Page 1671 of 1786 FirstFirst ... 671117115711621166116691670167116721673168117211771 ... LastLast
Results 66,801 to 66,840 of 71422
  1. #66801
    Jun 27 2011
    Quote Originally Posted by Flygman View Post
    Unless you yank the wires and the bulbs drop into the headlight like they did on mine
    Haha I think I did that once. Such a massive pain in the ass!
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  2. #66802
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Why does everybody have to butcher everything? Found a mint set of RS4 Recaros locally and went to buy them today. When I get there the drivers side electrical connectors are all butchered up. The shop who installed his drivers side racing seat chopped up the connectors so now I have to chop up my A4 seat and splice in 2 connectors. I talked him down to make up for it but damn, I can’t even buy plug and play seats without having to deal with dip shits 🤣🤣
    The seller was cool, the shop that mangled his seats is not.
    Attachment 144880
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
  3. #66803
    Oct 28 2018
    San Dimas, CA
    My 07 Avant didn't have the tech package and I put in el-cheapo LED bulbs for the plate lights. I recently got a wiper stalk with the additional switches (and the Avant, with its rear wiper, needs the Q-series stalk, not the normal one) and re-coded the car for the "extra" display pages. I didn't realize that also turned on bulb monitoring and boy was my first night's commute home a real PITA with the random beeping going on! I swapped back to normal bulbs and no more "bulb out" errors.
    The tail brake/turn signal lights are PWM since they do double-duty as marker lights when the the headlamp switch is on. Given the price of LEDs that are good enough to work with PWM controllers I'm sticking to normal bulbs.
    I did put some NINEO H7 LEDs in last winter as the dipped headlights and they seem to work just fine. No errors and I like the light they throw. I haven't done the main beams yet but I rarely use them.
    07 A4 Avant 2.0T (my grey mare)
    04 A4 Quattro 1.8T (son's car, the one that brought me back to the rings)
  4. #66804
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by ksw_92 View Post
    I have an avant tailgate handle that has resistors pre-wired in for LED plate lights. PM if you’re interested. I posted in a while ago in the avant classifieds I think.
  5. #66805
    Senior Member Three Rings Jimmyjamms's Avatar
    Sep 20 2014
    Hilux SR5 3.0TD
    Sydney AU.
    Can you elaborate on the coding for the extra display pages you speak of? Wondering if I can code to what you had originally and disable bulb monitoring. I only ever use the ‘distance till empty’ anyway
  6. #66806
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    Quote Originally Posted by EvolutionArmory View Post
    Attachment 144880
    Because they are lazy M F !
  7. #66807
    Sep 20 2014
    Hilux SR5 3.0TD
    Sydney AU.
    Quote Originally Posted by Jimmyjamms View Post
    Done!!
    17 Instruments
    10 Adaptation
    Choose additional settings and code for high line without DIS.
    No more bulb errors. They still log in fault codes but no more on dash. I really didn’t use anything in DIS besides distance to empty which still works.
  8. #66808
    Oct 28 2018
    San Dimas, CA
    Yep, that's the code page that needs to be changed. I wanted the trip MPG, time and distance readouts for billing travel back to my job. Just have to remember to record the info before I shut the engine down.
    I'm OK with the incandescent plate bulbs. LEDs are cool and all but for marker lamps and such don't add much more than a "look" IMHO. Not enough benefit to have to fiddle with load resistors. Besides, if you have to soak up power through a resistor to keep the DIS happy you're not saving any energy, which is the main reason I'd use LEDs in the fixtures.
  9. #66809
    Veteran Member Three Rings Flygman's Avatar
    Jan 27 2018
    Gothenburg
    Attachment 144880
    Well worth it either way for those beauties! What did you give for them?
    Current:
    A4 B7 DTM | BSR Stage 1 | CTS HFC | Simons catback | 034 HPFP internals | K&N panel filter | Garrett FMIC | DO88 intercooler piping & hoses | GFB DV+ | IE PCV Delete | Poly snub mount, rear wishbone & spindle bushings | B5 'lowering perches' | Judd T325 19x8.5 ET32 rear + ET35 front | Pirelli P-Zero 235/35R19 |
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  10. #66810
    Jan 27 2018
    Gothenburg
    Passed inspection, legal for another 14 months
    Couple hours later installed a 034 HFC and Milltek non-resonated catback. Holy shit is it loud going from stock, 14 month older me is probably gonna regret it
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  11. #66811
    Aug 18 2009
    A Unicorn
    Portland, OR
    No way. Think of it this way. 14 month older you will have 14 month older ears, so the extra volume will be appreciated
    :: Seller feedback ::
    RIP: 2006 DG Avant Tip
  12. #66812
    Jan 27 2018
    Gothenburg
    WHAT?
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  13. #66813
    Aug 18 2009
    A Unicorn
    Portland, OR
    WHAT?
    Older ears = poorer hearing. Therefore, louder is better. Obviously
  14. #66814
    May 20 2017
    New Hampshire
    What Did You Do To Your B7 Today?..
    700. I probably overpaid for just getting front seats but the leather is mint. Next I’ll get some aluminum mirror caps, a flat bottom wheel and probably call the car done. Maybe some lightweight wheels and keep the B8 sport package wheels just for winter.
    Attachment 145016
  15. #66815
    Jan 27 2018
    Gothenburg
    I CAN'T HEAR YOU
    - - - Updated - - -
    Attachment 145016
    I'd easily pay $700 for a set, seen them for $2000+ on Facebook marketplace here in Sweden
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  16. #66816
    May 20 2017
    New Hampshire
    Maybe 2K for a whole set with door cards and dash trim. I felt comfortable with paying what I paid but don’t think I got that great of a deal considering I have to splice in an airbag connector and seatbelt sensor harness.
