Transmission is done, sitting in my garage. The motor got dropped off, FINALLY. Looking at around 2 weeks before it's back, and then the long block assembly starts.
That is a 2.0FSI crank, forged from the factory.
I'll be running just an enlarged AEB manifold for the next 4-5 months, and then our own 034Motorsport Intake Manifold, should be out this summer.
For now I'm going to stick with a SPA exhaust manifold and 3" downpipe, into my 3.5" rear system I already have. Next year I will go to a tubular manifold and a full 3.5" downpipe. I need to get used to the car on the track so I'll be spending most of the next year around 350whp.
I'll be running a Guard rear LSD, clutch disc style. We've worked with them before and my Porsche friends like them a lot. I like how clutch plate/pack diffs feel in general, but the constant need to rebuild and how nasty on/off they get as they wear sucks. Luckily the Guards seem to not get so clunky as they wear, and this car won't see much mileage. I originally come for big lifted Jeep scene and running around daily driving a full on Detroit locker so a little bind is fine.
I'm running our 034Motorsport Race Upper Adjustable Control Arms, different than our Density Line Adjustables. They are spherical inner and outer joint and allow up to 3 degrees negative camber. We can also make custom ones for even more. As UCF mentioned, you can also use the A6 lower control arm hole to increase track and camber. We use this on our Time Attack car. It requires a CV joint spacer.
