules present in your car. For this modification we are interested in 09- Central Electric.
    Once in the Open Controller select Adaptation-10.
    You will now be taken to the adaptation menu for the Central Electric module. In the Channel section you can select Channels 02, 03, 04; all of which control brightness of each component. Once you type in the value you want, hit READ.
    After picking a percentage of brightness, hit TEST. Next hit SAVE. The coding will then be stored. Finally hit DONE GO BACK.
    Sep 29 2011
    is the outdoors
    San Antonio, TX
    Quote Originally Posted by itsmatt33 View Post
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    i want your seasts.
    Mar 09 2012
    05 A4 1.8T
    Quote Originally Posted by PNW Avant View Post
    oh how i wish i knew someone with a vag com...
    I'm pretty sure I love my Audi more than my girlfriend.
    No I know I do.
    www.instagram.com/zaknull
    Dec 18 2011
    Colorado Springs
    Nice find on the LED Reverse lights!!
    Just bought a said...$40.** shipped!!
    20% tint, cant see shit out the back.
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    bright ass reverses ftw.
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    Dec 19 2007
    York, PA
    you guys pay way too much for these led kits and conversions...$17 for the h6w le'ds with built in resistors? christ man, i got a pair for $3 and the resistors are less than $1....
    there are secrets of the internet you must find to purchase things like this.
    Jul 14 2009
    Pasadena
    Like I said I didn't want to cut any wires to splice in led resistors
    Active Member One Ring revo staged's Avatar
    Feb 22 2011
    Colorado
    Nice Interior!!
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    Looks nice. On my to do list for the summer. MMMM Recaros
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Senior Member Three Rings A4QuattroBum's Avatar
    Dec 05 2010
    '05 Brilliant Black B6 A4 1.8TQ
    San Diego, CA
    In the immortal words of the old Irish dude in the Boondock Saints, "shit, fuck, ass" those are some bright LEDs! Looks like it's time to step my game up and upgrayedd. :thumbup:
    "that ass is chewing gum........and I like it." -the sheriff
    My other passion... http://www.youtube.com/ImMikeTrollston
    Veteran Member Three Rings J Boy's Avatar
    Aug 11 2011
    West Covina, CA
    these might not be as bright, but i got my LED kit (includes every interior light except for the red on the doors, but includes license plate) for $50 from krautoparts . com
    K-Sport Kontrol Pro Coilovers, REVO Stage 2, Genesis 380's, 710N, PODI Gauge, 2.5" Testpipe, 3" Exhaust, Check Engine Light...