    I’ll tell you this though, OEM Recaro seats are nice!!!
  17. #66817
    Aug 18 2009
    A Unicorn
    Portland, OR
    I CAN'T HEAR YOU
    Perfect
  18. #66818
    Jun 27 2011
    Attachment 145016
    For perfect condition RS4 seats that’s a reasonable deal.
    A lot of seats are pretty hammered. And I know RS4 and S4 seats are the same but RS4 seats generally go for a smidge more becuz RS.
    -CP
    2017 Q7 3.0t
  19. #66819
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Pulled the turbo and manifold to send to Pag Parts to have them rework my waste gate bracket and actuator rod. PPT really stands behind their work!
    2019 SQ5 Prestige
  20. #66820
    Jan 27 2018
    Gothenburg
    Decided exhaust drone isn't my thing.
    Much better
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  21. #66821
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Much better
    Did that actually help?? Serious question because I will do that immediately.
  22. #66822
    Jan 27 2018
    Gothenburg
    Did not get rid of it all but before your brain would scramble if you drove at a steady 2700-3500 RPM, now it feels like it's much milder and the RPM range has reduced to somewhere about 2900-3400. I'd recommend it.
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  23. #66823
    May 20 2017
    New Hampshire
    If I had the time I’d sound deaden the whole rear of the car. Avant problems 😀
  24. #66824
    Jun 27 2011
    Fuck it, strip the trim panels down and hose it down with RhinoLiner.
    -CP
    2017 Q7 3.0t
  25. #66825
    Jan 27 2018
    Gothenburg
    Haha I'm tempted to be honest
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  26. #66826
    Mar 12 2016
    The land of Kiwis
    Quote Originally Posted by i3oricua View Post
    Didn’t know that this style still exist !
  27. #66827
    Apr 10 2019
    Winterpeg
    I'd take cranks over power anyday less things to break :) especially in a vw/audi
    Sent from my SM-G950W using Tapatalk
  28. #66828
    Jun 27 2011
    Except it’s the regulator that breaks not the motor.
    -CP
    2017 Q7 3.0t
  29. #66829
    Feb 20 2016
    Greenville SC
    Quote Originally Posted by gotrek View Post
    I’ve never seen that either , but like you said I’d prefer it if I did , 1 less electrical gremlin to rear it’s ugly head lol
  30. #66830
    Veteran Member Three Rings wding2000's Avatar
    Jul 04 2015
    08 A4 Quattro Avant; 16 Golf MK7
    Installed new Bosch pre-cat O2 sensor; replaced with Audi CTS of leaky Vemo one - never buy it again.
    08 a4 2.0t quattro avant | eng bwt 200hp | tip 6-spd zf 6hp19a | akebono ceramic | andros 18x8 et35 cb72.2 72-57 centric rings | pirelli p0as+ 235/40r18 | hu xtrons px5 mtce_gs_3.40 android 8 | rev d dv
  31. #66831
    Jul 04 2015
    Quote Originally Posted by wding2000 View Post
    Did oil change and inspected the car, and found this. Two out of three snub mount bracket bolts are missing. Maybe forgot tightening it up when did engine mount 10K miles ago and these flying missing. Anyone know part # for these? Thanks
    In case anyone interested, it is N90355904
  32. #66832
    Jan 27 2018
    Gothenburg
    Quote Originally Posted by Dondbg View Post
    Didn’t know that this style still exist ! ]
    Yeah it was standard in Europe, electrical was optional. NA gets all the comfort crap.
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  33. #66833
    Jun 27 2011
    But Europe still gets actual drivetrain options, like multiple engines and 3rd pedals. So you win some, you lose some...
    -CP
    2017 Q7 3.0t
  34. #66834
    Active Member One Ring jeffz's Avatar
    Sep 30 2019
    Mesa, AZ
    Flygman:
    Thx for your photos. Helpful to this newbie. Just got my Avant , still in the “getting to know you” phase.
    Today I removed the glove box and repaired a failed previous (epoxy only) repair of the rt. hinge. The $6 brackets had to be trimmed
    a bit and bent to contour, but combined with fresh epoxy should be a lasting fix.
    2005.5 A4 Avant 3.2 AT
  35. #66835
    Apr 04 2012
    Calgary/ Alberta/ Canada
    Minus the front seats, you guys always get the better front seats
  36. #66836
    Jan 27 2018
    Gothenburg
    Quote Originally Posted by jeffz View Post
    Flygman:
    Nice, welcome to the forum! Don't hesitate to create a thread or message me with any Avant questions
    Quote Originally Posted by Redryuu View Post
    What, we do?
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  37. #66837
    Aug 18 2009
    A Unicorn
    Portland, OR
    What, we do?
    We'll you got the S-line seats, which we never got here. And the RS4 wingbacks, which we also never got. Plus way more material choices
  38. #66838
    Jan 27 2018
    Gothenburg
    Wait, do you not have sports seats with S-line embroidery, or do you not have sports seats at all?
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
  39. #66839
    Aug 18 2009
    A Unicorn
    Portland, OR
    No sports seats at all. We got the regular seats, and the S4 Recaros, that's it
  40. #66840
    Jan 27 2018
    Gothenburg
    HA! That sucks
    Current:
    Previous:
    RS4 B7 Avant
    A4 B7 Avant
