Results 1 to 17 of 17
    Veteran Member Three Rings brinesi's Avatar
    Nov 14 2011
    North Carolina
    Is my front plate mount missing something? Plate doesn't fit?
    Wow, feel silly but am trying to figure this out. I have a gloss black 3.2 front plate mount for the US sized plate - it all mounts perfectly etc.. However, the holes they have built into for the license plate are clearly too wide for a US plate. On my front plate mount that came factory with the car that is the gray plastic, they just sloppily drilled into it. Is this the only way? Seems a little silly.
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    I'm pretty sure mine was drilled in order to fit the LP onto it.
    Tschüß!
    Šave
    ____________________________________________
    '10 Brilliant Black A4 Sline • Hüper Optik • 034 HiFlo Turbo Hose • EC HFC • Milltek • Alu Kreuz/ÜSS • Hankook V12's • ST-40 BBK
    Nov 28 2011
    Calgary, AB
    Fit my Euro plate perfectly. ;)
    I think they made it intentionally like that so they did not have to make two separate parts. If you don't have a NA mount, then you need to buy one to attach to that piece.
    Nov 14 2011
    North Carolina
    Quote Originally Posted by 2Point0TDan View Post
    I have a NA mount. It was extra for the 3.2 NA mount in addition to the 3.2 grill. 2 separate pieces.
    Nov 28 2011
    Calgary, AB
    The filler plate has two chrome strips on it. Once I removed that, it had an opening to fit my Euro plate. I would think the NA plate mount filled in that section like this:
    Nov 14 2011
    North Carolina
    Yep, but the holes that are already created in the plate are too wide for the holes in a NA plate. Wasnt sure if there was another piece I was missing or if its always just drilled into the plastic.
    Also, I guess Id need a special drill bit to give it threads rather than just holes?
    Veteran Member Four Rings rayray's Avatar
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    You can take the plate holder off and simply drill your own holes. Remove the screw on each far side in the space below the rings.
    2019 S5 Sportback Prestige | Daytona Gray Pearl on Black | Black Optics | S Sport Pkg
    2017 Q7 3.0T Prestige | Ink Blue Metallic on Nougat Brown | Driver Assistance Pkg | 21"RS Wheels | Towing Pkg
    Nov 14 2011
    North Carolina
    Ok, so it sounds like I must drill my own then. That seems a bit ghetto considering I bought the thing just to hold a US plate. Weird.
    Veteran Member Four Rings seph's Avatar
    Norwalk, CT
    you mean the US licence plate braket doesn't fit the US plate properly? I never actually looked behind my plate. Interesting.
    -Ant
    2012 A5 2.0TQ 6MT Ibis white
    Senior Member Three Rings audinepa's Avatar
    Jul 29 2010
    2009 Audi A4 B8, 2007 GMC Envoy XL
    NEPA
    Quote Originally Posted by brinesi View Post
    Had samething happen when I purchased car new, dealership had to drill holes to allow correct attachment of vanity plate, since that time went back to plate delete.
    Nov 14 2011
    North Carolina
    Quote Originally Posted by seph View Post
    Precisely. See those two holes up top that one could only assume would be perfectly lined up for a US license plate? They're way off. Not nearly the correctly width. I couldn't believe it, hence why I was asking if I had missed something, some kind of other part that mounts on there behind the plate - I noticed that my dealership drilled into my factory gray front US plate holder to make the dealer plate work but naively assumed that was because their dealer plates were a weird size. For a car and automaker with fit and finish off the charts, I refused to believe the solution was to drill into my US plate holder to make a US plate fit. But that's the way I guess it must be :( . Even stranger how they clearly have it correct for the rear plate mount, it's not like the measurements were off, it's such a weird thing. We must be missing something.
    Jan 19 2012
    Charlotte NC
    I'm also pissed off. Spending $150 on an OEM part that needs to be modified is just insane.
    Mine arrived today. I guess I am off to Lowes to hack this thing together. If anyone knows the proper way, please advise.
    Sep 25 2011
    GT3 Rs/LX 570
    Cocaine Capital, Fl
    I had the same issue. Its normal. The holes were drilled and when i tried to put the front plate...new ones were needed. Smh really.. I just got the plate delete and said...fuckkkk that! $50.00 mod worth it
    Nov 14 2011
    North Carolina
    Yup, I just had to drill into the damn thing with new holes - what were they thinking putting those holes for US plates like that. It's pretty weak.
    2013 A4 P+ Monsoon Gray
    LEASE END - 2014 Chevy Spark EV - 400lb/ft tq,
    SOLD - '12 P+, S-line, NAV, OEM Sport Package
    HR 15mm spacers, 3.2 Grill, Gloss Black painted surround
    Wincos 45 tint, Rieger replica rear trunk lip, VAG COM goodness
    Jan 19 2012
    Charlotte NC
    What did you guys use to fasten the plate? Nut and bolt? Or simply short self tapping screws?
    Sep 05 2014
    Charlotte, NC
    Hi everyone, I'm a newbie here. I know this is an old thread, but was wondering if anyone has any new findings. I just bought a Q5 with the front piece for a vanity plate, and rather than the standard 7" holes, it has two HUGE (too big for plate screws) holes 8.5" apart. I would like to avoid drilling into it, has anyone found an add-on or adapter for this?
    For those who might say the only option is to drill, how did you do this? Was it with a special screw or nuts/bolts/washers...?
    Thanks!!!
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by lkngal View Post
    Thanks!!!
    The front plate (which was installed by the dealer) on my factory mount is held on by short self-tapping screws. I bet if you drop by the dealer they can just give you some, or at least tell you what size they use.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
