Page 2 of 6 FirstFirst 1234 ... LastLast
Results 41 to 80 of 211
  1. #41
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    Quote Originally Posted by Max@034 View Post
    Also, if it wasn't clear before, I run 255/40/17 on all my B5's. 8" rim with 35 offset. Only the front needed a little rolling. Same contact patch as a B7 RS4 stock.
    what is your gtf? 255 seems meaty for a b5
    (or maybe i just need to step up my game?)
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
  2. #42
    Veteran Member Four Rings gmx's Avatar
    Mar 01 2008
    '12 1M
    Sydney, AU
    I ran 255 on a 8" wheel until one got punctured.
    I wouldn't do it again with street tyres though - way too much flex.
    The RS4 runs a 9"wide wheel...
    00 A4 1.8TQ MT (AJL)
    12 1M
    18*8 RPF1 | Vogtland GT 575F/675R | H-Sport Sways | 320mm B8 Brakes, 300mm S4 rear |
    GT2871R Elim | QMS tuned AJL 627cc EV14 @ 4.3bar | 034 3" DP (8psi backpressure!) | Milltek | JHM SSK
    3090lbs
  3. #43
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    Quote Originally Posted by flynnr View Post
    Depends on the car, but of course I am not slammed; I am performance minded, I don't care much about aesthetics. The roads I tend to drive are nasty too. I'm about 25.5 or 25.25".
    Everyone always cries that 255's are not possible; this is the only size tire we run on B5's here @ 034Motorsport. Extensive track testing with the Time Attack B5 A4 was done before it went widebody, and the 255/40/17 tire on an 8" wide rim was found to be the most ideal. Contact patch is huge.
    However, GMX, while there is considerably more sidewall flex then a lower profile tire on a larger rim, this doesn't necessarily equate to better performance; at all. There are a variety of advantages (such as ride quality, the ability to conform to rough road surfaces, more rim protection, and better launching as well), compared to the slight difference in breaking point. A tire with less profile and less squirm will hold more lateral grip, but will release in a much more abrupt way.
    We run 275/35/17 on the Time Attack B5, 9.5" rim.
    I've tracked the 255/40/17 setup as well as pushing it well beyond the limits, in addition to running a ton of other rim and tire and sidewall combinations. I will ALWAYS run 255/40/17 on narrow body street B5's; the amount of data and back to back comparisons done by 034 in the earlier days is undeniable. I don't expect razor sharp reaction times in a 3700 pound front heavy pig. =)
    The Best Things in Life Are Free... Or Heavily Discounted!
  4. #44
    Sep 22 2008
    Minnesnowta (Roch)
    nice. ill have to go that route then
  5. #45
    Sep 22 2008
    Minnesnowta (Roch)
    I am more performance oriented as well. i would never 'slam' my car either. I was asking gtf so i could mimic your setup. If you get a chance to take a for sure measurement let me know!
  6. #46
    Sep 17 2005
    Fremont, California
    Right now, I am 25.3" front 25.5" rear.
  7. #47
    Veteran Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 4.2QM, 01 Nogaro RSFaux Avant, 15 Q7 TDI Sport Edition
    Valparaiso, IN
    I ran 255s on 17x8 et35/27 for a while. Only problem I had was turning, because I like being low.
    Brilliant Black 99.5 A4 Project V8
    Nogaro Blue 01.5 S4 B5 RSFaux
    Glacier White 15 Q7 TDI Sport Edition
    Poopoo Brown 80 5000s Diesel
    Audi R8 certified technician - PM for work local to Chicago/Northwest IN
    Alex
  8. #48
    Sep 17 2005
    Fremont, California
    Stuff is coming together.
    Got a full 06A shortblock. Just need a crank and some pistons, and I am good to go!
    Big Thanks to the Integrated Engineering Crew, too! Juiced on my new set of Tuscan rods!
