Results 1 to 8 of 8
    Veteran Member Three Rings hazard860's Avatar
    Aug 22 2011
    1984 gti, 2001.5 s4 (stg3)
    Lebanon, CT
    ABA 440cc bosch injectors on AEB????
    my friend has some bosch 440 injectors from his ABA build (that never happened) and will pretty much give them to me. would they work on my AEB motor??
    Thanks
    Senior Member Two Rings back183's Avatar
    Apr 03 2008
    2007 jeep grand Cherokee
    Littleton,CO
    Are they the older bosch green tops?
    Established Member Two Rings Steve Chicago's Avatar
    Mar 19 2009
    2000 Jeep Grand Cherokee Laredo
    Chicago, Illinois
    440 injectors will work on your AEB if you have a turbo big enough to deliver that much additional airflow. You'll also need a tune written to match that turbo and those injectors to an AEB engine and a list of supporting modifications.
    Simply dropping in larger injectors on an otherwise stock engine won't help at all. In fact it will hurt performance. The fueling, air delivery and engine management system need to match each other.
    Aug 22 2011
    Lebanon, CT
    i have a franken turbo and i'm getting a custom tune, so i jest need to know if they plug in.
    Feb 26 2010
    NOVA
    i believe that is what was in my AEB when i got it.
    Aug 22 2011
    Lebanon, CT
    could you define older please?
    Feb 26 2010
    NOVA
    old
    new
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    New are EV14(Uscar) plugs so you will need an adapter plug to use them on the car and are a skinny body. The older Bosch injectors are a EV1 plug(jetronic) and are a fat body, they are the same plug that is on the stock harness. The EV14 and some of the newer Bosch EV1 racing injectors are by far the best injectors on the market at this time, that is what everyone uses to modify to a single spray.
