Results 1 to 11 of 11
    Veteran Member Three Rings FlashA4's Avatar
    Dec 17 2006
    Formerly B7 A4 2.0T - The OG Flash Mobile / B8 A4 2.0T Quat - Baby Flash
    Orlando, FL
    Thanks A LOT for posting this. Will save me tons of time when I start this project....SO just to verify, the back deck lid went back on with no issues?
    Any pics of sub from inside the trunk? Like how it hangs down?
    Also, it looks like you replaced the stock amp entirely. Is this true? How did you power the rest of the car if so? Not sure why Im so confused from the pics. I need to take a look at my own trunk to see what im missing here.
    Mar 30 2010
    Midwest
    Quote Originally Posted by FlashA4 View Post
    Just took a picture of the trunk. Really does not hang too low. The spacer above the deck uses up at least an inch.
    The stock amp is mounted behind the Alpine amp - see photos above on the mounting of the two amps. Stock amp will not be visible once the assemby is installed the vehicle, but it is there!
    Back lid went on without issues.
    Refer to the follow link for other ideas on similar installs.
    http://forums.audiworld.com/showthre...1#post24031981
    Dec 17 2006
    Orlando, FL
    Ok, saw the pics again...makes sense about the sub!
