OK, here's a good "too dumb to ask" question. Where, pray tell, the hell is our firewall? I think the firewall is the bit that separates the engine from the battery. It's the metal that has gromets through it to allow the brake booster vacuum line to pass. It ahead of the battery, behind the engine. It's the bit you keep hitting your hand on when you're trying to access the back of the cylinder head. It is NOT, behind the battery. It does not separate the battery from the passenger compartment. Am I correct?
Why do I ask? SCCA says I have to do my best to prevent flames from intruding into the passenger compartment from the engine bay. I think that means ensuring the thing that I think is the firewall is intact and the grommets there are functioning well. It is, and they are. I do not think that means I have to seal off the HVAC filter inlet, or the ECU entry point.
