Page 1761 of 1786 FirstFirst ... 7611261166117111751175917601761176217631771 ... LastLast
Results 70,401 to 70,440 of 71422
  1. #70401
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Quote Originally Posted by EvolutionArmory View Post
    I mean, you’re the guy who’s making his car look bad to make sure his crash bar stays cool….
    So eager to write back something smart, that you didnt take time to see why that is. Or you did and didn't understand what it means.
    Either way thanks for proving my point. Making this way too easy. Appreciate it.
    Cheers.
    Audi A4 in an RS4 body
    Mike
  2. #70402
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    What Did You Do To Your B7 Today?..
    Quote Originally Posted by Doctor View Post
    Cheers.
    Dude, you even said you have a euro plate in front of it most the time. So it literally does nothing except look bad when you take the plate off. 🤣🤣🤣 Dude, you don’t need vents to direct airflow over a FMIC. The grill does that. 🤣🤣🤣 And the crash bar is visible through the holes..
    I thought the Greeks were known for doing amazing things to Audi’s. Maybe you missed that day at tuning school.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
  3. #70403
    Jun 02 2008
    Greece
    You should do your homework before you dive into throwing toxicity in fora.
    Quit try-harding mate, this is looking funny to people having been longer than you in here.
    Sorry, I meant dude, not mate. Seems to be a word you like.
    Cheers
    Mike
  4. #70404
    Jun 02 2008
    Greece
    B Pillars, C Pillars and Interior Kevlar / CF Trim installed
    Untitled by mgpdoc, on Flickr
    Cheers
    Mike
  5. #70405
    May 20 2017
    New Hampshire
    Cheers
    What I lack in time here compared to you I make up in build quality and a lack of useless holes in my grill. 🤣🤣🤣
    Look man, I’m just telling you it looks bad and is pointless. Don’t get too butt hurt over it.
    You’re putting very nice carbon accents on it and all of that is instantly overlooked by that horrible grill. Yes, you have a plate over it when driving it daily, but as soon as you take it off, that mistake cancels every nice thing about the car.
    I’m just trying to be honest with you.
  6. #70406
    Jun 02 2008
    Greece
    Restored some things on the interior to remove some years off of it.
    1. Climatronic Unit - which also now has the buttons for heated seats if needed in the future.
    Old and tired to the left
    Installed
    2. Latch from the armrest, which was broken from when i bought this second A4.
    Old above (or what is left of it ) vs new at the bottom
    Installed
    Cheers
    Mike
  7. #70407
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Not a huge leap forward, but kind of. I’m pretty sure this is a first on a longitudinal EA113. I hung the Peterson R4 with the Integrated Engineering mounts. I’ll need to pull the engine to get the OEM oil pump/balance shaft assembly out, add a PTFE crank scraper, and the IE oil pan.
    It wouldn’t clear the Race3 rad cradle, so they’re sending me the light version next week. I’ll make everything a lot easier. I have a feeling this one will end up modified and in an 07K swapped B7.
    Now I have to wait on the mandrel for the crank and the oil feed. Once that’s done, I can really start plumbing. The dash Hass to come out so I can pull the HVAC and heater core, then build a dash bar for the roll cage.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
  8. #70408
    Jun 27 2011
    Oh dang, that’s really cool! External oil pump? Should be a nice upgrade for the track.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  9. #70409
    Jul 04 2015
    Toronto Ontario
    Thanks. Yessir, 3 stage (2x scavenge & 1x pressure). It’ll be a huge upgrade because of the consistent oil pressure, elimination of all starvation/cavitation, and the 4 gallon oil capacity. It has been a struggle putting it all together though.
    I’ll likely scavenge the turbo via a Tee with a check valve, as well. That way I’m assured it’ll always be draining properly. I’ll still likely run a closed loop catch can from the valve cover.
  10. #70410
    Senior Member Three Rings Blockis's Avatar
    Jul 25 2012
    2007 A4, 2011 Q5
    Boston, MA
    Finally put in a "newer" headunit. Next up is replacing the bubbling shift plate trim and then drop in the rest of the brushed aluminum trim.
    Paul
    2002 A4 1.8T Quattro | 197k ☠️
    2007 A4 2.0T Quattro | 168k
    2011 Q5 2.0T Quattro | 240k 🔧
  11. #70411
    Jul 04 2015
    Toronto Ontario
    Canadian came over on the weekend and we got to work.
