Page 1 of 384 1231151101 ... LastLast
Results 1 to 40 of 15348
    Senior Member Three Rings westie180's Avatar
    Mar 01 2011
    Indy
    Lightbulb questions you thought were too dumb to ask
    i've been seeing more and more posts around here telling people to search when they ask questions. well, in response to that, i'm starting a type of thread that existed in every section of saabcentral back when i regularly read and posted there. the whole thread is dedicated to questions about your B6 you simply thought were too dumb to ask. so here is the place to feel free to ask anything you want about your car. there is no question too dumb. well...within good limits. we don't need questions like "how do i start the engine?" if you read on here and see a question you know the answer to, go ahead and answer it, even if that means posting a link to another thread. sometimes searching just doesn't pull up information that really offers good answers, and straight up asking someone else ends up being better in the long run. may it be a wealth of information for us all.
    i'll start with an opener:
    it's one i've searched for both here and with google. is there any way to remove slack from the hood release cable? mine's just barely pulling enough to pop the hood, and i'm concerned it'll cease to work altogether.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Interesting question. Here's a potential cure. Fabricate a ¼" spacer to insert between the end of the outer cable housing and the outer cable housing bracket under the hood. This will reduce the handle pull by ¼". If you need more just make a longer spacer.
    Oct 09 2008
    Good idea. The spacer would probably work well.
    I have one,
    The lock/handle latch for the rear seat folding mechanism seems to be broken or stuck. So I cannot fold down that section of the seat. The handle moves freely as if the seat were unlocked and when i lock it then the handle locks up like it should. How does that latch mechanism work so I can get the seat folded down and replace it?
    Thanks
    The Awesome™
    Senior Member Three Rings Barker29's Avatar
    Jan 19 2010
    2018 VW Atlas
    South Jersey
    Brilliant thread!! My seat latch is broken too but my doesn't latch so im not much help
    Dec 28 2006
    Western Maryland
    This is for an Avant but it should be applicable for the sedan: Clicky click
    Jan 19 2010
    2018 VW Atlas
    South Jersey
    Maybe we should rename this thread "stupid questions for old guy"
    Dec 01 2010
    Connecticut
    my front ashtray won't stay closed. Anyone fixed that?
    Mar 01 2011
    Indy
    Quote Originally Posted by Barker29 View Post
    that is why old guy is the best.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by MoroBlueB6 View Post
    Get some radio removal tools and remove the radio so you can remove the ash tray. You will probably find some coins or other trash has fallen behind the ash tray door preventing it from closing enough to latch.
    Dec 05 2007
    Try silicone spray on the closing/opening mechanism. Or do like me, and hold off forever on picking up a used one for cheap and swapping it in. This post actually just gave me incentive to source a cheap one. Thanks!
    Oct 09 2008
    Thanks for the link! Much appreciated.
    The Awesome™
    Aug 26 2005
    Quote Originally Posted by JoshDub View Post
    I have one,
    Thanks
    The rear seatback latches work ~the same way as the door latches. The latch pin must be adjusted so that the pin is 90 degrees straight into the latch, and not to far in or out in relation to the seat latch, otherwise the latch will jamb or fail to latch and release correctly. It's all about the adjustment position of the latch pin screwed into the body, for fore and aft, up and down, and in and out with relation to the seat latch.
    Vorsprung durch Technik
    Aug 26 2005
    I thought that the end of the cable fit through a pin with a set screw at the hood latch, and the slack in the cable is pulled tight then the set screw tightened. Is the installed length of the cable fixed?
    May 21 2007
    Florida
    why do these cars have 4 wheels? a tri-mobile would have been much less costly and far superior in handling. 4 wheels is overkill. is it because of some sort of safety regulation?
    2018 Navarro Blue Q5
    Veteran Member Four Rings Valve_Cover's Avatar
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    Quote Originally Posted by doublezero30 View Post
    I dont know what this dude is smoking but damn..... I want some !
    I'm just here for the free coffee
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    I have one,
    Thanks
    The easier way is to hold the latch in the open position and give the seat a nice hit with your shoulder. I read that somewhere on here a few years ago and it also works on my stuck rear seats.
    Mar 01 2011
    Indy
    it's to avoid events like this:
    Veteran Member Four Rings tchuck's Avatar
    Apr 11 2010
    '04 A4 1.8T Avant tip
    Portland, OR
    I have one,
    Thanks
    I just replaced that little latch assembly for the same reason. Upon closer examination I found that the plastic handle itself was broken and was flexing enough to feel like it was working, but in fact was not engaging the mechanism below. Unfortunately the handle isn't sold separately...
    ©Timtronic
    Feb 06 2012
    1999 Saab9-5 SE & 1983 MB 300D
    breinigsville, pa.