  9. #49
    Jun 21 2005
    Milton, Ontario
    Nice, what turbo you going with Max?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
  10. #50
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by SleeperAvant View Post
    Precision 5857, journal bearing, and a 38mm Tial WG. Probably just do a SPA manifold for the time being or possibly a PSI, and build a tubular manifold next year.
    I think for the time being I will also just modify my big port intake manifold (further porting and maybe some horn work), or possibly just reuse the runners and fabricate my own. Either way, I'll run a 65mm throttle body body likely.
  11. #51
    Oct 06 2004
    Minnesota
    What throttle body?
    Instagram r_michals
    '12 Q7 TDI- Glacier White
  12. #52
    Mar 22 2009
    Norcal
    Quote Originally Posted by A4Rob View Post
    What throttle body?
    Not sure, but I have quite a bit of flexibility with the 034EFI Stage IIc. Probably just use a V6 for now?
    Next news is that I decided I'm going to keep these Work Emotion CR Kai wheels. They are so sexy white, and while they aren't 9" or 9.5", I just picked up a whole bunch of Continental Extreme DR race tires (none of that DOT legal crap!) in 245/40/18 so the 8.5" width on the Work's will match the wear pattern on the tires (from our Subaru STi 25 Hour race car).
    Next on List: FSI crank
  13. #53
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    i just did a little reading through this thread and i approve lol. how do you find the time for all of the things youre involved in?
  14. #54
    Mar 16 2009
    Valparaiso, IN
    Any possibility you will run the PSI mani? I've been eyeing it for about a year now
    Alex
  15. #55
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by AudiForeman View Post
    Hah, I have a very understanding girlfriend.
    Quote Originally Posted by NeedingAnAudi View Post
    The SPA manifold is in stock and the price is pretty unbeatable, especially with the downpipe. However, the PSI manifold does look nice.
    If I was going to be running a MAF element, then I would go for the PSI so I could run our XL turbo inlet hose. But I am MAFless so I do not need a "stock fit" style manifold really.
    I'm still trying to figure out what pistons to use. Been trying to go JE since that is what I have on my S4 and my builder knows them well, but might look into trying something else.
  16. #56
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Quote Originally Posted by Raacerx View Post
    Max do you *need* the FSI crank? I have a few of the AZG CAST units I could spare for this project.
  17. #57
    Sep 17 2005
    Fremont, California
    Got some more goodies. Hancook race tires not pictured. Continential race take offs.
    Quote Originally Posted by Issam@INA View Post
    I don't necessarily "NEED" the forged crank, looks like there are some people are at the power levels I want with the cast unit, but it just seems like a good idea for peace of mind. They certainly are expensive though.
  18. #58
    Nov 21 2006
    san francisco, ca
    Take those seats out already would ya! :-P
    --dillon
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
  19. #59
    Feb 26 2006
    Earth
    Send me an email in the morning. Ill show what we got.
  20. #60
    Sep 17 2005
    Fremont, California
    Got some exciting news about pistons! More to come in the near future! This is turning into quite the build, so I think I will be going FSI crank just because I already did premium rods and everything else. The pistons should be a great compliment to this project.
    -Max
  21. #61
    Jun 21 2005
    Milton, Ontario
    Pretty exciting stuff !
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
  22. #62
    Sep 17 2005
    Fremont, California
    Pistons have arrived, and I am excited.
    Big thanks to JE Pistons!
    I will be running their FSR (asymmetrical) stroker piston set in my 2.0L. Really excited about them because of their lighter weight (almost 20 grams per piston!!!) and their asymmetrical design, which decreases drag and friction losses on the up stroke of the piston!
    82.5mm bore, just under 9.0:1, extra deep valve reliefs for variable valve timing at high rpm with aggressive cams.
    With Integrated's Tuscan rodset and JE's new piston design, I am 40 grams lighter per cylinder compared to the traditional H-beam + normal piston style. That's 160 grams in the rotating assembly, which is seriously significant. A quarter pound!