    Pulled the rear subframe, drive shaft, and dash. Still need to pull the engine and transmission (parts from iABED will be here soon). Need to swap the diff from the old subframe to the replacement.
    We pulled about 80lbs from the car and that was all just fuel system/shields/filler equipment. I’m thinking the HVAC/blower/ etc is likely going to net another 120+lbs.
  12. #70412
    Senior Member Three Rings studiobmx's Avatar
    Jun 20 2016
    1.8T Vanagon, B7 Avant, C5 Allroad, NCV3 Sprinter, Q5 (wife's), CB550
    Tacoma
    Dang, that’s crazy!! I’d be interested to see what you can get the weight down to!?
  13. #70413
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by studiobmx View Post
    Thanks. I’m guessing 2900lbs wet.
    3372lbs with driver 220lbs) before.
  14. #70414
    Jun 20 2016
    Tacoma
    Wow, that’s a substantial saving. You’ve got a cage right ?
  15. #70415
    Jul 04 2015
    Toronto Ontario
    Yes. We built a 6-point cage. It’ll likely be 10 point this winter.
  16. #70416
    Jun 20 2016
    Tacoma
    Awesome! This is a CHUMP car right ?
  17. #70417
    Jul 04 2015
    Toronto Ontario
    Yeah, ChampCar and Lucky Dog.
  18. #70418
    Jun 27 2011
    An old Co worker used to run an old fox body in lucky dog. Sounded like a lot of fun. He always had good stories.
    -CP
    2017 Q7 3.0t
  19. #70419
    Jul 04 2015
    Toronto Ontario
    So, a little more progress today. Thanks to Canadian for driving 3 hours, having the truck eff off twice, and throwing out his back for the help.
    The rear subframe with all upgrades is finally in. I mean, I was nervous of the 034 RSB not clearing the fuel cell/cell cage, but there is about 5mm clearance. All in all, it went in very quickly (unlike pulling the old one).
    Put a cherry picker together to get the engine out again. Working on pulling the last few transmission bolts and I’ll have it out. I still need to swap the OEM oil pump out, and throw the dry sump pan on the built engine (after clearancing the pan for the oil feed galley). Lots to do inside the car with the dash coming out as well. Hoping I have time to get it all done before April!
  20. #70420
    Jul 25 2012
    2007 A4, 2011 Q5
    Boston, MA
    Quote Originally Posted by Blockis View Post
    Replaced the shift plate and the last of the brushed aluminum trim:
    Paul
  21. #70421
    Jun 27 2011
    Bought a new Bluetooth adapter that supports streaming with the AAC codec. Should arrive in a few weeks from Shenzhen.
    I’m currently using a Tune2Air ($120) connected to an A3 AMI module ($200 and quite rare) in my glovebox and while it’s been decent enough I’ve lately been reminded at just how much low frequency sound is cut off by the garbage SBC codec. And given that song info in the DIS doesn’t really work anymore, and steering wheel controls don’t reliably work to control the songs either, keeping the AMI unit doesn’t really make sense. So I’ll be switching to a more standard Aux unit and wiring this bare board/module in. Nice thing is it also has Aux pass through so I can wire in a headphone jack if I want to later on and it’ll takes 12v power from the Ami harness too. Should be relatively simple to wire in.
    I might do a write up when I get it working if anyone is interested. The board is $22 shipped and come with wiring pigtails, supports Bluetooth 5 and AptX-HD for the Android folks. So it should be a really flexible solution that’s also really cheap and should integrate well in a car audio system. My only concern is that it might take a long time to “boot” when I turn the car on but we’ll see I suppose.
    -CP
    2017 Q7 3.0t
  22. #70422
    Junior Member One Ring
    Apr 26 2021
    Baltimore
    Changed my CTS bc I pulled the good old P181. The old one looked pretty bad so I'm pretty sure that's it (fingers crossed)
  23. #70423
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    Grocery Getter Updates
    Thanks to covid BBS CH-Rs & RS5 CF wheel finally showed up. Still waiting on BBK to show up i ordered in May.
    Need to drop the rear and possibly get a meatier tires, a bit stretched for me. Out of all my cars this slow ol' grocery getter still looks so good.
    New Sport shifters CF GT2 knob just showed up yesterday and looks fantastic. highly recommended to any one looking for a new shift knob.
