Page 1771 of 1786 FirstFirst ... 7711271167117211761176917701771177217731781 ... LastLast
Results 70,801 to 70,840 of 71422
  1. #70801
    Veteran Member Three Rings wangerang's Avatar
    May 22 2017
    Lafayette
    Replaced LF strut mount and a front sway link bolt that mysteriously disappeared.. checked torque on RF strut top. Getting ready to inspect the cam follower when I do an oil change next. Will be purchasing the stud convert kit.
    2018 GTI
    2007 A4 2.0T 6MT
    1998 A4 Avant 2.8 5MT
    1997 A4 1.8T 5MT FWD
  2. #70802
    May 22 2017
    Lafayette
    Quote Originally Posted by PhireSideZA View Post
    The only other hurdle that comes to mind was the right-side rear control arm to subframe mount that we couldn't remove without dropping the subframe. We then chose to cut the bolt off with an angle grinder and installed the new bolt from the front facing back, which should make future repairs easier.
    Exactly how I ended up doing mine :’(
    You can slightly lower the subframe and not drop it. As I’m sure you experienced, it’s a PITA to get to that top bolt.
    2018 GTI
    2007 A4 2.0T 6MT
  3. #70803
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by wangerang View Post
    Gonna need to move the hard coolant pipe. Pump will hit when installing/removing with stud kit, why I never installed one I have.
    Sent from my LM-G710VM using Audizine Forum mobile app
  4. #70804
    May 22 2013
    FL
  5. #70805
    Feb 15 2016
    Cambridge,Ontario
    Replaced rear caliper. Due to seized e-brake.
    Total of 7 minutes not including bleeding . Easy caliper to do.
    Helped that I did the rotors and pads last month and noticed the ebrake stuck.
    Lifted ebrake cable out with my fingers. 13 and 15mm to remove pins. Lifted caliper out. Swapped over hydraulic line with my 13mm. Done. Pop caliper back in. Put bolts back with lock tight. Compress ebrake with channel locks and hook on cable.
    Done ....
    10 minutes more to bleed. Car back on the road.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
  6. #70806
    Senior Member Two Rings PhireSideZA's Avatar
    Dec 31 2021
    Ryobi Lawnmower, 1hp
    South Africa
    Yup, luckily not an insurmountable task, but an annoying one at the very least. I did contemplate going the subframe route, but the angle grinder was close by
  7. #70807
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    After almost a year of sitting there not driving it, I decided it was time to make my A4 street legal again and start driving it. Out with the test pipe, in with the high flow cat.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
  8. #70808
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by EvolutionArmory View Post
    Do they just do a visual check, or do you expect it to actually pass a sniffer test?
  9. #70809
    May 20 2017
    New Hampshire
    Quote Originally Posted by Jayz691 View Post
    For the first time ever, my mechanic looked under the car and failed me. That was last year and was 100% why I bought a B8 S4
    The car has been parked since. I was just sick of dealing with that car and needed a break. Now I want to get back to driving it to keep the miles off the S4.
  10. #70810
    Jul 02 2012
    Yokota
    After 30 months…I finally have my car back! The only downside, the guy didn’t tighten my temp plate down and well…I was driving back to Melbourne with no plates on my car, in the rain!
  11. #70811
    Dec 31 2021
    South Africa
    Quote Originally Posted by Dat Black Kid View Post
    On the bright side, you got it back! I suppose it was an uneventful trip with no issues besides the temp plate?
    Got some not-so-good news back on my Avant. It looks like the machine shop that replaced my valve stem seals also discovered serious scoring on the camshaft journals, and pitting on the camshafts themselves. I'll have a proper report hopefully tomorrow, but that's what I could suss out so far. I may be looking at a new head and camshafts, or failing that, a replacement engine and then salvaging the best parts between them.
    Or if I can get hold of the 4.2 V8, just drop that in...just kidding...or maybe not
  12. #70812
    Jan 21 2018
    frackville, pa US
    Ok, so they just do a visual. Thats good.
  13. #70813
    Jul 02 2012
    Yokota
    No issues except, since it rained so dang much within the first 5 days and the on-base draining system is horrible, I had to drive it through a nice stretch of puddles. Now, I can hear something fluttering on the left rear. Something is loose and I will see if they can find it. It's been raining every single day for no reason other than to punish me! Taking her in tomorrow to have all of my fluids changed, cancel the tire rotations, but add in to have the plastic seat back fixed, a new safety belt mechanism, because it no longer retracts automatically, and a new battery for the key fob.