    Where is the air filter element and how's it changed? 2004 1.8l
    Thank you, Jay
    04 A4 1.8T Q M6
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    I understand why they have 4 wheels but I think 3 wheel drive would have been good enough
    Quote Originally Posted by westie180 View Post
    lol love the reliant robbin episode of top gear.
    Quote Originally Posted by Valve_Cover View Post
    x2
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by dsljay View Post
    Clicky click
    May 28 2010
    Georgia
    How do you pull the climate control out?
    I have an aftermarket single din radio in the factory double din spot.
    Current
    2018 A4 Q 2.0T
    2002 TT Q 1.8T
    Former
    2002 A4 Q 3.0
    2003 A4 Q 1.8T
    2012 A4 Q 2.0T
    2014 A4 Q 2.0T
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by igo4uga0586 View Post
    Pull the radio first and you'll have access to the screws holding it in. (I believe)
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by onceover View Post
    Correct (except there are no screws). Remove the stereo head unit using the stereo release keys. Slide the unit forward and disconnect the wiring.
    Reach through the opening and push the climate control unit out from behind. It should just click out.
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    How do you kill / bribe the gremlins that control my heat and a/c?
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    Senior Member Three Rings nazisled's Avatar
    Feb 21 2012
    Detroitish
    here's a dumb one for ya...
    can you put E85 gas in non flex fuel cars? if yes, is there any benefit or harm?
    Veteran Member Four Rings 32_d3gr33s's Avatar
    May 14 2009
    '16 Tiguan TSI, '08 Suburban, '02 Ninja ZX-6R, '06 Ninja 650R
    West Michigan
    anyone know what the rms output is for the stock bose amp?
    I could write something cliché and insightful, but that would be too cliché and insightful.
    **-Anthony-**
    2003 A4 3.0 Pearl White | Autopilot V2 | Airlift Slam Series | Koni Sport Shocks | Pioneer X920BT | Kenwood 9105 | Kenwood 8405 | Infinity 6030 | 15" Alpine Type R | Ram Air Intake | Adams Rotors | Air Horns | Oettinger | Varrstoen Wheels| ABT Grille | 5% Tint | Build Thread
    Feb 06 2012
    breinigsville, pa.
    Thanks, old guy, for that link. I'll pull that air filter tonight.
    Thank you, Jay
    04 A4 1.8T Q M6
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by nazisled View Post
    No. Lots of harm. You need way more fuel in order to have the correct air/fuel mixture. Running it without a proper tune (and larger injectors for enough fuel) will cause the engine to run super lean.
    Stock. For now...
    Jan 13 2010
    Toronto Canada
    whats the difference between coated bearings and OE bearings?
    when do you use head studs compared to head bolts and why are the studs so damn expensive?
    what is the diameter of the Divertervalve hose?
    is it bad that my downpipe isnt connected to my transmission?
    how many dead babies can I fit in the spare tire well in the trunk.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Jun 08 2008
    Calgary AB Canada
    Head studs (ARP for example) can be re-used multiple times, and are much stronger than the OEM bolts. They also make lining up the head onto the block a lot easier.
    I would connect the downpipe to the trans. Thats a lot of weight hanging on the flex pipe/test pipe/flanges/turbo/exhaust manifold. Somethings going to give eventually.
    Stock. For now...
    Apr 06 2009
    The StL
    and what of the baby volume? come on!
    and i still love your front lip!
    Senior Member Two Rings RawrItsCris's Avatar
    Jul 23 2009
    88 Alpine E30, 06 E92 325xi WAGON
    Spanaway WA
    HAHAH quoted. god i love forums and thier unexpected humor
    db.DirtyBirds
    "Magazine feature in Japanese, of a German car, in America.
    Legit."
    Senior Member Three Rings DBM's Avatar
    May 31 2011
    SLC, UT
    How does the window-lock switch work? It can be up or down, but then sometimes the light is on and sometimes it isn't...and I swear every time someone in the back tries their window it's locked.
    Feb 06 2012
    breinigsville, pa.
    do OE wheels from a B5 fit onto a B6? Are they interchangable?
    Thank you, Jay
    04 A4 1.8T Q M6
    Dec 28 2006
    Western Maryland
    Yep.
    Dec 18 2011
    Colorado Springs
    What exactly is an Eliminator Turbo set-up? and a FrankenTurbo?
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by B6A4Dave View Post
    Eliminator is a term coined by ATP for a Garrett GT25/GT28/GT30 series turbo designed by them to bolt up to the stock K03/K04-type exhaust manifold. There are the GT2X (GT25R-based), GTRS (GT2860), GT2871R (a GT28 w/71R compressor) and a GT3071R-based eliminator as well.
    Frankenturbo is a K04 "hybrid" turbo (basically a K04-015 with a different/larger compressor wheel) which is a stock replacement as well, good for up to 300chp or so.
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Apr 06 2009
    The StL
    Quote Originally Posted by Matt Devo View Post
    NO S? hmm so what would the next logical step be from a K03? with , say a test pipe and FMIC?