  24. #70424
    Veteran Member Three Rings RickB_7's Avatar
    Feb 26 2015
    Tacoma, WA
    Washed it
    Covered it
  25. #70425
    Jun 27 2011
    Took advantage of the in-laws being around to help wrangle the kids and put its winter boots on:
    They barely clear the Macan brembos with 8mm spacers.
    These wheels didn’t clear standard A4 brakes (they did once the pads wore down some) so I’m glad the spacers were enough for clearance.
    -CP
    2017 Q7 3.0t
  26. #70426
    Jul 04 2015
    Toronto Ontario
    Engine is out for the oil pump removal and dry sump pan.
    I effing hate pulling the engine without the trans because it’s a c-unit getting aligned. I also wracked my brain for three days over one bolt. Turns out it’s a cake walk from the top. Perspective, I guess.
  27. #70427
    Jun 27 2011
    Glad I put the winters on because this happened
    The roads got pretty icy but the Hakkas were unflappable.
    -CP
    2017 Q7 3.0t
  28. #70428
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    Had my second outer CV joint 'C-Ring' fail on me. Both have basically broken at about the midpoint of the C. One lasted about 8 months and the second about 3 months. One was on my Sedan and one was on my Avant, so different axles altogether.
    I have been putting the 'C-Ring' in the groove on the axle first and then getting the CV joint started on the splines and then giving the CV joint where the big bolt goes a pop with a hammer to get it to seat in the CV joint groove.
    Should I have been doing it the other way? Putting the 'C-Ring' into the CV joint first and then inserting the axle and giving the axle a pop with a hammer at the back of the part that mates to the transmission? I would think it would not matter either way.
    Anybody else experienced this issue? Let me know your thoughts.
    Edit: More info. Boot kits that broke the 'C-Rings' (2) are Genuine boot kits from the dealer. Pulling out the 'C-Rings' that I saved that were removed from the last 2 outer boots I replaced, the old 'C-Rings' that are I assume the original to the car when new are not round. They are a little bit oval where the distance to the top and bottom of the C is larger than the distance to the left and right of the C. The wear marks on the old 'C-Rings' are on the top and bottom of the C. The new 'C-Rings' were almost perfectly round. The wear marks on the new, broken 'C-Rings' that appear to be almost perfectly round are on the left side of the C only and that is where they broke....
    I have a new boot kit that I should be able to pick up at the dealer, hopefully tomorrow. It will be interesting to see what the 'C-Ring' looks like round or slightly oval. I am tempted to put one of the old 'C-Rings' in if the new boot kit comes with a round one.
    Edit #2: Fixed and all back together. A little lessons learned if anyone comes across this issue or is doing outer CV boots. The 'C-Ring' can move around on the axle shaft a lot. There is a chamfer on the splines of the CV joint that is there to compress the 'C-ring', but the 'C-ring ' can move so much that it is outside of the chamfer. If you hammer on the CV joint with the 'C-ring ' being outside of the chamfer a little bit, it tries to take a chunk out of the 'C-Ring'. In my case, the damaged 'C-ring' eventually fatigued and broke at the damage site. With the new boot kit, I figured out you have to get the CV joint started on the splines so it is just loosely sitting on the 'C-Ring', then pull back the boot so that you can see the 'C-Ring' then with a small pick, make sure the 'C-ring' is not pushed out all to one side. Get it centered with the pick and then it only takes a little tap with a dead blow to have the chamfer compress the 'C-ring' and let the CV joint slide on enough to engage the 'C-ring' in the CV joint groove.
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
  29. #70429
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
  30. #70430
    Jul 04 2015
    Toronto Ontario
    It’s nothing really fancy like a lot of the builds I see on here, but I think it’s pretty rad.
    I got the oil pump/balance shaft assembly pulled from my race engine. The oil pump was in absolutely perfect condition and has only seen about 500km of use (testing and tuning the race car). That said, factory oil pumps and balance shafts tend to fuck off when seeing consistent high RPM, and also starve for oil when cornering hard.
    I’ve got the Integrated Engineering sty sump pan on the bottom end to keep debris out until I get a chain breaker for the factory oil pump chain. I’ll also need to laser cut a PTFE crank scraper, and swap the iABED rear main seal, while I’m in there. I also realize I need to move the snub mount, as it’ll interfere with the dry sump pulley/belt.
    Mind the mess of a shop.