    Once fixed, I will drive it around for another good week or two doing my Stage 1 ECU tune from 034.
  14. #70814
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Oil change, rear diff fluid, front diff fluid, and transfer case fluid. All with new plugs
    "Beep beeeep bloop boop" - R2D2
  15. #70815
    Veteran Member Three Rings IbisB7stage2's Avatar
    Mar 20 2013
    Bay Area
    Putting the car in the air and hunting for the source of a clunk noise.
    I hear and feel a clunk when letting the clutch out, typically in 1st or 2nd gear.
    Anyone got suggestions?
    Sent from my SM-G950U using Audizine Forum mobile app
    ~John
    B7 A4 quattro 6spd, k04 w/ meth, PSS9 coils, S4 recaros, basically everything else
    C5 S6 Avant 6spd
  16. #70816
    Oct 14 2011
    Norcross, GA
    Quote Originally Posted by IbisB7stage2 View Post
    Hmm snub mount?
  17. #70817
    Jun 27 2011
    What Did You Do To Your B7 Today?..
    Came home from a trip out east last night to a flat tire at the airport. Got in really late and just wanted to get home so I didn’t notice the flat until this morning when I was going to take my kid to soccer. It was droving really funny last night and TCS kicked in on a very mild corner on the highway but since it was midnight and I didn’t really have a safe spot to pull off I drove the 15 miles home from the airport, just a bit slower than normal. The tire was at 0psi this morning with a huge metal thing sticking out of the center of the tread. Looks almost like a bicycle spoke…
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  18. #70818
    Oct 14 2011
    Norcross, GA
    Dang, sorry to hear Charles. Could be a bent nail maybe. Tire looks repairable.
  19. #70819
    Aug 18 2009
    A Unicorn
    Portland, OR
    Plug it, fill it, forget about it
    :: Seller feedback ::
    RIP: 2006 DG Avant Tip
  20. #70820
    Junior Member Two Rings KNN's Avatar
    Sep 03 2011
    South East Asia
    Changed all four absorber mounts and front arm bushing. It made a good difference in ride quality and road feedback.IMG_20220915_113337.jpg
    Sent from my V2022 using Audizine Forum mobile app
  21. #70821
    Sep 03 2011
    South East Asia
  22. #70822
    Sep 03 2011
    South East Asia
    Replaced this plastic bit behind the seat railed, not original, not OEM, but 3D printed. Fits damn well.IMG_20220915_222843.jpgIMG_20220915_222832.jpgIMG-20220915-WA0054.jpg
  23. #70823
    Jun 27 2011
    Quote Originally Posted by Willënskraft View Post
    Yea most likely patchable at least. There’s so much highway construction here I’m not sure when I picked it up but it’s a slow enough leak that I put 20psi in two hours ago and it’s not flat yet. I might just pick up a patch kit rather than going to discount. Anyone have patch kit reccos? Or are they pretty much all the same?
    -CP
    2017 Q7 3.0t
  24. #70824
    Jun 27 2011
    Yuuuup.
    -CP
    2017 Q7 3.0t
  25. #70825
    Registered Member One Ring Detroit Leaning's Avatar
    Sep 25 2022
    New Eibach Lowering Springs and Koni Sport Shocks
    It was actually yesterday, but installed new Eibach Pro-kit with Koni Sport (yellow) dampers. Before picture on the left, after on the right.
  26. #70826
    Aug 18 2009
    A Unicorn
    Portland, OR
    They're all pretty much the same. Just grab one off amazon
  27. #70827
    Jul 02 2012
    Yokota
    Took her to Sebring, and drove 3 laps around the track! Best day ever! Then the top part of my grill which covers the radiator….broke into pieces, so it’s time to replace the whole grill. In addition, the hood doesn’t stay open, so I had to prop it with the umbrella to cool the engine down after doing 3 laps…and then the piece broke. So…I’ll look into a DTM grill, as well.
  28. #70828
    Jul 25 2019
    Charlottesville, VA
    I usually do this every couple months. :) Seriously though- I do and it biiites. You’re lucky- 90+% of the time mines within an inch of the sidewall, and you can’t plug or patch there (as that’s at the edge of- or too close to the edge of- the belts.) Mine are so consistently at the edge and non-fixable that I now keep two new tires in the basement (pretty f’ed up to have luck like this. )
    Anyway I know there are various camps on this, but the majority advocates for an off the rim patch on the inside of the tire. Yours is a perfect candidate. Any reputable place can do it quick, while you wait. It’ll be as good as new once done properly.
