I have a 2012 S4 Prestige with the 19 inch peelers, with ADS and ACC. I took my car to a local reputable shop with a very good alignment tech. They have one of the latest brand new Hunter laser alignment racks (sorry I don't know the model though) that the wheel mounts clip to the tire and not the rim (never seen this before on older racks).
The rack walks the tech through the process of performing the manual part of any typical aligment, adjust camber, then toe... adjust the front then the rear.. etc. All of that went fine and well. Then the rack (because my car has ADS) instructs the tech to perform a steering wheel calibration.
This process apparently does not complete successfully, and now I have multiple MILs on. There is a steering fault and a sport rear differential fault. ESP is also disabled. So now my car is at the dealership to calibrate the steering wheel and hopefully remove the faults. Also, as it turns out, ACC also has to be calibrated from just simple toe changes, and can only be performed at the dealership as Audi has not released the equipment to 3rd parties to perform it yet (per the Hunter regional rep).
I've bought the shop manuals from the erWin site for our cars, I've looked at the "basic setting" setup for the steering wheel. Everything tells me that the rack should have been able to do this successfully (the rack even displays verbiage word for word from the Audi manuals and even the VAS tools to be used). At the moment, I'm left wondering... what and how am I supposed to get an aligment on this thing? I've done it often in the past for my other cars...
So, have any of you had your S4 with ADS (and maybe ACC).. hopefully someone with a 2012.. successfully aligned, and what was your experiance? Could the alignment shop do it? Did you have to go to the dealer? Do you have any advice for me (other than telling me i shouldn't have got the ADS and ACC options :P)?
Thanks for any help!!