  31. #70431
    Mar 16 2012
    Lomita, California
    Did this yesterday(power steering high pressure line):
    A medium pain in the ass, and a big messy task as it was leaking inside the protective jacket and the protective jacket filled up with PS fluid. An offset 19mm wrench with 12 point is a must to get the banjo bolt on the rack. I guess I am happy it was not the rack itself.
  32. #70432
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by Older_not_Wiser View Post
    Great work!
    WERA Tools also has a ratcheting crows foot wrench that works very well for this job. That’s one of my next projects when the electric pump goes in. I just wish I had an RS4 rack for it.
  33. #70433
    Senior Member Two Rings PhireSideZA's Avatar
    Dec 31 2021
    Ryobi Lawnmower, 1hp
    South Africa
    Bought it!
    I've been looking for an Avant for a couple of months now and finally got one that I liked enough to buy it. I really, really wanted one in white but the spec level of this one in Phantom Black was too good to pass up - towbar, wood trim, RNS-E, colour DIS and cruise control as factory fitted. We don't get great spec levels where I'm at, even with the S-line trim.
    Delivery should be sometime next week. I'm most excited.
  34. #70434
    Jun 27 2011
    Got a flat today. The roads here in Seattle are absolutely fucked either from the prolonged freeze during the storm a few weeks ago, or all the plows just shredding all the pothole patches. Either way I hit a gnarly one on the highway offramp today and pinched the sidewalls on my front drivers side. The tire is a goner, it was totally deflated in a matter of seconds. Thankfully I was able to stop in a nice cordoned off construction bypass and change the wheel with my spare which, with my luck, was also flat! Seeing as I had no inflator, and my wife was out and couldn't come get me with the portable one I have at home, I had her pick me and the kiddo up and we went home and had dinner. Caught an Uber back to the car, pumped up the now-mounted spare and drove it home.
    Now the dilemma of what to do about replacing a single tire. I'm running Hakkapellittas that are a few years old with maybe 5-10k on them and I need snow tire capabilities for weekend trips to the mountains. All the passes here are closed because of the unholy amount of snow we've gotten this year (no joke, the 5 year average for today's date was 146" and as of today we have had 286" at the passes, its been bonkers) so throwing a random all season on isn't a great idea and ordering one single new snow and hoping my diffs don't blow doesn't really sit well considering I'll be driving up to the mountains at least once a week for the next few months. Ugh, dilemmas...
    -CP
    2017 Q7 3.0t
  35. #70435
    Aug 18 2009
    A Unicorn
    Portland, OR
    Order new tire, have it shaved, done and done
    :: Seller feedback ::
    RIP: 2006 DG Avant Tip
  36. #70436
    Jun 27 2011
    Pretty hard to find Hakka R3s in stock anywhere. Love these ongoing supply chain issues.
    And besides I’ve found another set of Michelins in great shape a mile away so I’m going to pick those up tomorrow most likely.
    -CP
    2017 Q7 3.0t
  37. #70437
    Aug 18 2009
    A Unicorn
    Portland, OR
    To be fair. Hakkas have never been the easiest to get here. But yeah, matched set is good
  38. #70438
    Jun 27 2011
    And wouldn’t you know it, the spare is flat again this morning. Love that the bozos at the Costco tire picked literally the worst tire of my old ones when I asked them to keep the best one and replace the spare. That tire was the reason I got new ones in the first place.
    -CP
    2017 Q7 3.0t
  39. #70439
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    Quote Originally Posted by james12lucy View Post
    Great work!
    Just sent you a PM, I have a rebuilt RS4 rack that I’m considering parting with.
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Mounts - APR Snub - S4 RSB - 034 Turbo Inlet - JHM Short Shifter - Porsche 345mm Brembo Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension/B5 front cups - Black Alcantara Recaro Interior - RoadNav/S100 Headunit - Summer: 19" OEM S5 wheels, 19x8.5 ET32 - Winter: OEM 18" RS4 stye wheels, 18x8 ET43 w/ Nokian studded tires - Dolphin Grey FTW!
  40. #70440
    Aug 18 2009
    A Unicorn
    Portland, OR
    And wouldn’t you know it, the spare is flat again this morning. Love that the bozos at the Costco tire picked literally the worst tire of my old ones when I asked them to keep the nest one snd replace the spare. That tire was the reason I got new ones in the first place.
    Go someplace better than Costco