    Eric
    2015 A4 2.0T Quattro
  29. #70829
    Dec 31 2021
    South Africa
    Missed it.
    It's been a bit over a month since I handed the car in for the valve stem seal repair. Unfortunately, due to the car overheating some time prior to me taking ownership, the engine is pretty much toast.
    The head journals are shot, the camshafts are pitted and scored, cylinder #3 has collapsed rings, so next item on the agenda is to try and source a working engine and try to assemble a working unit from all the spares.
  30. #70830
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    samething happened to me last week, parked the car in the garage, and I heard a psshhhhh, first I thought it was water dripping on the hot exhaust, but then realized that was the tire.
    I thought I could plug it on the car, but damn this indy500 are hard to plug, had to remove the tire to have more grip on the tool. 20 minutes and the tire was back
  31. #70831
    Jan 21 2018
    frackville, pa US
    Id say a nail thats bent and worn. Either plug it, or if you can take the tire off, those newer plug patches work really nice. Used them a few times. Screenshot_20220926-095044.jpg
  32. #70832
    Mar 20 2013
    Bay Area
    discovered the sound of my clunk. Apikol rear diff mount ate sh*t.
    anyone got aftermarket recommendations? I was checking out the powerflex bushing options.
    ~John
    C5 S6 Avant 6spd
  33. #70833
    Junior Member One Ring
    Oct 24 2010
    Moscow, Russia
    Quote Originally Posted by oVeRdOsE View Post
    tried the rs4 with 245-40-19, dont fit, anyway, tires a shoot, planing to put 235-35-19, debating to put :
    - indy 500
    or
    - DWS06
    I guess at the size, both will have same comfort, aka almost none
    (yes those will be repainted)
    Can you please wight oem rs4 wheel?
    I'm choosing between 19*9 rs4 cast and 20x9 s8 oem forged wheel.
  34. #70834
    Jul 02 2012
    Yokota
    Found out that Melbourne Audi never rescheduled me for a full service and fluid check, so I said f-it and forego rescheduling it again, when there’s no guarantee of giving me a loaner car. I’m just gonna do my stage 1 Ecu tune. I know all the fluids are still full, since the gov surprisingly enough, took care of it for 30 months. I wanna find the oil drain plug, so I can change out the oil and refill it.
  35. #70835
    Jul 01 2015
    Mtl
    Quote Originally Posted by Sherbakoff View Post
    you mean the weight? they are 25 lbs without tires
    you want to go 20'' on a B7? 20'' are way too big on a b7 imo, looks funky. even 19'' are a bit big. Imo , 18'' with meaty tires looks the best.
  36. #70836
    Jun 27 2011
    Agreed, 20s are Donk wheels on a b7. 19s look good if done right.
    It’s all about the proportions in relation to the wheel well. 20s look weird. On a b8 they look great. But b6/7s just can’t pull it off IMO.
    -CP
    2017 Q7 3.0t
  37. #70837
    Jan 21 2018
    frackville, pa US
    Also agree, 20's makes a b7 look like a matchbox car, lol. If roads were better, id consider 19's. But 18's are perfect imo. Also, cuz I like light weight. My 18x8.5 are 19.2lbs, 40lbs with new tires. My 17" stocks were 25lbs...
  38. #70838
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Any tire shop can easily plug then patch it up for free, especially with Firestone. Done mine just a couple of months ago.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
  39. #70839
    Oct 09 2007
    Miele S7
    Quote Originally Posted by KNN View Post
    Wow, this is a first. I remember bringing my car in to the dealer back in 2013 (33,000 miles) and they replaced the power seat motor on the driver side but messed up this very part when reinstalling the seat back in place. Long story short they ordered me new ones, as a matter of fact a whole pair. To this day I have not been able to replace them due to time and have totally forgot about it. Just sitting inside my 'drawer of parts' somewhere.
    Nice reproduction of the part by the way.
  40. #70840
    Jun 27 2011
    I actually broke a few of those rail covers on my b8 seats when I was moving them around the basement. Never quite knew what to do about them but I’ve never had issues brushing up against the rail so I moved on. That’s a clever idea though. 3D printing is so awesome…
    -CP
    2017 Q7 3.0t