  23. #63
    Established Member Two Rings biglou's Avatar
    Oct 27 2008
    2001 Audi A6 , 1998 BMW M3 cab
    home
    damn , this is just as serious as my car !!! im building a 1997 M3 . My custom pistons are about 83 grams lighter than anyone else on market. good for 2000hp :). also using tuscan rods, IE said they are good for 1400hp on my car, well see lol. this stuff is alot of work and patience :( . how much is your car going to weigh?
    good luck with everything !!!
  24. #64
    Veteran Member Three Rings KMEL65STANG's Avatar
    Mar 15 2009
    Washyourrhand's Imola B5 S4 Stage 1,2,3
    HAYWARD, CA
    Been out of the loop for a sec! Did u pick this up from Gil?! I swear it's the same car when I went to pick up mike's Imola! This is a sick ride bro!
    2002 B5 S4 w/ stage 3 driver!
  25. #65
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by KMEL65STANG View Post
    Yep. We were going to build it together but he's got other plans now and I wanted to take it on by myself. Decided to keep the Work's too, they are on the S4 right now. =D
    Unfortunately, this project is on hold right now while I finish the single turbo S4. My plan is to have the A4 broken in and tuned and ready for track testing in August. I have just about everything I need to get the motor built, and I still need to swap in my 01E 6 speed drivetrain and get some real suspension, but I've got it on full sphericals now.
    I'll be learning how to tune on this bad boy too.
  26. #66
    Jun 21 2005
    Milton, Ontario
    Wow nice, what would a setup like that cost (pistons only)?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
  27. #67
    Sep 17 2005
    Fremont, California
    The FSR piston set? Depends what bore/stroke/coatings but they aren't too much more then the normal JE pistons.
  28. #68
    Jun 21 2005
    Milton, Ontario
    Ah, okay.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
  29. #69
    Senior Member Three Rings silverman's Avatar
    Sep 27 2008
    '98 A4 1.8tqm. Bilstein pss9.
    Hartford, CT.
    Are those new JE pistons available in 10:1 ?
    And you keep bringing such good info to the table! Good luck with both builds.
    Cactus green B5 A4!
  30. #70
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by silverman View Post
    Most of their pistons are available in custom compression ratios. Are you looking to run only race gas? 10:1 on the 1.8T is pretty aggressive, especially if your head has been decked before.
    9.5:1 is great for 93 octane, just can't run quite as much boost but more timing.
  31. #71
    Sep 27 2008
    Hartford, CT.
    In dream land... I plan on running a 2.0, meth and 93 and standalone. I just want more low end for daily driving while being able to bounce off the limiter. I pretty much thought 10:1 would be the highest to go on a "street" motor. This is all a dream but as we all do, I've been researching for 6+ years...Long before I had the car.
    Cactus green B5 A4!
  32. #72
    Veteran Member Three Rings rvca3112's Avatar
    Aug 08 2010
    brick/nj
    Any advancements in this project or still with the s4? What's going on with that thing? This thread is what I'm basing my build off of.
    2003 Porsche 911 turbo 623 awhp
    2009 Porsche Cayenne s 317 awhp
  33. #73
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by rvca3112 View Post
    Yep, unfortunately still with the S4, just trying to get everything finalized for the single turbo kit.
    All the parts for the 2.0L are sitting here teasing me, but just no time to start getting a motor built. I really don't want to have the shortblock put together, and then have it sit for a month or two. But at the same time, the girlfriend is getting sick of the car taking up most of our garage...
    My first priority is to get the 6 speed drivetrain swapped into the car.
    Already have the Stage IIc ECU and the engine harness ready to go.
    Once things start moving forward, they should progress very very quickly. Right now I'm trying to decide if I should keep the RS4 clutch for awhile and just hang out around 350whp (dunno if it will hold), or go straight to a Tilton setup. I would like to be able to drive the car on the street for the first year, in case the S4 is being worked on, but the ultimate goal is a race car so I want to skip forward as much as I can.
  34. #74
    Veteran Member Three Rings Grip99's Avatar
    Feb 15 2011
    ny, ny
    Nice build/car, Max!
    Cant wait to see this thing run!
    -Pete
  35. #75
    Established Member Three Rings morzechowski's Avatar
    Jul 20 2011
    500whp 1.8t, 2500HD Duramax
    Minnesota
    The ultra lightweight JE pistons are so noisy inside the block. The ultra lightweight aspect is awesome, but the noise is so annoying.
    I like George Michaels
  36. #76
    Nov 21 2006
    san francisco, ca
    I run a Southbend setup max. No issues. Its an OFE SS stage 4, well it was until they changed the names. Now it may be a stage three. Not the easiest to drive but also not an on off switch. I think the new part number is K70205-SS-TZ-SMF, good for 425 ft/lb's. Much cheaper then the tilton setup too. Southbend rebuilt mine for $175 i think.
    --dillon
  37. #77
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Grip99 View Post
    -Pete
    Thanks Pete! I basically forgot about it the last 2 months because of the S4, but now the pistons and rods and bearings and valvetrain and everything else is just staring at me from my sun room...beckoning for me to build it!
    The 06A block is ready to go, and the AEB head has already been Stage 2 ported.
    Quote Originally Posted by morzechowski View Post
    I consider normal JE pistons to be one of the noisiest pistons out there, but never had any issues with them; they just seem loud. I'm not surprised that the FSR's are even louder, but this is a race car so I'm not concerned about engine noise; I'm sure it will be drowned out by the lack of sound insulation and a short 3.5" side exit exhaust!
    Are you running them Mike? Can't remember.
    Quote Originally Posted by nunya View Post
    --dillon
    If it was a Southbend setup, I wouldn't think twice about just wearing it out. But since it is an RS4 pressure plate and I think a pretty basic S4 or Stage 1 or 2 disc, not only do I think the current setup won't hold +400whp, but it's just so so heavy. I really do not want to run a traditional style single disc clutch, specifically because of the weight; not even so much the power. The big huge 240mm discs just take forever to shift, and combined with the 01E, it's just way too slow for a dedicated track car.
    I don't mind rough engagement, I used to have a twin disc on my S4, and eventually I'll end up with an iron sintered Tilton twin disc, which is a freaking bear to drive... If i had a proper Southbend in there, I'd deal with the slow shifting for now, but since the current clutch probably won't hold the power AND it is slow as hell, it has me thinking of following my primary motto of "DO IT ONCE, DO IT RIGHT!"
    The Tilton is really not that expensive; the clutch itself retails for barely over $1000 (with hardware and billet TOB), leaving only the flywheel. Of course, I wouldn't expect it to last more then 5000 miles, but it should take years to put that kind of miles on the car (or maybe never).
    I plan on stripping the interior sooner, rather then later, specifically so I don't get tempted to just build a street car. I want to get so far into this build that there is no turning back and no desire to cut corners.
  38. #78
    Nov 21 2006
    san francisco, ca
    I see how it is, you are saying i did it wrong! :-P
    --dillon
  39. #79
    Sep 17 2005
    Fremont, California
    --dillon
    You're clutch is perfect for a daily driver!!!
    I knew from the start what this car would be used for, and I'm learning my lessons from my B5 S4... There are lots of things I regret not doing in that build, and it taught me that you either go slow and pussy foot it, or you do it once and do it right and go balls to the wall!
    Of course, balls the wall would be acid dipping and trussing the chassis... I don't think I'll be going that far hahaha, but something like a clutch, I don't want to mess around with, especially with a 5858 and its potential.
    But on the good side of things, I just sold my MKII GTi and will hopefully have my other A4 sold soon, and then its time to get this show on the road. I'm still hoping to have things together by the end of August.
  40. #80
    Jun 21 2005
    Milton, Ontario
    Update?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
